Like Tree45Likes
Old 12-23-2014, 05:50 AM   #6151
Trader Rating: 15 (100%+)
... Does the centre diff include any diff oil?
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 12-23-2014, 07:51 AM   #6152
None included.
sime46 is offline   Reply With Quote
Old 12-23-2014, 08:19 AM   #6153
slakr's Avatar
Trader Rating: 28 (100%+)
What is the part number for the center diff?
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is online now   Reply With Quote
Old 12-23-2014, 11:12 AM   #6154
slakr's Avatar
Gear Center Differential - Set #364901
Old 12-23-2014, 11:15 AM   #6155
RokleM's Avatar
Trader Rating: 33 (100%+)
Fits
XRAY XB4
XRAY XB4 2014 Specs
XRAY XB4 2WD
XRAY XB4 2015 Specs
I thought someone tested and determined it wouldn't be possible in a 2014???
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 12-23-2014, 11:19 AM   #6156
jmcelroy42's Avatar
Originally Posted by RokleM View Post
Fits
XRAY XB4
XRAY XB4 2014 Specs
XRAY XB4 2WD
XRAY XB4 2015 Specs
I agree, I thought the bearing supports are too close together and would have to drill new holes for the motor mount to make it fit? as well as different driveshafts and upper brace.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 12-23-2014, 11:24 AM   #6157
RokleM's Avatar
That's what I was thinking I read too...
Off of the main part page, click specs and states it fits:
http://www.teamxray.com/teamxray/pro...20Differential
- Eric G. -
Old 12-23-2014, 11:38 AM   #6158
jmcelroy42's Avatar
Also says it fits 2wd, witch makes absolutely no sense.
Old 12-23-2014, 12:44 PM   #6159
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Released: Dec. 22, 2014
MaricopaAgent is offline   Reply With Quote
Old 12-23-2014, 04:21 PM   #6160
prosport's Avatar
Trader Rating: 21 (100%+)
Hi, I bought a used 2013 XB4 , when it grabs traction it pops and bangs so loud it sounds like the transmissions are gonna break. What would cause this?
I'm running a Tekin 8.5t motor and a Speed Passion GT2.0Pro ESC with a new sensor wire.
prosport is offline   Reply With Quote
Old 12-23-2014, 04:54 PM   #6161
jmackani's Avatar
Trader Rating: 14 (100%+)
Rear ring and pinion is probably gone.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 12-23-2014, 05:18 PM   #6162
Yup.. check front and rear ring and pinions.. There is probably a few teeth missing..
If not, check and the screws to be tight.. Center motor mount not loose,motor loose, center slipper bearings good, drive axles not hitting outdrives..Basically anything that moves, via drivetrain.
Old 12-23-2014, 06:11 PM   #6163
suzukipro's Avatar
Trader Rating: 22 (100%+)
Sounds like one of the diffs composite ring and or pinion gears are bad, with the likely cause being your slipper is set too tight. There are steel and aluminum options available now since the 2015 kit was released to replace the stock components. If the internal diff gears are bad the NT1 steel gears are also a popular option to replace the composite ones.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 12-23-2014, 06:27 PM   #6164
prosport's Avatar
Thanks for the fast answers guys.
Old 12-26-2014, 07:21 AM   #6165
Hi there,
I am waiting for my Xb4 at the moment and was wondering what spare parts I should have with me on track? I will drive mosly outside on a dirt track.
I am quite busy in my life with family and stuff so when Im at the track I really want to drive if you understand.
I would also really want to know if there are any option parts that I really need to buy?
Its a Xb4 2014 that I am have bought.
Thank you and happy new year from Sweden.
MickeCTR is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
