Like Tree37Likes
Old 08-04-2014, 07:22 AM   #5251
Originally Posted by suzukipro View Post
I bought and use the Bugle Boy Racing Front Bumper, it looks like it's a factory option part and has held up great!
Yes, same here. And I've had some horrible crashes .
Another thing with this style of bumper is that it tends to be a bit nicer to the track you're running on if it's astro or carpet. The original, square bumper can easily catch seams etc.
Nyegaard is offline   Reply With Quote
Old 08-07-2014, 05:53 PM   #5252
the jconcept 12mm hexes the front wheels are for zx6 ,zx5 compatible will the b44.2 wheels work or is the offset different i assume the offset different? also seen exotech racing has a set that will work for the b44.2 wheels but will i need longer axle for the front ? i looked for jconcept zx6, zx5 compatible wheels and seem's i can not find them online like they don't make them. any knowledge would be greatly appreciated.
kjsea is offline   Reply With Quote
Old 08-07-2014, 06:28 PM   #5253
asc6000's Avatar
Trader Rating: 15 (100%+)
Do you already have zx or b44 wheels ? The only real reason to run other brands of wheels is because you have them already. Otherwise just use the xray wheels. Don't make it so hard.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 08-07-2014, 06:39 PM   #5254
i have b5 rear wheels and it would make it easer. one less wheel to order and they are available everywhere i would race. only reason am looking to switch i dont have the front wheels though
Old 08-08-2014, 02:03 AM   #5255
Peakki's Avatar
With exotek 12mm rear hexes&AE B5 wheels the car is barely within the width rules. I wouldn't recommend those.
JC 12mm rear hex seems to be narrower and I expect that the car width is nearly the same as with stock xb4 14mm hexes and xray wheels...
Destiny&V-Dezign 1:12- Sanwa M12s - Xray XB4 2016 - Xray XB2 DE - HW XR10Pro & Team Orion R10.1 Pro & Sanwa Super Vortex Zero Gen2- Team Orion Vortex & Muchmore & Reedy BL motors - Sanwa & Highest & Sav÷x servos
Peakki is offline   Reply With Quote
Old 08-08-2014, 03:47 AM   #5256
Trader Rating: 25 (100%+)
I haven't gone through this whole thread. However I just ran my xb4 for the first time last night and absolutely loved it. My only issue was that one of the pins holding the cvd's in just shot out. I didn't see any sign of it going through the plastic cover. Is this a common occurance and also what parts should I keep on hand for races? Thank you
Ronisonce is offline   Reply With Quote
Old 08-08-2014, 04:32 AM   #5257
It happens, especially if the join is too dry.
Switch to the optional alu cups.
As for spares, there's a nice list earlier in the thread . But a few arms front and back, diff houses front and back and bevel and crown gears is a good place to start.
Old 08-08-2014, 07:41 AM   #5258
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
My buddy blew a pin through alloy cups and he always used a graphite dry lube on his joints
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 08-08-2014, 08:55 AM   #5259
joeymdz's Avatar
Send a message via MSN to joeymdz
make sure you check your locktite(d) screws. My front diff got shredded from the screw holding the bevel gear in place back out. destroyed the diff housing. I didnt take any pics but it made a huge mess.. and gave me about 60% drag brake!! haha
I swear Xray should hire me for R&D
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 08-08-2014, 10:59 AM   #5260
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Yeah I also did the same once. Only thing did not clean the older blue off with motor spray that caused a failure lolz. Had half a mind to put a socket cap and red locktite the sucker :P
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 08-08-2014, 05:16 PM   #5261
Boz
Trader Rating: 23 (100%+)
lube your pins with this stuff and use the alum cups.
Xray cups
Eureka Pro Lube
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 08-08-2014, 06:17 PM   #5262
Is anybody making a center diff conversion for this buggy?
Rickybob is offline   Reply With Quote
Old 08-08-2014, 06:27 PM   #5263
joeymdz's Avatar
No
wait 4 months and I'm pretty sure xray will include them in the 2015 kits
Old 08-08-2014, 09:53 PM   #5264
moot's Avatar
Can anyone point me in the right direction for a setup on a loose track? I need everything from the tires upwards
Here's the track
moot is offline   Reply With Quote
Old 08-08-2014, 09:54 PM   #5265
moot's Avatar
Again
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
