Like Tree36Likes
Old 01-27-2015, 11:45 AM   #6751
Canadianrage's Avatar
Checked my '14 car, hangar is worse than the '15 one. Brass version is off the same.
Loved my '14 car, beat it to death and it still was good enough to run up front.
First night out with the '15, will be Fri night. I have a feeling it will be better yet. Added a 1 deg shim and called it good.
- Xray XB4 2015 VTXR10BE / Trinity D4 6.5 - Associated T5M R10 / Tekin Pro2 5800 -
Canadianrage is offline   Reply With Quote
Old 01-27-2015, 11:46 AM   #6752
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by theclutch View Post
It's NOT in my 2014 version of the car. And this issue would be VERY noticeable in handling on the track.
Maybe the 2013 and 2014 cars had the diff case holes off center and this was Xray's way of fixing it. Idk. I have a new set of 2014 rear toe blocks sitting in front of me and the rear one is visually off. Not even going to open the package, back to amain it goes.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 01-27-2015, 11:49 AM   #6753
rcgod's Avatar
Playing devil's advocate, if you didn't notice it on the track even if it were off, would you still be ok with it?
Mine wasn't noticeable from behind the wheel, but it was pointed out to me by a buddy that he could see the back of my car stepping out when viewed from behind. Not a lot but enough to ask me to check my car. That's what started the whole thing for me.
Dialed RC Hobbies
Old 01-27-2015, 11:56 AM   #6754
blwaz23's Avatar
The car feels fine to me box stock even with the issue.
blwaz23 is offline   Reply With Quote
Old 01-27-2015, 11:56 AM   #6755
slakr's Avatar
Trader Rating: 28 (100%+)
After knowing, definitely not OK with it. And the even bigger issue for me is the manner in which XRAY chooses to handle the situation.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is online now   Reply With Quote
Old 01-27-2015, 11:58 AM   #6756
ProfessorX's Avatar
Trader Rating: 17 (100%+)
Good thing I have a d413 meanwhile this is still sitting around
ProfessorX is offline   Reply With Quote
Old 01-27-2015, 11:58 AM   #6757
kdeleon's Avatar
That's a fair statement. I just wonder why the team drivers haven't noticed it and had XRAY fix it. Especially on the high grip carpet tracks, you would have thought it would have been more noticeable than on looser dirt tracks. Those folks can pick up the smallest changes in their cars.
kdeleon is offline   Reply With Quote
Old 01-27-2015, 12:02 PM   #6758
rraden's Avatar
Trader Rating: 231 (100%+)
Really, what would you notice? Would the car pull, hook, launch wrong, something else? If this has been on the car for some time I don't see anyone complaining of what it does on the track.
I'm in no way agreeing with what Xray is not doing. It's wrong and they should correct it. They are a premium manufacturer and this lack of detail is not acceptable.
But, it took a long time to notice so my guess is it's not too noticeable on the track.
Xray XB8E 2016 | MBX7TR Eco | Xray XB4 2017 | Xray XB2 DE | Xray XB8 2017
Dirt Burners - Livonia, Mi
The Track - Carleton, MI
rraden is offline   Reply With Quote
Old 01-27-2015, 12:13 PM   #6759
kevinpratt823's Avatar
You may want to double check that, both the '14 I looked at Sunday appeared to be this way, and others on here have confirmed the measurements...
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 01-27-2015, 12:19 PM   #6760
rcgod's Avatar
I would think it it's more noticeable on loose tracks. I was driving on a med bite track maybe even a little loose when it was noticed.
Idk.
Dialed RC Hobbies
Old 01-27-2015, 12:31 PM   #6761
slakr's Avatar
They are probably all running #0 on the right and +1 on the left (or some similar equivalent)... LOL
Old 01-27-2015, 12:44 PM   #6762
suby723's Avatar
Trader Rating: 21 (100%+)
Hated to do it but I also left a one star review on amain. I really hope this will be a wake up call for xray. A great kit has a two star review because xray wants to not make it right for customers that purchased a $450 roller.
suby723 is offline   Reply With Quote
Old 01-27-2015, 12:48 PM   #6763
jmcelroy42's Avatar
Ok guys I finally had time to take some measurements on the CMM with different combinations of inserts. I also measured the distance to the centerline of the mount insert pockets. It was worse than I originally thought. All measurements are to the centerline of the chassis. Here's what I found:
Inner hinge pin angles with 0 inserts:
Left 2.73 degrees
Right 3.60 degrees
Inner hinge pin angles with 0 insert right side and .5 insert out on left side:
Left 3.22 degrees
Right 3.60 degrees
Inner hinge pin angles 0 insert left side .5 in on right side:
Left 2.73 degrees
Right 3.08 degrees
Inner hinge pin angles 0 insert right side 1 insert out left side:
Left 3.69
Right 3.60
Centerline of chassis to centerline of insert mount pockets no inserts:
Left .9004"
Right .9280"
Offset of pockets to centerline of chassis:
.0138" towards right side.
I measured my mount at .010" offset with calipers, but looks like the holes in the case are also offset about .004" No bueno.
You didn't list this combination but I believe it would give the closest to 3deg per side, witch is what they say 0's should give you?
.5 in on right, .5 out on left
Left 3.22 degrees
Right 3.08 degrees
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 01-27-2015, 12:50 PM   #6764
The first time I drove the car, I had my trim set straight by eye on the bench. As soon as I punched it on the straight my car veered right, so I had to go several clicks left on the trim to make it go straight. Next time I drove the car, I noticed my trim appeared to be set a bit to the left before I put it on the track, I figured I just leaned on the trim button and threw it off, so I corrected it by eye to get it back in the ballpark, guess what, as soon as I punched it down the straight my car veered right......see where I'm going here?
Sometimes, when you don't know something is wrong, you don't notice it until you experience it when it's better. Have you ever thought your car was working great, then made a change just to experiment and it felt better?
My car definitely felt better on the straight with just a .5 difference in the insert, and that was still uneven.
To answer the other question, and I'll speak for myself, any anger I have is entirely from the bogus responses from Xray, refusing to acknowledge the issue, let alone work on a solution, insisting that everything is correct/within tolerance, and to some extent the tone of some of the responses, which imply that regardless of what I have in my hand, see with my own eyes, and can measure with my own tools, they could not possibly be wrong. Going as far as inventing unrealistic reasons as to why the brace is designed that way, hiding behind their self proclaimed "Legendary Attention to Detail", which seemed to be an attempt to just shut me up about it, all to avoid having to correct it.
I was not angry when Losi had soft pins failing in the SCTE, because the acknowledged it and sent updated parts, I was not angry when Tekno's first run of EB48 had outdrives that wore out right away, because they acknowledged it and made updated parts. When the first Tekin RX8's were failing prematurely from impacts/vibration, and they took them all back in and fixed them under warranty with a new 3 hole case to identify the corrected ones, again I was not angry. I continue to buy and support both those brands, I have (3) Tekno's, (8) losi's, and (7) Tekin systems plus spares on the shelf, partly because of this .
Had Xray just said, gee you're right, we will see what we can do to correct that, or some other response of that nature, I would have understood completely and patiently waited for a solution, meanwhile continuing to run my car with mis-matched inserts, and speaking highly of them for wanting to give the end user the best performing product they could.
Old 01-27-2015, 12:52 PM   #6765
Left 3.22 degrees
Right 3.08 degrees
I would have to say that would likely be correct, and another decent alternative for now.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
