Like Tree52Likes
Old 12-03-2014, 08:01 PM   #5971
spu83's Avatar
If anybody go for shorty configuration be careful. Big mistake on page 40. (Page 8/Step 1) call for drive shaft 85mm supposed to be 95mm instead and (Page 10/Step 1) call for drive shaft 95mm supposed to be 85mm.
Pak Lee
XB8E, XB4'15, 410.3, T4'16, XB2de, X1'16, XT2de
spu83 is offline   Reply With Quote
Old 12-03-2014, 08:26 PM   #5972
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Boz View Post
I just received a reply back from Xray. I questioned them on the clay setup sheet. It says not to use the front or rear upper plate (so does the carpet setup sheet). They said the setup sheet is correct and it is not necessary to use the upper decks.
Interesting, plus the front body post is screwed to the front upper plate.
I know a lot of us donít have our kits yet, but would you consider using the XB4í15 without the upper decks???
No front deck on a 14 and you will pull out a center drive shaft and smash the body with the front bulk head.. If you drive as well as I do.
MaricopaAgent is offline   Reply With Quote
Old 12-03-2014, 08:36 PM   #5973
Boz
Trader Rating: 23 (100%+)
FYI
This error has been amended in the downloadable instructions found on Xray's website.
Poor person in the factory who's job it will be to put stickers over this mistake.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 12-03-2014, 08:43 PM   #5974
Boz
So I take that as a 'No' from you then.
Their was more in the reply I received. They did say, if you are using the chassis brace front and rear it will be ok. If our track had smaller jumps, I would probably try it.
Chris Bozich
Xray XB8 XB4 XB2
Old 12-03-2014, 11:19 PM   #5975
Qwkrn U's Avatar
Trader Rating: 128 (100%+)
Got mine today and made it about 70% of the way thru the build. I'll have to recheck the drive shaft lengths as I'm setting it with a shorty. Easy fix.
Bag 1 wasn't sealed in the box and a few of he install pins for the diff build were missing. Be careful when you open the box.
Hoping to get the rest finished tomorrow after work, if I get some free Time.
I couldn't see not using the at least the front upper brace. Chassis has more flex to it than older generation.
Wayne Robison
B5m , X-ray XB4 '15 ,xb8e, Scte 2.0
Tiny Boat Guy Paint Designs, Checkered Flag Hobbies, creativecustomtees.com
Qwkrn U is offline   Reply With Quote
Old 12-04-2014, 08:25 AM   #5976
Dan Reino's Avatar
Been running my '15, small indoor clay track(Thunder in Nashville). Running shorty setup w/7.5 motor. Car is longer, lighter, more nimble, and I think it will prove to be even more durable. I'm only running the Front Top Deck(not rear. really helps it grip coming out of the corners. Relativley stock setup and I'm VERY happy!!!!!
Serpent America/Desoto Racing.-Sweepracingusa.com.-Reino's Ragu & Magic Marinade Tire Sauce.-RCAmerica/XRAY.-Wildflower rc raceway.-Thunder RC
Dan Reino is offline   Reply With Quote
Old 12-04-2014, 10:07 AM   #5977
I posted on the xray forum and I was told it was a mistake that we absolutely need to run the front top deck
Posts:*19
There was a mistake in the basic set-up sheet saying to not run either of top decks. However, this mistake has been corrected as you have to run at least the front top deck, where also the body holder is attached. Not runing the rear top deck gives you more flex.
lonslo is offline   Reply With Quote
Old 12-04-2014, 04:26 PM   #5978
nerdling's Avatar
I've been running my '13 with out a front deck at my local track, med to low grip, large jumps and the car was fantastic. I did have to cut up a front deck to fabricate a plate to secure the lay shaft and a front body mount. No problems with the front drive shaft.
nerdling is offline   Reply With Quote
Old 12-04-2014, 04:57 PM   #5979
advpball's Avatar
Trader Rating: 28 (100%+)
Anyone running the jc 12mm aluminum hubs? which rims do they fit.b44 or kyosho?
thanks
xray xb2 de
Johnny 5 designs xsc2
Tekno eb410
all powered by smc battery's and Motiv motors
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 12-04-2014, 05:04 PM   #5980
spu83's Avatar
thanks
Kyosho is 12mm
Pak Lee
Old 12-04-2014, 07:12 PM   #5981
I tried the jc hexes and my b5 rims were bound up when I tightened them the exotek ones work great
Old 12-04-2014, 07:15 PM   #5982
Qwkrn U's Avatar
The mm size was wrong, but the short vs long was right in the wording. so yea just watch as you build. Longer one goes in the rear. That was the only hiccup throughout the build process aside from a missing diff pin. Mine is almost ready for the track Saturday.
Wayne Robison
Old 12-04-2014, 09:35 PM   #5983
My diff bag wasn't sealed either half that bag was spilled all over inside the box. I haven't started building I hope I'm not missing anything.
evolution03 is offline   Reply With Quote
Old 12-04-2014, 10:33 PM   #5984
Qwkrn U's Avatar
Just be sure and unfold the inside of the box carefully. I found all my missing pieces. After I was done with the build. I had spares for the diff pins already, so I didnt let it slow my build.
Wayne Robison
Old 12-05-2014, 08:26 AM   #5985
Mine should be here today! Going to try an put it together for Sundays race!
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
