Like Tree36Likes
Old 01-18-2015, 08:16 PM   #6481
MaxxBashers's Avatar
Trader Rating: 107 (100%+)
Anyone gonna be selling a '15 anytime soon?
Eric "EJ" Jordan
MaxxBashers is offline   Reply With Quote
Old 01-18-2015, 09:14 PM   #6482
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
I have a 14/15 that will be going up soon.. all 15 chassis setup with center gear diff shorty only, with 14 towers and regular plastic diffs, not the metal ones.
MaricopaAgent is offline   Reply With Quote
Old 01-18-2015, 10:13 PM   #6483
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Apparently the most inner is useless. Unless You want maximum dog bone plunge. I had similar ish with front causing out drrive snappage. Iunno.got the feel inner pos is not gd frnt or rear.
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 01-18-2015, 10:27 PM   #6484
BDRMBULLY's Avatar
Apparently the most inner is useless. Unless You want maximum dog bone plunge. I had similar ish with front causing out drrive snappage. Iunno.got the feel inner pos is not gd frnt or rear. Either way dont wanna snap ojtxrives to be replaced with old or updated parts. Due to price point. And b/o partz
Nor do iknow if im getting old or updated parts wich i assume im getting newer parts due to the fact the old style was b/o for the last 6months .ive bought a 15 centre diff for my 14 on ebay hoping it will work . Still not sure.
Hand D Flooring
Old 01-19-2015, 01:06 AM   #6485
GregerL's Avatar
If you use the most inner position you must have external up-stop limiter on your dampers, otherwise you will have the problem you are mentioning.
The center diff will not fit the 14 without some real modifications.
Alexander Landén RC on facebook:
https://www.facebook.com/alexanderlandenRC
GregerL is offline   Reply With Quote
Old 01-19-2015, 06:09 AM   #6486
center differential bearing placement
https://www.facebook.com/2015XB4/pho...type=1&theater
Old 01-19-2015, 07:13 AM   #6487
Trader Rating: 74 (100%+)
My 2015 XB4 keeps getting better! Running the shorty and center diff with 100k. I have no issues with forward bite using 100k. I've read a few guys wanting to go higher than 100k to be able to clear some of their bigger jumps but that is not my experience thus far. Last night I was consistently hitting a triple located immediately after a sharp 90 deg turn; a jump I previously would just double-single. The center diff for me on clay is infinitely better than the slipper! I Love this wheeler!
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 01-19-2015, 06:06 PM   #6488
Boz
Trader Rating: 23 (100%+)
Originally Posted by ridgeback View Post
Quick question guys, I have the rear suspension holder pills set both RR and FR at the lowest and most inner position. With the pills front and rear set the same, has anybody actually measured the actual toe in? One of the setup sheets for Clay that im starting with says to set the rear toe to 3 degrees; it also has the pills in the inner/lowest position. But looking at the rear tires/wheels; doesn't look like much toe at all. Any help would be greatly appreciated.
The FR holder is for the rear of the front bulkhead.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 01-19-2015, 07:16 PM   #6489
suby723's Avatar
Trader Rating: 21 (100%+)
Yeah I have no intentions to change from 100k also. I'm running 8k front and 7k rear. What are you using?
suby723 is offline   Reply With Quote
Old 01-19-2015, 07:46 PM   #6490
TPR 1's Avatar
Trader Rating: 26 (100%+)
Has anyone run the 15 on low bite dusty track in shorty config without the rear
top deck vs with it and how much difference did it change the rear traction?
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 01-19-2015, 07:54 PM   #6491
suby723's Avatar
I did actually and it was pretty good. Hard pack/dusty conditions and I ran the car without a rear top deck and no chassis screws(only two required). The car was a lot better without the top deck.
Old 01-19-2015, 11:19 PM   #6492
TPR 1's Avatar
cheers for that mate.
what pistons did you choose on your dusty track?
does anyone who filled their centre diff up with 100,000 remember how much
it weighed?
-Adelaide RC -
-Game On
Old 01-19-2015, 11:34 PM   #6493
suby723's Avatar
it weighed?
2 hole front and 3 rear (kit setup) 37.5w losi oil front with 3 dot and 27.5w losi 1 dot rear. Set up links for low roll centers also and I was still running 1.2 swaybars front and rear. I never weighed my center diff but just filled to the same spot as the front and rear.
Old 01-20-2015, 04:42 AM   #6494
I'm running 8K front and 5K rear. That's what I ran in my 2014 so I built the 2015 kit diffs this way right out of the box.
XRAY 17 XB4
Yokomo YZ-2 CA
Old 01-20-2015, 05:44 AM   #6495
jmackani's Avatar
Trader Rating: 14 (100%+)
Do the pistons in the shocks seem better on the 15 kits? I know the the 14's had a lot of problems and guys were replacing them with avids.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
