Like Tree52Likes
Old 11-15-2014, 10:40 PM   #5851
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Say what you want . They made metal gears for a reason!!!!
And updated the outdrives fan boys
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 11-16-2014, 12:16 AM   #5852
gavaust's Avatar
Trader Rating: 22 (100%+)
Default What size pinion to run in 17.5
Hi guys new to the electric side of racing and I plan to run stock 17.5 my xb4 has the 81 Spur so what size pinion should I be using cheers
Xray xb4 2016
Proamps servo & shortys
Dualsky motor
Hobbywing xr10 pro
Awesomatix a800x
gavaust is offline   Reply With Quote
Old 11-16-2014, 12:45 AM   #5853
locked's Avatar
Originally Posted by HeavyD99 View Post
All the photos show the '15 with a low profile servo - anyone know which one? I think most low profile servos only has 125oz...
Hey D. I had a Savox 1251 in my xb4 all last year. It was fine, but I plan to put an Xpert low profile servo in my next xb4. Been running them in my touring cars(PM-3401 and PI-3401-B) and I'm really happy with them so far. Great specs for torque and speed, precise and reasonably priced too. Definitely worth checking out.
The ones in most of the press release pictures look like futaba or older ko propo servos.
Regarding the bevel gears discussion.. It took me quite a while to destroy any of the plastic gears, but then I went through a couple of sets of them. Though I agree that with a properly set slipper, it shouldn't be an issue, they can still strip a bit too easily. I'm glad they went with metal gears now. I'm sure I'll feel more confident in the car's ability to hold up to my abuse. The new car looks sweet! Can't wait to get one.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 11-16-2014, 05:53 AM   #5854
Most likely to shut up the whiners.
Welcome to my ignore list. Have a nice day
"If you have complete control over the damned thing, you're not going fast enough."
kaan is offline   Reply With Quote
Old 11-16-2014, 07:16 AM   #5855
There is a minor error in the manual on page 40 when you are building for shorty battery.
The rear/front driveshaft have the "mm" text reversed.
It should be 95mm rear and 85mm front.
Regarding setup sheet.
I like to start with building the car according to the setup sheets provided by Xray for a start.
A confusing thing is that the setup sheet specifies the following.
Front top deck - Standard / No
Rear top deck - Standard / No
In both Carpet and Clay setup sheets it specifies "No" on both Front and rear.
But i dont understand how you can build it without using the front topdock.
The body post is attached to the front deck.
I will build it with the front topdeck anyway, but still confusing.
Bonanza73 is offline   Reply With Quote
Old 11-16-2014, 07:45 AM   #5856
My '15 so far. Using old dampers from the '14, couldn't be bothered to do the new dampers now as these are literally 2 batteries old since last rebuild. Will buy some new xray alu shock caps and do a proper install of the new ones a bit later though.
Using ORCA 13 AWG to motor and 12 awg to the batteries. This was done like this to avoid the running gears with all cables, when I'm done it should be quite impossible to actually get a cable to touch any running gears.
Nyegaard is offline   Reply With Quote
Old 11-16-2014, 12:02 PM   #5857
suzukipro's Avatar
Trader Rating: 23 (100%+)
Haha found a site that will ship ring n pinion and the insert . Hope i dont need new diff housings though. 209 for me n my bud so 4 of each part
Ring gear 364955
Pinion 365134
Insert 364990
Any chance you'll disclose the name of this site? I'd like to purchase these same parts for my 14 Xb4 - I'm also considering buying the center diff to see if I can make it work on the 14 car with the saddle layout???
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 11-16-2014, 12:10 PM   #5858
RokleM's Avatar
Trader Rating: 33 (100%+)
Looking forward to an official or unofficial (i.e. mod) way to do this.
I just picked a used toy.
- Eric G. -
Tekno EB48.4, NB48.4, ET48.3, NT48.3, EB410
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 11-16-2014, 03:26 PM   #5859
BDRMBULLY's Avatar
Ill PM it to yea seeing everyone else is a PRO at setting their slippers.
Hand D Flooring
Old 11-16-2014, 05:57 PM   #5860
Such an attitude deserves a spot on my ignore list.
Old 11-16-2014, 06:13 PM   #5861
Boz
Maybe we need a Pro thread.
First invitation we be going out to Bent.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 11-16-2014, 08:12 PM   #5862
BDRMBULLY's Avatar
Ive set my slipper 10 diff times losened it way off. Still blew front diff gears and rear diff gears , and im sure alot of other racers that dont get out weekly have as well . Go ahead and put me on your ignore list i could care less. Do me a favour. I run mostly in my buds back yard track with a timing system and drink beer. With metal gears means more run time and more beer . So all you wanna be pro slipper adjusters can have your composite gears and dnf for all i care.i just wanna have fun n run my car.
Hand D Flooring
Old 11-16-2014, 08:39 PM   #5863
Boz
BDRMBULLY,
Are you using the '13 bulkhead, the V2 bulkhead or the '14 bulkhead?
Chris Bozich
Xray XB8 XB4 XB2
Old 11-16-2014, 08:51 PM   #5864
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
pm me too please!
MaricopaAgent is offline   Reply With Quote
Old 11-16-2014, 09:21 PM   #5865
BDRMBULLY's Avatar
Will do pal. Done deal just a heads up the shipping aint cheap
Boz
V2's then what ever amain shipped me when my front one broke
Hand D Flooring
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
