Like Tree52Likes
Old 11-09-2014, 09:26 PM   #5791
joeymdz's Avatar
Send a message via MSN to joeymdz
Originally Posted by EricW View Post
Tyler Vik says he adjusts his slipper on his XB4 the same way people do it on a 2wd vehicle, hold the read wheels and blip the throttle. It's posted somewhere on here.
I do the same on the bench but then I fine tune it on the track surface
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 11-12-2014, 01:03 AM   #5792
Originally Posted by randy0025 View Post
just wondering when the xb4 2015 edition will be out. anyone know? Anyone, ANyOne, come on anyone out there know, ANYONE ???
just saying xray. you released a teaser weeks upon weeks ago. im not asking you to release the damm kit tomorrow, but give us the specs and atleast a release date.
anyways that's my rant. hopefully someone at xray understands that staying in contact with your customer's is key in this hobby
Friday
ColourGhost is offline   Reply With Quote
Old 11-12-2014, 01:20 AM   #5793
Peakki's Avatar
Originally Posted by suzukipro View Post
Anyone have any experience with the Dhawk carbon chassis? Thinking about buying one, but not sure if there is an advantage (more flex) to be gained other than less weight and $$ in my pocket...
My friend bought it and used it for a while. Either his chassis was a bad monday version or the hawk CF chassis isn't a good idea for this car.
His car was anyway terrible and inconstant to drive with the chassis...
Destiny&V-Dezign 1:12- Sanwa M12s - Xray XB4 2016 - Xray XB2 DE - HW XR10Pro & Team Orion R10.1 Pro & Sanwa Super Vortex Zero Gen2- Team Orion Vortex & Muchmore & Reedy BL motors - Sanwa & Highest & Sav÷x servos
Peakki is offline   Reply With Quote
Old 11-12-2014, 01:27 AM   #5794
Peakki's Avatar
Originally Posted by Wease View Post
It turns out it was my slipper being too tight! I tried every combination of springs, sway bars, diff fluids, camber links, shock positions, etc., and nothing would stop the twitchiness and grabiness of the front end. I was watching the AE guys with their new B44.3 cars change the suggested 100K center diff fluid out for 60K all day at our track. So I thought, why don't I try loosening my slipper. The manual says the distance between the shoulder and the spring collar should be between 5.0 - 6.3mm and I had mine at 5.2mm. I never could hear my buggy slip so what did I have to lose. Each round I loosened the slipper and each round the buggy got easier to drive. Right before the main my slipper was at 6.39 mm and I loosened it to 6.59mm. That might have been just on the loose side, but the buggy was pretty hooked up front and rear and that was on a dusty track. The only reason I thought it might have been a little loose was because I had trouble clearing this triple right after a hard 180 with no run at the jump lip.
So it seems the problem was that with each punch of the throttle, full power was going to both the front and rear of the car with most of the power going to the front yet still diffing out the rear of the car.
As you can see, my car's ideal slipper setting was outside the range specified by the manual. Could this be the reason some guys are roaching their diff gears even though they have their slipper setting within the range specified by the manual? For me anyway, the manual suggestion was too tight for my high traction track.
That manual info is wrong. For 2013/2014 model: approx. 5.7~6.3mm. Anyway it always should slip, regardless of the surface. See:
XB4 Instruction Manual Supplementary Sheet http://www.teamxray.com/teamxray/pro...ame=XRAY%20XB4
2014 models SLS pads are way better than 2013 pads...
I find it also true, that thicker rear diff fluid helps the car during acceleration and out of the corners. Shame that diff fluid ratings are so much different between different brands. I'm using Ultimate Racing diff fluids, which are lighter than AE for example. So usually 10K in front and 5k or 7k in rear...
Old 11-12-2014, 10:02 AM   #5795
suzukipro's Avatar
Trader Rating: 23 (100%+)
Originally Posted by ColourGhost View Post
Friday
I sure hope your right and that the metal ring and pinion gears will also be out then too!
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 11-13-2014, 07:48 AM   #5796
rraden's Avatar
Trader Rating: 233 (100%+)
Looks like their web page confirmed the Friday specification release!!
Xray XB8E 2016 | Xray XB4 2017 | Xray XB2 DE 2017 | Xray XB8 2017
Dirt Burners - Livonia, Mi
The Track - Carleton, MI
rraden is offline   Reply With Quote
Old 11-13-2014, 08:02 AM   #5797
EricW's Avatar
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 11-13-2014, 08:47 AM   #5798
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
So...Shorty or no shorty
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-13-2014, 11:12 AM   #5799
EricW's Avatar
Tune is tomorrow, same bat time same bat channel.
**** "Luxury" ****
Old 11-13-2014, 12:47 PM   #5800
Trader Rating: 15 (100%+)
With a centre diff, you won't need those metal gears...
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 11-13-2014, 03:33 PM   #5801
suzukipro's Avatar
If they are available, I'll use them regardless for the peace of mind.
Eric
Old 11-13-2014, 07:25 PM   #5802
Default XB4 Update tomorrow? 2WD?
I saw that the XB4'15 information will be out tomorrow. I wonder if they will announce a new 2WD buggy also, or if this will be a separate announcement. I might consider an updated 2WD XRay if it was well suited to my US indoor dirt (medium-traction?) conditions.
If they don't release something interesting, I might go with the Kyosho RB6 for mod class. Currently running TA B5R for stock. I'll probably stick with it for stock, and add a mid-motor for mod class.
MasterBlaster is offline   Reply With Quote
Old 11-13-2014, 08:12 PM   #5803
Boz
I don't think they will be. From pictures taken at the EOS the Xray 2wd has a completely new front end and the rear looked like it had a traditional mid mount motor setup.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 11-14-2014, 03:07 AM   #5804
moot's Avatar
What gearing to I need for a 13.5t? I need to tame the car.the 6.5 is to much for our track
moot is offline   Reply With Quote
Old 11-14-2014, 08:14 AM   #5805
You have the shorty option yes.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
