Like Tree36Likes
Old 01-31-2015, 09:52 AM   #6901
kevinpratt823's Avatar
Originally Posted by John Myall View Post
Not to defend him as I have my own doubts over some email replays I've had from them this week over metal gear comparability, but it's the EOS rd in Berlin this weekend, so it's possible he's off doing that and can't check things before replying to you....
Precisely, but to be honest I would be surprised if I actually even get a response. It would not be that far fetched to think that he may not even be aware of the issue, or any others, and that his underlings in the company are the ones trusted to call the shots on how to deal with some of these things. My hope was to make Mr. Hudy himself aware of how his company is dealing with his customers, in case he isn't already.
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 01-31-2015, 09:55 AM   #6902
Originally Posted by Toenz View Post
Yes the insert position from Team C is 0.5mm lower.
The Part is available by Eurorc Part Nr. 04130
To Norse- This is what I went by. When I looked it up, I found this # but with a "T" in front of it. That is what I ordered, I hope the T didn't mean it was a different part though.......
T04130
Old 01-31-2015, 10:46 AM   #6903
Trader Rating: 30 (100%+)
Hello Kevin,
Thank you for the part info. as I greatly appreciate it. I think the T is for Team C but I could be wrong. Where did you order from. I know Evo hobbies carries a lot of Team C gear. Looks like this is a nice temporary fix.
Thanks Again,
Norse is offline   Reply With Quote
Old 01-31-2015, 11:30 AM   #6904
Originally Posted by Norse View Post
Hello Kevin,
Thanks Again,
I got the last one from a seller on ebay. If you look at my post a page or two back, the fact that this brace has the insets .5mm lower throws some of the adjustments off a bit from what they would be with the proper brace, so consider that when you set your inserts.
Old 01-31-2015, 11:36 AM   #6905
Default Hangers Xb4
Hey Fellas,
Another option for a temporary fix may be the rear hangers for the Sworkz s104
They have an option rr hanger in a neutral anodized finish and rear front is red ano. Amain or RCMonkey for the rr option. Just a thought for another temporary fix.
Best,
J
Old 01-31-2015, 12:15 PM   #6906
Hey Fellas,
Best,
J
Do you know for sure that it fits? Do you know the dimensions of the insert holes from the screw holes, and have you confirmed that the inserts are the same?
Old 01-31-2015, 12:25 PM   #6907
Hey Kevin,
I believe you may have to use s104 inserts which are $9 for all of the various different settings. i believe the mounting holes are exact but I will thoroughly compare to be certain.
Are you using the rear rear hanger from Team C for the XB4 rear front as well?
Thanks Kev
Old 01-31-2015, 12:28 PM   #6908
Evo hobbies site says the Team C hangers Kevin discovered are in stock
Old 01-31-2015, 12:51 PM   #6909
That's just it, he may not have been aware about it till your message, now he is & the executions start Monday/Tuesday after they get back from Berlin.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 01-31-2015, 01:24 PM   #6910
Originally Posted by masin14 View Post
I'm not sure if this has been discussed yet or not, but are the brass rear holders also offset? or are they correct.
I don't think anybody has confirmed with measurements, but most of us agreed they certainly appear to be by looking at Amain's picture, but I'm certainly not giving them $62 to find out.
I have just measured my brass rear hanger. (363313)
It is off aprox 0.5mm.
Also measured the original +2 rear hanger of the XB4 2WD.
It was also off aprox 0.5mm
Really strange that no one has discovered this before.....
Bonanza73 is offline   Reply With Quote
Old 01-31-2015, 01:39 PM   #6911
Hey Kevin,
Thanks Kev
It was Toenz that discovered the Team C hanger, and according to him the rear/front brace doesn't fit because the screw holes don't line up. I have not gotten mine yet, but I only ordered the rear one. I am running mis matched inserts still. I mismatched by .5 deg last weekend, but this weekend I will be going with the full 1 deg now that Rcgod has confirmed that that is closest to true.
Old 01-31-2015, 01:42 PM   #6912
LOL, I hope that is the case.
Old 01-31-2015, 02:05 PM   #6913
Trader Rating: 15 (100%+)
The Team C brace is not a very good alternative for carpet though, as the inserts are .5mm lower, so you will not be able to use the high roll center options. Even if you put 1 deg inserts up, the pin will still be lower than the Xray brace with .5 deg inserts up. Being that the Team C brace inserts are .5mm lower, this also throws off the rear anti-squat, as the Xray inserts are .375mm and .750mm.
I hope people remember to take this into account when using them. Personally, I will try it initially with 1 deg down/in on the front, and 1 deg in for both rears, this should in theory give a touch over 3 deg toe(as the insert are reportedly .1mm wider), with a bit less anti squat angle. That's about as close as we're going to get to the setup most of us are shooting for.
From this description, this Team C hanger could be dubbed the RR+1, lol. The eccentric bushings are the tricky part. Do the Xray bushings fit does anyone know or had that been determined and I missed it?
For carpet I'd run the chassis plate to raise the hangers either way.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 01-31-2015, 02:13 PM   #6914
Originally Posted by HeavyD99 View Post
From this description, this Team C hanger could be dubbed the RR+1, lol. The eccentric bushings are the tricky part. Do the Xray bushings fit does anyone know?
Toenz, who found this brace, said they measure the same and fit.
Old 01-31-2015, 02:27 PM   #6915
I will measure the s104 hangers when I return from my daughters basketball games.
Thanks Fellas
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
