Like Tree44Likes
Old 10-21-2014, 05:09 AM   #5731
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Either way theyre prone to breaking . I had a scte for 4 years one never broke . Had it slammed for carpet to boot
they are thin and 2 broke at the same point in my car
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 10-21-2014, 09:41 AM   #5732
Originally Posted by suzukipro View Post
I initially had the same issues you described running on a indoor low to med bite hard packed dirt with a 6.5 motor. What helped me the most was setting the slipper right for my track conditions and reducing current limit (no timing or boost), I'd also try the Tyler Vic setup posted a page or two back and work from there. After improving my setup I now am glad I went with a 6.5 and like knowing there is something in reserve if the track or my skill require it.
So stick with the 6.5 then.. The buggy doesnt have rear sway bars either. I bought it 2nd had so trying to dial in. I dont have the parts book so need to look up the parts. I know that the slipper right now is very tight with not much slip I dont think. 7/5 on the diffs. The pinion is 20 and motor seems warm for the little track. Thanks for all the input guys
wolfe99 is offline   Reply With Quote
Old 10-21-2014, 09:56 AM   #5733
joeymdz's Avatar
Send a message via MSN to joeymdz
this should you help you out for a manual:
http://www.petitrc.com/setup/xray/Se...tsXrayXB4.html
you really need to know whats on your car especially when you buy it 2nd hand. go through the car and redo the shocks, re-grease everything, redo the diffs (and since you are on low grip go 5f/2r).. and clean/re-oil the bearings. Also look at the VIK Tacoma set up and order parts that are needed.
AND CLEAN/ RESET THE SLIPPER CORRECTLY!!
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 10-21-2014, 02:10 PM   #5734
Trader Rating: 15 (100%+)
Here's Tyler set up:
http://www.petitrc.com/setup/xray/se...acoma20140413/
That track is fairly tight - is that why he's running the 6* front hubs?
No rear weight?
TLR 42.5wt = AE 40wt-37.5wt = 500cst?
TLR 27.5wt = AE 27.5wt-25wt = 300cst?
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 10-21-2014, 02:46 PM   #5735
joeymdz's Avatar
No rear weight?
6 degree hubs creates more stable low speed cornering. At high speeds these blocks reduce push as well. (stolen from exotek)
also the axle height helps:
Lowering the Axle (putting the shims on top of the steering block) will give the car more front grip entering corners, but a little less grip on exit.
no weight!
http://www.petitrc.com/reglages/OilChart.pdf
Old 10-23-2014, 08:43 PM   #5736
TLRCREW's Avatar
Trader Rating: 19 (100%+)
Arrow
New to xray, I have been racing short course for a couple years and wanted a change. I picked up a xb4 for 150 and it came with some exotek upgrades. I am always for mods to cars so I gave the shorty lipo a chance and it came out pretty good. I ordered some spare parts like extra rings and pinions for diff's. I am not sure about the plastic in the diffs, are the aluminum upgrades for ring and pinion. Any input would help.
Xray XB4 thread-img_20141021_124640512.jpg   Xray XB4 thread-img_20141022_150927450.jpg   Xray XB4 thread-img_20141022_150934417.jpg   Xray XB4 thread-img_20141022_204347275.jpg   Xray XB4 thread-img_20141022_204351311.jpg
TLR CREW
IF Your Not First Your Last!!
TLRCREW is offline   Reply With Quote
Old 10-23-2014, 09:46 PM   #5737
Aluminium crown and bevel gear are a nice to have if you can't be bothered to set your slipper clutch properly. As for the internal gears, I've been fine with the plastic ones and really it's nice that the drive train and rotational mass is lighter with the plastic than with aluminium ones.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 10-24-2014, 01:43 PM   #5738
Trader Rating: 32 (100%+)
When they gonna release new xray xb4 2015? Anybody know?
raved007 is offline   Reply With Quote
Old 10-25-2014, 07:59 PM   #5739
BDRMBULLY's Avatar
Hopefully not as long as its been taken since the announcement of metal ring n pinions lol
Hand D Flooring
Old 10-26-2014, 06:01 PM   #5740
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
Avid shock pistons.. Worth the money?
MaricopaAgent is offline   Reply With Quote
Old 10-26-2014, 07:23 PM   #5741
Send a message via AIM to sublimize23
I think my slipper was too tight all day. Buggy was very loose, especially the rear. Considering adding more rear toe and more rear wing. Is there a good method to setting the slipper? On the B44.2 you could push it gradually tighter until the front wheels would slip.
sublimize23 is offline   Reply With Quote
Old 10-26-2014, 07:51 PM   #5742
Over the stock pistons yes, I bought the 1.5+1.1's and 1.6+1.1's for outdoor (I found them ok, but for me they lacked pack). Check out Schelle, they offer the same pistons with the same tighter tolerances but in pairs of two, not four, like Avid, and they also offer 1.6 and 1.7 in a 2 hole piston - my next purchase.
Unfortunately neither make stock 1.3 x 3 hole or 1.4 x 2 hole for indoors/carpet. On another classified site there is a seller selling pistons CNC'd in Macau which are better than the Xray stock pistons (that are molded onto a plastic tree), but they are copied from Xray pistons, which means they too are just slightly smaller than they should be and wobble when in the shock body, much like the Xray stock pistons (disappointingly) do.
Daragh Slowey
Old 10-26-2014, 08:04 PM   #5743
What kind of surface and tyres were you on? I'm on medium indoor loamy surface and I had completely the opposite with my XB using this setup - http://www.petitrc.com/setup/xray/se...un20130811.pdf
As for setting the slipper, I do that on the track. From a stand still, hard on the throttle and listen and watch the tyres. Slipper should slip and tyres shouldn't excessively wheel spin for about 5/6ft. Car should track straight and true. Once that's ok, I'll go around the circuit and make sure I'm not slipping too much for the take offs for my jumps. Its the first thing I check on the cars for the day that I'm running
Old 10-27-2014, 11:21 AM   #5744
Unfortunately neither make stock 1.3 x 3 hole or 1.4 x 2 hole for indoors/carpet. There is a seller on a well known site selling pistons CNC'd in Macau which are better than Xray OEM, but they are copied from Xray pistons, which means they are just a little smaller than they should be and wobble in the shock body much like the Xray stock pistons do.
We are running indoors med/high bite.. I ordered the 1.6 and 1.5 avids. Wasn't aware of the Schelle's till now.
Old 11-02-2014, 05:36 AM   #5745
BDRMBULLY's Avatar
Is this thread locked or sumn?
No good info left to share?
Hand D Flooring
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
