Like Tree54Likes
Old 09-18-2014, 11:12 AM   #5566
Phoenix82's Avatar
hey guys. what are you running for a steering servo?? low profile??
Nick K
Desoto Racing|Novak|Airtronics
Phoenix82 is offline   Reply With Quote
Old 09-18-2014, 01:47 PM   #5567
GregerL's Avatar
Nick K
We tend to want to have the servo saver pretty much locked down on the XB4 and I have not found a low profile servo that really can take the abuse of that. Stayed with the full size servo, have been running Sav÷x 1258TG with great success.
/G.
GregerL is offline   Reply With Quote
Old 09-18-2014, 01:49 PM   #5568
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
low profile servos suck. They are not nearly as durable as full sized servos. I only use LP servos when I have to because there is no room.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-18-2014, 02:23 PM   #5569
V6Jim's Avatar
Nick K
Tried quite a few servos and, believe it or not, the one I've liked the most is a Hobby King MI Digital one. Fast, tough and super smooth.
http://www.hobbyking.co.uk/hobbyking...6sec_61g_.html
Nicer than a lot of servos 3 and 4 times the price.
Jimmy
Dumfries, Scotland.
Returned to racing after 20 years off. (Racing Karts and Motocross!)
Scottish 1/10th Off-Road Champion 1985/86/87.
Now driving PR Racing UK PRS1 V2, V3FM, V3MM & PR SB401LW
V6Jim is offline   Reply With Quote
Old 09-19-2014, 07:14 AM   #5570
jmcelroy42's Avatar
http://www.amain.com/ProTek-R-C-130S...oltage/p253592
This is the one I use.
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 09-19-2014, 04:02 PM   #5571
Trader Rating: 29 (100%+)
Default Slipper assembly
I've read through a lot of this thread and haven't noticed anyone with this issue.
I'm in mid assembly and I just installed the center slipper and I feel like there is a lot of play when installed. I can move it front to back a fair amount. Is this normal?
branover is offline   Reply With Quote
Old 09-19-2014, 04:22 PM   #5572
Boz
Trader Rating: 23 (100%+)
Yes, it has been mentioned before
Put a shim in before the bearings, this will fix it. The new yellow pad a sightly thinner then the original black pads, hence a little more back and forward play.
Note: you do need a little movement, so don't go shimming all of the play out.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 09-19-2014, 04:29 PM   #5573
Trader Rating: 139 (100%+)
Nobody I know is shimming the slipper assembly and so far zero issues. Might do it to remove just a slight amount of play, but so far no problems with both cars, the one I have now, and the one I had earlier in the year.
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 09-19-2014, 04:32 PM   #5574
Thanks for the responses. I was just concerned that it might damage the bearings. I'll throw a shim in there for peace of mind. Nice build otherwise so far. This is my 3rd xray, by far my favorite manufacturer
Old 09-19-2014, 04:48 PM   #5575
Boz
Now you know someone who does.
I didn't say there was issue or problem either. Pads do wear, some people don't like that amount of play. It was something we did when running a Durango.
You don't have to do it, but I like fast lap times.
Chris Bozich
Xray XB8 XB4 XB2
Old 09-19-2014, 04:53 PM   #5576
I didn't say there was issue or problem either. Pads do wear, some people don't like that amount of play. I was something we did when running a Durango.
True that. I have some shims, wouldn't hurt to throw on a couple. As far as fast goes, my call is ballistic and am one of 3 drivers to do sub 17 second laps on my local track. Have you toyed with the 6 degree caster blocks? I have them but have not used them yet.
Old 09-19-2014, 05:58 PM   #5577
joeymdz's Avatar
Send a message via MSN to joeymdz
I like them. More aggressive feel up front. Im also running Vik's Tacoma setup
(And I shimmed all 3 of my cars)
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 09-19-2014, 06:03 PM   #5578
Boz
I have not tried them for awhile. We have our state title in a few weeks, so I will have two full days of practice. I may put them on for a run. I'm struggling with understeer on the 180deg corners, we have 4 of them. The club is planning on applying sugar for this meet, so the grip will come up.
Chris Bozich
Xray XB8 XB4 XB2
Old 09-19-2014, 06:19 PM   #5579
Yeah, I had the same problem with off power under steer when the traction came up at LRH.dont know for sure if the caster blocks will help, but since it is way cooler and no humidity ( was running on an indoor clay track that the surface of the track was 98 degrees, and water evaporated as soon as it hit the track making things unpredictable was s challenge to setup for to say the least.
Old 09-19-2014, 06:34 PM   #5580
Boz
I moved the front inner camber link to the top hole (3mm of spacer on the outer position). This helped a little. Let me know if this works for you??? But I am still after a bit more.
Chris Bozich
Xray XB8 XB4 XB2
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
