Like Tree39Likes
Old 08-11-2014, 10:20 AM   #5281
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by BDRMBULLY View Post
You may need to shim it
Not really they work perfect out of the box. This for the spec r DCJs
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 08-11-2014, 10:53 AM   #5282
Default metal diff gears
sorry for mmy anger but this is BS. I have had my xb4 spec 14 since it came out abd really love it besides the rear diff going out every other week if not every week. Im sick of spending 25 plus dollars on parts that or xrays issues. I have had 5 people buy the kit because I let them drive mine and talked it up and they are having the same issues as me. You guys (XRAY) have been saying since NOV 25 of 2013 that you were making Metal gears to fix your mistake of graphite gears. I have emailed you guys twice now over the last 4 months and have not gotta anything back but "there is not set date yet"
please someone just give me a answer so I where do go from here. sorry If I hit a nerve with someone, but I over a year and half later and nothing when they know people aare blowing them left and right.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 08-11-2014, 11:03 AM   #5283
aloksatoor's Avatar
I know its been said before but just maintain the slipper right and it will work. I run mine with a 4.5T on a huge 1/8 size track. Just scrape the pads with a xacto, fine sand the plates, adjust to around 6.3 to 6.5 (pre compress spring with channel locks) and run. It does chip gears when I run around 6mm on the springs, its an expensive mistake but you learn from it .
Don't wait on the Hudy guys man they would be busy writing 'optimized' descriptions for the 2015 release lolz. I would drop this car at a moments notice if there was something better but right now just isn't. The d413 is too sloppy and no parts (even that d812 has parts shortages still and did not shine particularly at last weekends big race, the tlrs broke a lot, no zx6s showed up, yokomo is hard to find parts but looks solid). The zx6 would be my choice once they start coming out with gear diffs stock.
Old 08-11-2014, 11:15 AM   #5284
joeymdz's Avatar
Send a message via MSN to joeymdz
Is there a like button??
I had the EXACT same issue until I started to adjust my slipper almost every time it hit the track. I think its been about 6 months since I've shredded gears. And I race on clay to real loamy dirt to carpet.
its a slipper issue.
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 08-11-2014, 12:18 PM   #5285
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Ive burned out two rear diff sets of internal gears (not ring n pinion)bought nt1 gears metal and redonemy slipper seems alot better got 3 days in my buds back yard track pack after pack with no ish ( fingers crossed i dont blow ring nor pinion gears )
BDRMBULLY is offline   Reply With Quote
Old 08-11-2014, 01:19 PM   #5286
asc6000's Avatar
Trader Rating: 15 (100%+)
That is total malarkey and you know it. Bentka used to fanboy the same lame message. If it was perfect then why new versions and upgrade kits and so on and so on. Various versions of most parts are different dimensions and when mixed can give wildly varying tolerances. < that is fact. Iv'e been saying it since the dang thing came out. SHIM it if it has slop. I still have the original gears in one diff. Shimmed since new.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 08-11-2014, 01:51 PM   #5287
aloksatoor's Avatar
haha not that man, I was talking about the spec-r DCJ front driveshafts sold by superior hobbies THOSE do not need shimming. Edited my post also hehe
You do need to shim that diff esp if the ring is oldler and the bevel is new since the v2 bevel sits a bit ahead :P. Ain't an xray fanboi at all, sold all my 1/8 xray crap since I hate the bigger buggies. As I said before, I would drop this car the moment something better comes in with some decent parts support, sick of paying $$$ for an outdrive and 10 bucks for 1 inch of optimized heat shrink tubing (they sold for the 1/8 stuff).
Old 08-11-2014, 02:59 PM   #5288
EricW's Avatar
6 months, both diffs are fine and I beat the piss out of my Xb4. Adjust the slipper correctly.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 08-11-2014, 11:11 PM   #5289
Oasis's Avatar
Trader Rating: 36 (100%+)
Gearing for a 7.5..any starting point would be good..thanks for any help..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 08-12-2014, 09:22 AM   #5290
joeymdz's Avatar
23/84 (big track)
Old 08-12-2014, 10:37 AM   #5291
Trader Rating: 75 (100%+)
I think the temps will depend on your ESC/Motor combination as well as gearing, but I know my XB4 with an RS Pro is very heat sensitive with respect to gearing.
My first motor was a Tekin 6.5t. I think I started with a 22 pinion with the stock 81t spur and my RS Pro was thermalling before 10 minutes. I went down to a 21 and managed to finish a 10 minute main, but my speeder was coming off at 190-200 degrees, despite the motor being right around 140 degrees. Tried a 20 tooth pinion and got the speeder to come down to 170 degrees. I finally settled on a 19t pinion which kept both my motor and speeder within the 140-150 degree range.
I moved to a Reedy 6.0T motor and needed to go down to a 18/81
Now I have a Tekin 5.5 motor and I'm at a 17/81
Even one tooth higher on those combinations sent my RS Pro temperature up 20-40 degrees. I'm not lacking in top end speed either. For a 7.5t motor I would suggest starting at a 20/81. Check your temps and if permissible, I'd go up one tooth at a time until you find the sweet spot.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 08-12-2014, 11:19 AM   #5292
BentKa's Avatar
Each to his own I guess.
We've ran these since day 1 and have never shimmed the diffs nor the slipper or the prototype center diff that we now run.
We've done it all with clay, dirt, carpet and astro.
Ball diffs, metal gear diffs and stock composite gears.
Shorty pack and saddle packs.
National Championships, Nordics Championships, European Championships, Euro Offroad Series and a bunch of other races without failures.
What works for some apparently doesn't work for others
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 08-12-2014, 04:19 PM   #5293
BDRMBULLY's Avatar
Why announce metal ring n pinion are "coming soon" if they are not? For the longest time you cant even get outdrives on amain like what the heck? If i knew it was so hard to buy parts i would of never purchased this wheeler or any wheeler for that matter i calling BS graphite gears are bogus nuff said i dont care how the pros set their slipper the majority of us are not sponsored pros its almozt football season
C'MON MAN!!!!!!!!!
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
Old 08-12-2014, 04:27 PM   #5294
Oasis's Avatar
Thanks for the help on the gearing..
Old 08-12-2014, 05:11 PM   #5295
asc6000's Avatar
Bent
You can be smug about it if you want but I don't understand why you don't acknowledge that there YOUR experiences are not what MANY people go through and that there is a simple solution if they so CHOOSE to use it. If you don;t choose to use it then why cut it down for everyone else ? Don't you see all these people posting about their problem ? Why do you want to deny them a solution is boggling.
My car works great.
Ayrton Senna
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
