Like Tree45Likes
Old 12-16-2014, 03:30 PM   #6076
advpball's Avatar
Trader Rating: 28 (100%+)
quick question i got my 2015 together and noticed when i push down on front end
the tires toe-out a lot .Is that normal I don't remember that on my 2013? or never noticed.
xray xb2 de
Johnny 5 designs xsc2
Tekno eb410
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 12-16-2014, 04:29 PM   #6077
Hi, just picked up a 2015 XB4 and started the build. Its my first time with a 1/10th electric.
Just wanted to know from the people here who are more experienced whether there is a handling and performance difference between the Saddle Pack setup or the Shorty pack setup. Does it change the handling of the car in anyway. I do have Shorty Packs so i was thinking of doing that setup, but i need a car that can handle more of a loose (low bite) track that we have here locally.
Thanks for any info or advice anyone can give.
chamber is offline   Reply With Quote
Old 12-16-2014, 10:57 PM   #6078
Thanks Maricopa i will try those changes tomorrow and let you know if they worked for me. Randy - i have a 14' and AMS is where it drove poorly and the track was amazing. The setup change i spoke of was different springs, sway bars and pills...which cost more than i imagined. Any Michiganders have tire suggestions for Ams and Clubhouse? I'm currently running suburbs in rear and ions up front both super soft. I heard tendroids were the go to for Clubhouse.
g-one is offline   Reply With Quote
Old 12-17-2014, 05:41 AM   #6079
yeah at AMS Ions will work if its a new track layout or if the track in moist or wet. as for normally I run Panters Rattlers 2.0 with Bobcats upfront.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 12-17-2014, 06:13 AM   #6080
GSMike's Avatar
I have a '14 XB4 and I love it. It is completely dialed and I have 100% confidence in it. However, I was looking at the 2wd buggy and I've had a couple of Xray drivers say it's really designed for astroturf, carpet, high grip tracks and wouldn't do well at the track where I race (hard pack moist clay). So my question(s) are, if the 2wd and 4wd share so many of the same parts and seem to be built the same, why wouldn't the 2wd do just as well? The next question is if the 2wd will not do well, what about it makes such a huge difference? I really like that the platforms are so compatible but I don't want a 2wd that is not gong to be competitive.
Thanks all.
DIALED-RC HOBBIES
CLOCKWORK RACING ENGINES
GSMike is offline   Reply With Quote
Old 12-17-2014, 07:21 AM   #6081
dMITIj's Avatar
Thanks all.
I think there is a new 2wd on the way from XRAY if you read the news at XRAY you can see that mr. Hudy and Bayer is driving a new 2wd
dMITIj is offline   Reply With Quote
Old 12-17-2014, 07:38 AM   #6082
Trader Rating: 20 (100%+)
My '13 has always done this as well, no worries.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is online now   Reply With Quote
Old 12-17-2014, 07:39 AM   #6083
jmcelroy42's Avatar
Thanks all.
I believe its because the weight bias is so far forward, there isn't enough weight over the rear tyres to get traction. Even their team drivers who are running on carpet are modding their chassis to run a shorty and put the motor in the rear to shift more weight back.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is online now   Reply With Quote
Old 12-17-2014, 09:06 AM   #6084
hellfire's Avatar
Trader Rating: 87 (100%+)
??? What shorty pack are u guys running that fit nice in the 2015? And do the rims from the 13 fit the 2015? Thanks!
~ Scott McTaggart ~ *In Memory Of Shaun Neary*
~ GotNitroOnline.com ~ The home of Radical 621T motors Thanks Dave ~
~MnNitroSeries.com ~ Lucky 13 Speedway ~
hellfire is offline   Reply With Quote
Old 12-17-2014, 10:27 AM   #6085
Trader Rating: 75 (100%+)
I'm using a few different shorty packs. I have an SMC 4400 Mah 60C, a Turnigy NanoTech A-Spec 4200 Mah 65c, and a TrakPower 4600 Mah 80c.
The rims are all the same for the 2013, 2013v2, 2014 and 2015 spec cars, so yes you can use the 13 wheels on the 15 car.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 12-17-2014, 11:44 AM   #6086
All rims fit but the v2 fronts supplied with the 2014&2015 cars are different. Front offset is +1mm. They'll all fit but don't mix them up.
sime46 is offline   Reply With Quote
Old 12-17-2014, 11:54 AM   #6087
hellfire's Avatar
Thanks guys. My son and I both have 13' got a 15' coming.
Old 12-17-2014, 12:49 PM   #6088
rchogfan's Avatar
Got me a 15 kit coming. Pretty stoked about it. Any pointers for the build process? I'll be putting AE fluid in it so I know what I'm dealing with. What's the stock fluid setup? Thanks in advance.
**CALVIN BRUCE**
MUGEN SEIKI MBX7 ECO - TEKIN GEN 2 RX8 1900T8 | MUGEN SEIKI MBX7 - ALPHA LUTZ WORLDS | B5M CE - TEKIN RSX - 9.5 | 2015 XB4 - R10 PRO - 6.5 |
rchogfan is offline   Reply With Quote
Old 12-17-2014, 12:51 PM   #6089
rchogfan's Avatar
Thanks all.
It is a combination of weight placement too far forward and not having the front wheels to pull the car for the rear end to follow.
**CALVIN BRUCE**
Old 12-17-2014, 04:29 PM   #6090
Trader Rating: 24 (100%+)
I noticed the 2015 has 3 dot springs now F&R, need suggestion on shock fluid using avid 2+2 pistons, shorty config, running on smooth moist clay, med-high bite, thank you
blacktop20valve is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
jmcelroy42, MrLean
