Like Tree39Likes
Old 01-02-2015, 09:34 AM   #6241
RokleM's Avatar
Trader Rating: 33 (100%+)
Originally Posted by EricW View Post
I'd go a little heavier on the oil in the rear diff and see if that helps. Also, open the diffs and make sure that oil isn't low or leaked out.
Running 5k in the rear, but could bump to 7. Diff is sealed, no issue there.
Originally Posted by Wease View Post
I have a 2015 now, but had a 2014 that I ran on the same exact surface with the exact same problem. I made a ton of various changes trying to add rear-traction and/or take from steering away with no success. The problem is your car is driving from the front and the front end is making soo much grip that the rear can't stay planted and just wants to sling around and follow the front. In the end it turns out that my slipper was waaaaayyyyy to tight. The manual recommends something like 5.5 - 6.3mm spacing between the bearing and spring collar. The manual's recommendation is way to tight for those conditions. In the end, I loosened mine to 6.9mm and the problem went away.
Interesting... I will measure.
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 01-02-2015, 11:13 AM   #6242
Default Center diff oil
Need some help from some team drivers. Just got my center diff a couple days ago and wondering what oil to run. I have seen 1,000,000 to 500,000 weight but that to me seems crazy high. I mea I thought the 100,000 in the d413 was high but this is 5 to 10 times as much. Any help would be great. Just wanted to make sure it wasn't a misprint
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 01-02-2015, 11:23 AM   #6243
EricW's Avatar
The 2015 comes with 8k for both front and rear in the kit, my son just built his and that's what it came with.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 01-02-2015, 03:11 PM   #6244
Qwkrn U's Avatar
Trader Rating: 128 (100%+)
Originally Posted by blwaz23 View Post
Any reason why you're not running the rear top deck? Affect the handling without the rear deck?
No rear upper deck allows rear to flex more, creating more rear traction. Run on dirt clay mix, medium - high traction so the extra rear traction helps. On carpet the rear deck may be worth running.
Wayne Robison
B5m , X-ray XB4 '15 ,xb8e, Scte 2.0
Tiny Boat Guy Paint Designs, Checkered Flag Hobbies, creativecustomtees.com
Qwkrn U is offline   Reply With Quote
Old 01-02-2015, 03:15 PM   #6245
Trader Rating: 32 (100%+)
Got center differential today from LHS can't wait to test tomorrow.
raved007 is offline   Reply With Quote
Old 01-02-2015, 03:20 PM   #6246
Qwkrn U's Avatar
Mine arrived today as well. Got it built,Gonna try it tomorrow, gotta round up some heavy fluids. Gonna try 80k-100k
Wayne Robison
Old 01-02-2015, 04:08 PM   #6247
Let me know how would you like. I'm gonna try F/C/R 8K/8K/3K and my sct410 Tekno 10k/10/3K im happy and easy to drive for me.
Old 01-02-2015, 05:57 PM   #6248
Trader Rating: 15 (100%+)
Looking for a little advice as I'm new to the car. This is a 2014. I have some ideas based on normal changes I would make with other vehicles, but figured I would see how those compare to your experience.
Racing on an indoor track with soft slicks, very high grip and fluff only off the groove. My rear has a tendency to come around a bit on power in the corners vs staying planted. Other than that, it feels pretty good.
Running the 2014 clay setup sheet:
http://www.teamxray.com/xb4/2014/dow...sheet_clay.pdf
Here's another thought. Remove your rear sway bar. I was having the same issue and then a buddy told me to take the rear sway bar off - instantly better. The sway bar was lifting the inside wheel, as it's supposed to do, the front end had a ton of grip and the rear was simply trying to keep up and washing out in corners. You'll notice the basic clay set up on the 2015 has no sway bars on it. Try it.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 01-02-2015, 07:12 PM   #6249
Originally Posted by HeavyD99 View Post
What would be the weight of that piece of tungsten? Neat layout.
I believe it's 8 grams.
discodom is offline   Reply With Quote
Old 01-02-2015, 07:47 PM   #6250
the diff in the 1/10 scale buggy are way smaller than in sct410 you are going to need heavier in center than 8k or you will probably be wearing out tires
evolution03 is offline   Reply With Quote
Old 01-02-2015, 08:37 PM   #6251
blwaz23's Avatar
Anyone know where Martin Bayer got the blue bling?
blwaz23 is offline   Reply With Quote
Old 01-02-2015, 09:43 PM   #6252
TPR 1's Avatar
Trader Rating: 26 (100%+)
Any feedback with centre diff on the track?
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 01-03-2015, 12:35 AM   #6253
Hiro Seiko do a full range of bling parts in quite a few colours.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 01-03-2015, 02:04 AM   #6254
rchogfan's Avatar
Anyone know when the center diff will be available at amain? I'm seeing people already getting them at their LHS but I don't have one. Thanks.
**CALVIN BRUCE**
MUGEN SEIKI MBX7 ECO - TEKIN GEN 2 RX8 1900T8 | MUGEN SEIKI MBX7 - ALPHA LUTZ WORLDS | B5M CE - TEKIN RSX - 9.5 | 2015 XB4 - R10 PRO - 6.5 |
rchogfan is offline   Reply With Quote
Old 01-03-2015, 04:05 AM   #6255
Qwkrn U's Avatar
Stormerhobbies has em in thier system already.
http://www.stormerhobbies.com/cgi-bi...s&pn=XRA364901
Wayne Robison
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
