Like Tree45Likes
Old 01-12-2015, 07:05 PM   #6391
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Originally Posted by HeavyD99 View Post
That'd be my next guess - are those rear dog bones really 68mm? Have you measured them? They may have been mis-printed?
There has got to be an answer to this!
Thats what I was thinking.. Check dogbone length..
I was thinking shocks still, as in the piston was bottoming out on one side. I was not looking at the dogbone hitting the inside of the cup.
Is your diff shimmed to one side for gear mesh?
My pin hardly passes center of the outdrive.
MaricopaAgent is offline   Reply With Quote
Old 01-12-2015, 07:09 PM   #6392
What does it look like with arms down?
mine at droop
Old 01-12-2015, 07:24 PM   #6393
Originally Posted by Boz View Post
Maybe one of the drive cups is not machined right? Have you tried putting the front diff in the rear?
on this note, the inside notches for my dogbones are Inside/even with the plastic diff case. Yours look to be outside.
two different cars.
Old 01-12-2015, 07:30 PM   #6394
Tektronix's Avatar
Originally Posted by kevinpratt823 View Post
I was kind of surprised at how loosely the o-rings/bushings fit in, the lower cap really doesn't squish anything down compared to most other shocks I have dealt with. I also found that after the initial bleed, when I pump the shock hard a few times before I do the final re-bleed, they almost seem to take a little air in.......Just build 'em and run it I guess, the air mixes right in with the oil after a few strokes and it still does what it's supposed to, but I will definitely be checking/re-bleeding them often until I get more familiar with them.
I run associated x-rings in my xb4. Much better seal than the o-rings. My o-rings leaked after every run. The x-rings stay nice and dry!
- Colton C. -
Losi 8ight 3.0
NITRO is Racing!
Tektronix is offline   Reply With Quote
Old 01-12-2015, 07:47 PM   #6395
Trader Rating: 15 (100%+)
@tektronix, do,you use the Xray spacers or the AE spacer with the AE x seals?
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is online now   Reply With Quote
Old 01-12-2015, 07:53 PM   #6396
Tektronix's Avatar
I use the the xray spacers with the AE x-rings. They work very well! No leaks at all. No shock shaft restriction either.
- Colton C. -
Losi 8ight 3.0
NITRO is Racing!
Old 01-12-2015, 08:18 PM   #6397
Boz
Trader Rating: 23 (100%+)
two different cars.
Its a rear end from 2015.
It just depends what side you are looking at. I have never notice that before. That is probable why Kevin car bottoms out on the right side first.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 01-13-2015, 01:52 AM   #6398
kevinpratt823's Avatar
Thanks for the feedback guys, if I have time I will be pulling the bones out this evening to get some measurements, I'm pretty sure that is the issue.
The wheels are DE for a DEX410, they are the right size, same size as the wheels on my 22, with the same tires on them.
Diff is not shimmed, and the notch on the gear side just comes into the plastic, while the other side is just a hair farther out. I pulled the diff and flipped it around in the case just to see, and the non-gear side protruded out just a hair more either way. I don't think that's nearly enough to be causing this issue, just enough to make one side more noticeable.
Tektronix, thanks for the tip on the o-rings, I have some TLR x-rings, wonder if they're the same, if not maybe I'll get some Associated ones.
At this point I'm willing to bet I'll find the shafts are longer than 68mm, we'll see.
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 01-13-2015, 02:28 AM   #6399
GregerL's Avatar
Hi again
Checked our car today, using the inserts in the lower middle position, no issue what so ever. This was with 2,5 degrees of camber.
So you have to have an unfortunate QC issue. I can see four possible problem areas.
Diff out drive notches
Drive shaft length
Outer drive shaft
Seating of inner bearing in hub
The AE X-rings you mention, is that the B5 version?
Alexander Landén RC on facebook:
https://www.facebook.com/alexanderlandenRC
GregerL is offline   Reply With Quote
Old 01-13-2015, 03:09 AM   #6400
Losi xrings are for 3.5mm shafts. Xray are 3mm. Get the AE ones
WagwanBumba is offline   Reply With Quote
Old 01-13-2015, 05:48 AM   #6401
Trader Rating: 32 (100%+)
What is the part # ae xrings? Thanks
raved007 is offline   Reply With Quote
Old 01-13-2015, 06:10 AM   #6402
slakr's Avatar
Trader Rating: 28 (100%+)
ASC91493
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 01-13-2015, 12:28 PM   #6403
Graham11's Avatar
Trader Rating: 21 (100%+)
can anyone recommend which exotek rear hexes to use if hoping to use my b44.3 wheels on my xb4 2015? I know i need the 9.5mm for the fronts but which ones for the rear?
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 01-13-2015, 12:32 PM   #6404
slakr's Avatar
I think it would be...
XB4 12MM HEX REAR (2) 7MM WIDE
http://www.exotekracing.com/xb4-12mm...ar-2-7mm-wide/
Old 01-13-2015, 12:41 PM   #6405
rcgod's Avatar
Slakr is correct. I just bought both 7 and 9mm and the 7mm put the width where the stock wheels are.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
