Like Tree36Likes
Old 12-31-2014, 12:11 PM   #6211
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Originally Posted by ProfessorX View Post
Anyone
I don't weigh mine.. fill to top of cross brace and go.
If you add to much, the fluid will come out of the screw holes during assembly.
MaricopaAgent is offline   Reply With Quote
Old 12-31-2014, 12:42 PM   #6212
Qwkrn U's Avatar
Trader Rating: 128 (100%+)
Lightbulb
Originally Posted by MaricopaAgent View Post
I am trying 20k front and 10k rear fluid right now.. Seems damn good. Need to play with the rear mounts some.
What handling differences did you notice, I'm gonna play with fluids this weekend
Wayne Robison
B5m , X-ray XB4 '15 ,xb8e, Scte 2.0
Tiny Boat Guy Paint Designs, Checkered Flag Hobbies, creativecustomtees.com
Qwkrn U is offline   Reply With Quote
Old 12-31-2014, 12:55 PM   #6213
Anyone
Put some fluid in the bottom of diff drop first set of gears in then spin them put some more fluid in then second set of gears fill the diff to top. Take the sun gear put it in then take a hex driver and scrape the excess oil off the top should put fluid level. Line the sun gear up so when you install ring gear holes will be lined up. Oh yeah don't forget to put light coating of oil on diff gasket. This way you have same amount of oil every time
evolution03 is offline   Reply With Quote
Old 12-31-2014, 01:06 PM   #6214
We are on Med Bite indoor tight track.. Steering and push seem better in and out of the corners. I also went to a 3 dot rear sway bar and run the rear arms adjusters on the low side. I will be trying the regular hangers instead of the +2 this weekend.
Old 12-31-2014, 01:49 PM   #6215
Qwkrn U's Avatar
On my 14 car 5-7 front and 3k rear fluids worked best at our track. The 15 seems more nimble so thinking the heavier fluids may calm it a bit. So gonna try the 20 front 10 rear
Wayne Robison
Old 12-31-2014, 04:52 PM   #6216
Trader Rating: 32 (100%+)
I am running 8K front/ 3K rear traction has great and running motor 6.0T
raved007 is offline   Reply With Quote
Old 12-31-2014, 08:52 PM   #6217
blwaz23's Avatar
Just purchased and build my XB4 2015. Can someone post a picture of how they setup their electronics for the shorty conversion?
blwaz23 is offline   Reply With Quote
Old 12-31-2014, 09:16 PM   #6218
Qwkrn U's Avatar
Wayne Robison
Old 12-31-2014, 09:38 PM   #6219
Old 12-31-2014, 09:46 PM   #6220
This is my first electronic layout but when i bought skyrc scale found out un-balance so i change my electronics configuration but now my new configuration electronics both side equal 50%.
Old 12-31-2014, 10:10 PM   #6221
spu83's Avatar
Pak Lee
XB8E, XB4'15, 410.3, T4'16, XB2de, X1'16, XT2de
spu83 is offline   Reply With Quote
Old 01-01-2015, 06:18 AM   #6222
Originally Posted by spu83 View Post
Looking good, but that positive wire looks like it can have some interesting meetups with the spur. I tried that once in a '14, didnt work out so well .
Nyegaard is offline   Reply With Quote
Old 01-01-2015, 08:29 AM   #6223
blwaz23's Avatar
They don't give you alot of room lol
Old 01-01-2015, 09:32 AM   #6224
blwaz23's Avatar
Originally Posted by raved007 View Post
Bling Bling
Old 01-01-2015, 09:53 AM   #6225
suby723's Avatar
Trader Rating: 21 (100%+)
Just pulled the trigger and ordered a 15 from amain. I'm really looking forward to building the car. The 44.3 wasn't working for me and went up on the chopping block after a month of headaches trying to get it right for me.
suby723 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
