Like Tree52Likes
Old 01-21-2015, 05:01 PM   #6511
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by kevinpratt823 View Post
When I was on the phone with Brian from RCAmerica about a week and a half ago, about my issue with the dogbones bottoming out in the drive cups, we were both measuring parts to compare. My rear black was about .5mm farther out on the right side, the one he measured from the warehouse was about .3mm I believe. I really need to get the RF one out and check it. I measured from the inside edge of the screw hole to the outside edge of the square hole and had about .5mm difference between the sides....and it was also noticeable by eye when looking at the gap from the arm.
Sounds like we both have the same issue then. Unfortunately rc america doesn't have any in stock so I ordered one from amain. Hopefully the replacement part doesn't have the same issue.
After racing last week my buddy mentioned that the rear of my car was kicking sideways under acceleration. I didn't notice it when driving but it's still not good. Now I know why.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 01-21-2015, 05:48 PM   #6512
[QUOTE=Wease;13794662]I run a Reedy Sonic Mach2 7.5t with the HobbyWing V3.1. I don't customize the settings ESC for anything except brake strength & neutral width. Is it possible your spinning the wheels when you punch the throttle and losing some forward bite? Maybe you've actually got too much power you're actually losing traction with the initial punch and you don't realize it? Have you tried going back to the slipper and seeing if you can clear the quad?
Yes with the slipper i was able to clear the quad, so with that said i went ahead and opened the center diff up to put 200k into it but saw that the center diff was almost empty. So i ended up just putting 100k back in and it worked fine. I did notice some oil around the spur and was wondering if anyone was having the same issue. this time i put some grease around the edge before putting it together..
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 01-21-2015, 05:48 PM   #6513
TPR 1's Avatar
Trader Rating: 26 (100%+)
Yep mines got .5mm difference aswell after checking it 3 times!
can't believe my eyes.
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 01-21-2015, 05:51 PM   #6514
Trader Rating: 29 (100%+)
Mine always seem a bit dry after the first run with a new diff. The oil gets into all the nooks and crannies making it look like it leaked out. Just refilll and you will be GTG.
DustinEich is offline   Reply With Quote
Old 01-21-2015, 06:23 PM   #6515
kevinpratt823's Avatar
I'm guessing there's a good chance that even if you buy one from Amain it'll be off then. I really hope Xray gets on this, figures out why, and gets some proper parts out to us.......
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 01-21-2015, 06:59 PM   #6516
Qwkrn U's Avatar
Trader Rating: 128 (100%+)
Just measured mine same issue.
Guess I'll be emailing xray
Wayne Robison
B5m , X-ray XB4 '15 ,xb8e, Scte 2.0
Tiny Boat Guy Paint Designs, Checkered Flag Hobbies, creativecustomtees.com
Qwkrn U is offline   Reply With Quote
Old 01-21-2015, 07:14 PM   #6517
Yea I measured the same also, damn
leothegreat is offline   Reply With Quote
Old 01-21-2015, 07:22 PM   #6518
suby723's Avatar
Trader Rating: 21 (100%+)
Same here, off by .30mm. Rcamerica will have the phone ringing off the hook tomarrow. It's all good if they make it right.
suby723 is offline   Reply With Quote
Old 01-21-2015, 07:43 PM   #6519
rcgod's Avatar
Damn I guess I opened up a can of worms. The good news is you can make the toe angle even by using a .5 offset insert sideways. The bad news is you can only get 2.5 or 3.5 toe.
Dialed RC Hobbies
Old 01-21-2015, 08:19 PM   #6520
Qwkrn U's Avatar
Or just run the non +2 holders
Wayne Robison
Old 01-21-2015, 09:15 PM   #6521
rcgod's Avatar
Yah that's a better option if you have them.
Dialed RC Hobbies
Old 01-22-2015, 12:44 AM   #6522
Trader Rating: 74 (100%+)
Does anyone know where I can buy a center diff kit ?
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is online now   Reply With Quote
Old 01-22-2015, 01:51 AM   #6523
Trader Rating: 22 (100%+)
Yep. Just measured. Mine is off by exactly .5mm. Sigh
littleZEN is offline   Reply With Quote
Old 01-22-2015, 07:19 AM   #6524
Trader Rating: 15 (100%+)
I just picked up a set from an RCTech member, his for sale post was from back in September so hopefully they were machined on another day than these recent blocks.
I'm sure Xray will rectify the issue. For a company that boasts doing everything in house, and making a high quality parts, this non symmetrically machined rear toe block issue will give Mr. Hudy fits. They have already had to issue a V2 to their build manual, that shows things were a wee bit hurried.
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 01-22-2015, 08:59 AM   #6525
rcgod's Avatar
Making new (correct) parts, sending them out for anodizing, and getting them out to the distributors isn't going to be an overnight fix. I will be surprised if the new parts are available anytime soon.
Yes this can happen to any company but considering how much they talk about German engineering and quality, it's dissapointing. Where was qc? Didn't they do any in-process inspection? No final inspection? Was the machinist drinking coffee and reading the paper when he should have been spot checking his work? Sorry it's frustrating because I'm a quality inspector and machinist by trade and I see these problems a lot when companies get in a hurry and skip qc.
Dialed RC Hobbies
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
bprc10T3
