Like Tree45Likes
Old 01-03-2015, 07:26 AM   #6256
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Can someone do a better explanation on the Roll Center with Eccentric Bushings.
I have read the Hudy and Xray setup book guide. The arm mount adjusters (Bushings) still eludes me. I see plenty of description for the upper link with length and mounting height.
Now the 15 has a higher rear mount, instead of the normal one.
MaricopaAgent is offline   Reply With Quote
Old 01-03-2015, 07:39 AM   #6257
jmcelroy42's Avatar
The higher roll center mounts are to compensate for the plastic spacer not being under the rear diff. The mounts keep the arms in the same position as the '14 mounts with the spacer.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 01-03-2015, 07:44 AM   #6258
My xb4 15 should arrive middle of next week. I'm trying to decide if I want to go saddle or shorty. I plan on running the center diff and my local track is indoor dirt/clay medium amounts of traction.
I have seen a few posts that the saddles can be better and kind of smooth things out. But I would prefer to run shorty.
I would appreciate some input.
ATXPro4 is offline   Reply With Quote
Old 01-03-2015, 07:58 AM   #6259
Mounting the pins higher, gives a higher roll center?
Old 01-03-2015, 08:06 AM   #6260
suzukipro's Avatar
Trader Rating: 22 (100%+)
Anyone with a new center diff try and drop it into the 14? I know the Xray site lists it as compatible, but others believe it won't fit without some extra mods. Just looking for a solid answer as I'll likely try to put one in my 14 if it will work for reasonable cost / modifying.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 01-03-2015, 08:28 AM   #6261
Trader Rating: 15 (100%+)
No, mounting the pins higher gives a lower roll centre.
I have read a bunch as well and my head hurt half way through it. I just go with Martin Bayer's bushing set ups. He seems to run fairly consistent set ups for his surfaces. His bushings change very little from clay to clay tracks, and for carpet it's different of course, but again, carpet to carpet, very little changes. I try not to overthink or confuse myself, just set it and drive!
I'm on the fence about updating my '13 which is not really far from being a '14, with the +2 rear suspension hangers. The team guys seem to run the +2's in the same position as the originals anyhow, so,what's the real benefit?
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 01-03-2015, 08:46 AM   #6262
GregerL's Avatar
I know this is confusing but I believe you are incorrect, mounting the pins higher will give a higher RC, but mounting the inside end of the link higher will give a lower RC.
GregerL is offline   Reply With Quote
Old 01-03-2015, 10:07 AM   #6263
Then we agree, as the question being asked is about the inner hinge pins and the eccentric bushings....
Daragh Slowey
Old 01-03-2015, 10:40 AM   #6264
Originally Posted by Qwkrn U View Post
Mine arrived today as well. Got it built,Gonna try it tomorrow, gotta round up some heavy fluids. Gonna try 80k-100k
let me know how 80,000 and 100,000k work for you. because the center diff calls for 1,000,000 carpet and 500,000 for clay. seems like 80k to 100k is way off there range.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 01-03-2015, 08:43 PM   #6265
blwaz23's Avatar
Does anyone run any sort of grease, diff lube, or anything on the steel gears? Or just run them dry?
blwaz23 is offline   Reply With Quote
Old 01-03-2015, 09:16 PM   #6266
Trader Rating: 29 (100%+)
dry in the front a touch of black grease in the rear.
DustinEich is offline   Reply With Quote
Old 01-03-2015, 09:22 PM   #6267
blwaz23's Avatar
I would imagine it helps save the gears? Makes them last longer?
Old 01-03-2015, 09:25 PM   #6268
Trader Rating: 32 (100%+)
I have xray xb4 '15 center differential but i want to sell. Let me know if anyone interested pm me for quick response i will text the picture.
raved007 is offline   Reply With Quote
Old 01-03-2015, 11:20 PM   #6269
rchogfan's Avatar
Pm sent
**CALVIN BRUCE**
MUGEN SEIKI MBX7 ECO - TEKIN GEN 2 RX8 1900T8 | MUGEN SEIKI MBX7 - ALPHA LUTZ WORLDS | B5M CE - TEKIN RSX - 9.5 | 2015 XB4 - R10 PRO - 6.5 |
rchogfan is offline   Reply With Quote
Old 01-04-2015, 01:15 AM   #6270
ronP617's Avatar
who has the center diffs instock, I'd like to try it out..
I tried the shorty pack stock setup, I really like it on a clay track. the rear end seems to be very light and turns on a dime! I have yet to go back to saddles with the 2015, but still experimenting. Does anyone have a good clay setup? saddles or shorty?
ronP617 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
