Like Tree52Likes
Old 01-22-2015, 10:30 AM   #6526
CarlCrocco's Avatar
Trader Rating: 88 (100%+)
Originally Posted by rcgod View Post
Making new (correct) parts, sending them out for anodizing, and getting them out to the distributors isn't going to be an overnight fix. I will be surprised if the new parts are available anytime soon.
Yes this can happen to any company but considering how much they talk about German engineering and quality, it's dissapointing. Where was qc? Didn't they do any in-process inspection? No final inspection? Was the machinist drinking coffee and reading the paper when he should have been spot checking his work? Sorry it's frustrating because I'm a quality inspector and machinist by trade and I see these problems a lot when companies get in a hurry and skip qc.
I'd like to see BentKa's response to this.
Andrew Crocco "The Hammer"
Viper R/C
XB9E XSCT
CarlCrocco is offline   Reply With Quote
Old 01-22-2015, 10:36 AM   #6527
Qwkrn U's Avatar
Trader Rating: 128 (100%+)
I envison the fix being a care package sent out. They are very good a boot standing behind their products.
Qwkrn U is offline   Reply With Quote
Old 01-22-2015, 11:23 AM   #6528
Trader Rating: 22 (100%+)
I went ahead and emailed xray about this. If you haven't already please email or contact them so that they are aware its not an isolated issue.
littleZEN is offline   Reply With Quote
Old 01-22-2015, 12:01 PM   #6529
theclutch's Avatar
You guys with the 2015 should take a look at your rear toe block. I could see mine was off by eye and confirmed it with calipers. A friend of mine is building his 2015 and his is off too. I sent an email to rc america and they're looking into it.
https://www.dropbox.com/sh/m5h99p73q...MaJXbMJTa?dl=0
Is this definitely with the 2015 only? I have a 2014 and while it appears "correct", I didn't take it out to measure it...
XRAY XB2 2018, XRAY XB4 2017, Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 01-22-2015, 12:06 PM   #6530
rcgod's Avatar
Trader Rating: 27 (100%+)
The 2014 kits didn't come with the +2mm rear mounts. So unless you put them on you're ok.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 01-22-2015, 12:13 PM   #6531
rcgod's Avatar
This pic is from the xray website. Looks to me like this one is off too. I hope my eyes are playing a trick on me. If not that means they've been off center since the beginning when the mounts came out last year.
http://www.teamxray.com/teamxray/sho...9694c360f7575#
Dialed RC Hobbies
Old 01-22-2015, 01:12 PM   #6532
kevinpratt823's Avatar
Damn I guess I opened up a can of worms. The good news is you can make the toe angle even by using a .5 offset insert sideways. The bad news is you can only get 2.5 or 3.5 toe.
I had posted this 9 days ago about my conversation with RCAmerica, so he was already somewhat aware. Thanks to all who confirmed, hopefully it gets sorted out in a timely fashion.
(Post #6409)
"Also worth noting, on the rear/rear brace, the right side insert square hole was almost .5mm farther from the screw hole than the left, and he(Bryan) measured about .3mm difference on one from the warehouse......."
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 01-22-2015, 02:42 PM   #6533
rcgod's Avatar
(Post #6409)
I feel better now. You're the one that opened the can of worms! Hope they get if fixed soon. Just got a replacement rear mount from amain and it's off.
Just ordered the 2014 rear mounts. Fyi amain has them on clearance for $19.95
Dialed RC Hobbies
Old 01-22-2015, 03:33 PM   #6534
someone have a review with photos of the XB4 2wd???
i m not sure about take it, ore xb4 2wd or losi 22 2.0 and i am so undecided but i dont find a review with pros and cons of the xb4 2wd....i found on the losi instead.
thanks all
i need for indoor track moquette.
turboboost is offline   Reply With Quote
Old 01-22-2015, 03:53 PM   #6535
GregerL's Avatar
thanks all
What type of surface will you be racing on?
Alexander Landén RC on facebook:
https://www.facebook.com/alexanderlandenRC
GregerL is offline   Reply With Quote
Old 01-22-2015, 04:07 PM   #6536
just to add more fuel to the fire...
http://www.amain.com/xray-2mm-brass-...er-set/p377658
The rear brass holder looks off to me too.
Old 01-22-2015, 05:36 PM   #6537
Wow, it certainly does look off........seems like they are all long on the right side(or short on the left), makes sense I guess if they were all machined with the same settings.
This is my first Xray, and I have to say, though some things are of great quality, between this, the fact that my dogbones bottom into the drive cups and stop me at half travel if I try to use the inner insert positions, and the terrible leaky/loose shock seals.....I'm a bit dissapointed. Perhaps they rushed this one out the door a bit too quickly.
Old 01-22-2015, 06:26 PM   #6538
Are you going to shim the gearbox up or just use it as is and put the inserts in the 1 deg top positions? I suppose the latter should be the equivalent of having the +2 with the inserts in the lower positions.......
FYI, I just set mine up with zero inserts on all but the right rear, which got a .5 deg insert in the inner/middle roll center position and it evened things up for now. Just sux that it will be my only option for adjustment.
Old 01-22-2015, 06:46 PM   #6539
aloksatoor's Avatar
Trader Rating: 42 (100%+)
been running those parts since last year on my now shelf queen 2012 xb4. I will measure those as well, the RR +2 is off center correct? I should have thrown it onto the setup station to check rear toe .
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-22-2015, 07:12 PM   #6540
suzukipro's Avatar
Trader Rating: 23 (100%+)
Hmn, I have the Brass +2mm Brass units NIP yet as I never tried them out, hopefully Xray will replace any faulty parts.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is online now   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
