Like Tree39Likes
Old 01-01-2015, 11:34 AM   #6226
Trader Rating: 23 (100%+)
Where are the U.S. Guys ordering parts? My local hobby shop isn't a RCA dealer so no xray parts. I order my onroad xray parts from tq but they have no offroad parts.
kwb0748 is offline   Reply With Quote
Old 01-01-2015, 11:50 AM   #6227
Default Electronics lay out
This layout with the piece of tungsten next to the receiver gives me 50/50 left to right, front to rear. Going to run it for the 1st time Sunday. Can't wait.
discodom is offline   Reply With Quote
Old 01-01-2015, 12:12 PM   #6228
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Amain is where I get mine.
MaricopaAgent is offline   Reply With Quote
Old 01-01-2015, 12:35 PM   #6229
Qwkrn U's Avatar
Trader Rating: 128 (100%+)
Stormer hobbies and Amain has most everyone need
Wayne Robison
B5m , X-ray XB4 '15 ,xb8e, Scte 2.0
Tiny Boat Guy Paint Designs, Checkered Flag Hobbies, creativecustomtees.com
Qwkrn U is offline   Reply With Quote
Old 01-01-2015, 05:07 PM   #6230
blwaz23's Avatar
Originally Posted by Qwkrn U View Post
Any reason why you're not running the rear top deck? Affect the handling without the rear deck?
blwaz23 is offline   Reply With Quote
Old 01-01-2015, 05:56 PM   #6231
rchogfan's Avatar
Wow. First time I've seen that layout. Looks like I will be re-soldering my electronics before I hit the track again. Thanks.
**CALVIN BRUCE**
MUGEN SEIKI MBX7 ECO - TEKIN GEN 2 RX8 1900T8 | MUGEN SEIKI MBX7 - ALPHA LUTZ WORLDS | B5M CE - TEKIN RSX - 9.5 | 2015 XB4 - R10 PRO - 6.5 |
rchogfan is offline   Reply With Quote
Old 01-01-2015, 06:23 PM   #6232
Smile
Wanted the weight to the rear, plus makes a clean wire job too me. Thanks
Old 01-01-2015, 07:00 PM   #6233
blwaz23's Avatar
Does more dots on the Xray springs mean stiffer springs? Less dots mean softer springs?
Old 01-01-2015, 07:06 PM   #6234
001casey's Avatar
Trader Rating: 31 (100%+)
Yes more dots = stiffer
Game on
Casey Troncone - Adelaide Rc
001casey is offline   Reply With Quote
Old 01-02-2015, 04:43 AM   #6235
advpball's Avatar
i switched to the progressive springs with the build handled great except i had hub carriers on wrong side, massive toe out on compression also that killed my 6070 lp servo!! 20 for gears sucks!!! upgraded to 6040
xray xb2 de and xsc2,eb410
eb 48.3 for sale artr 500
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is online now   Reply With Quote
Old 01-02-2015, 07:34 AM   #6236
Trader Rating: 15 (100%+)
What would be the weight of that piece of tungsten? Neat layout.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 01-02-2015, 08:24 AM   #6237
Also, to be filed under OCD, the weight of the new metal bevel gear, is 11.15g, which includes the plastic bushing insert. The composite plastic gear weighed 4.15g.
The metal pinion gear weighs 7.80g.
I'll post the weight of the composite pinion once I pull it out later, and the weight of the new diff completed with NT1 gears installed.
Daragh Slowey
Old 01-02-2015, 08:53 AM   #6238
RokleM's Avatar
Trader Rating: 33 (100%+)
Looking for a little advice as I'm new to the car. This is a 2014. I have some ideas based on normal changes I would make with other vehicles, but figured I would see how those compare to your experience.
Racing on an indoor track with soft slicks, very high grip and fluff only off the groove. My rear has a tendency to come around a bit on power in the corners vs staying planted. Other than that, it feels pretty good.
Running the 2014 clay setup sheet:
http://www.teamxray.com/xb4/2014/dow...sheet_clay.pdf
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 01-02-2015, 09:03 AM   #6239
EricW's Avatar
I'd go a little heavier on the oil in the rear diff and see if that helps. Also, open the diffs and make sure that oil isn't low or leaked out.
I went with lighter oil in the diffs when we went outside in the summer, when we came back inside the car was really twitchy so I went back to the 10k/5k setup and it settled down a lot. I'm also running the 6 hole 1mm pistons in my shocks with 35wt oil. Car is planted really well right now.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 01-02-2015, 09:07 AM   #6240
Trader Rating: 75 (100%+)
I have a 2015 now, but had a 2014 that I ran on the same exact surface with the exact same problem. I made a ton of various changes trying to add rear-traction and/or take from steering away with no success. The problem is your car is driving from the front and the front end is making soo much grip that the rear can't stay planted and just wants to sling around and follow the front. In the end it turns out that my slipper was waaaaayyyyy to tight. The manual recommends something like 5.5 - 6.3mm spacing between the bearing and spring collar. The manual's recommendation is way to tight for those conditions. In the end, I loosened mine to 6.9mm and the problem went away.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
