Like Tree36Likes
Old 07-22-2014, 11:35 AM   #5191
fullout's Avatar
Send a message via MSN to fullout
Any feed back on 6 deg c hubs?
Daniel Weinstein
Xray T4 15, Xray XB8 14, Xray XB4 14, Kyosho TKI 3, Kyosho RB6, Sanwa M12
rcamerica.com
performancehobbies.ca
orcarc.com
fullout is offline   Reply With Quote
Old 07-22-2014, 12:03 PM   #5192
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by ferrarieeeee View Post
Anyone tried putting the complete bmax4 diff including the diff case?
It will end up costing as much as the xray metal diff gears . The driveshafts on the yok are around 2mm. xray is 3mm, so 4 driveshafts along with the diff and ring gears $$$
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-22-2014, 12:23 PM   #5193
Trader Rating: 16 (100%+)
Xray driveshafts won't fit in the Yokomo outdrives. Slot is too small, mod needed
Tekno: NT48, ET48, EB48, SCT410
Xray: 2 XB9E, XB9, XT9 E, XB8 E 2014, 808E, 2 T4, XB4, XB4 2015
Losi: SCTE 2.0, 8T 3.0E, 2 8T 2.0E, Mini8T, 2 Mini8,
Mullet1 is offline   Reply With Quote
Old 07-22-2014, 09:49 PM   #5194
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Cars 2 yrs old what does coming soon mean? 2015 metal ring n pinion? Lets go xray
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 07-23-2014, 12:21 AM   #5195
BigInJapan's Avatar
Trader Rating: 15 (100%+)
lol people give hudy a hard time for releasing new cars too often. so which is it?
⚡ TEKNO ⚡ OS ENGINE ⚡ KO Propo ⚡
BigInJapan is offline   Reply With Quote
Old 07-23-2014, 05:12 AM   #5196
rcgod's Avatar
Trader Rating: 27 (100%+)
I heard a rumor that the 2015 spec kit will come with the metal diff gears stock. Maybe Hudy will hold off on releasing the gears as an incentive to buy the new car.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 07-23-2014, 06:09 AM   #5197
well at least if that's true we can get the gears once the kit and parts for it are released
Old 07-23-2014, 05:17 PM   #5198
aloksatoor's Avatar
Hehe. I think it was more for the 'optimised' chassis releases for on road tc ep, the back and forth on tall/short/tall again big bore shocks on the 1/10 nitro tc, and to an extent the xb9 and xb8 series where keeping up to date is more expensive.
Old 07-26-2014, 03:54 AM   #5199
Errokk's Avatar
Well, I finally shot my first set of ring and pinion gears in my xb4 after 2yrs of running, both the front and rears lol. The teeth were very worn which is to be expected from the amount of run time the car has had. I guess im very pleased with how well they've held up being plastic gears. Cheers.
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 07-26-2014, 05:57 AM   #5200
Stanfsu's Avatar
Trader Rating: 294 (100%+)
Send a message via Yahoo to Stanfsu
Hey guys I just picked up one set of metal gears for the diffs. Should I run in the front or rear? Does it matter that one set is composite and other set is metal?
Losi | Futaba
Low Ballers will be ignored!
Stanfsu is offline   Reply With Quote
Old 07-26-2014, 08:13 AM   #5201
Rear
Both is better
Old 07-26-2014, 09:07 AM   #5202
ferrarieeeee's Avatar
Where did u order them? What's the part numbers?
Electric: eb48.3 / eb48sl / 811e / d413 / b5 / b5m / kr / pro2b / msc / scte
Nitro: nb48.3 / xb8
ferrarieeeee is offline   Reply With Quote
Old 07-26-2014, 09:13 AM   #5203
BDRMBULLY's Avatar
I blew2 sets of rears from being on power on the down side of jumps
Id go rear and losen ur slipper some at first and tighten from there
I put them in frnt n rear and they are awesome compared to plastic ?;@)
Nt1 gears 335030
Hand D Flooring
Old 07-26-2014, 12:40 PM   #5204
asc6000's Avatar
Metal or composite, check the sideplay and shim them a bit if they feel loose. A tight set of composites will last longer than a loose set of metal gears. Been there. If you measure all the various bits and pieces you will find that the dimensions of some of the parts vary. Original vs new version, etc etc. Shim that junk up.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 07-26-2014, 07:06 PM   #5205
question, i bought a kit xb4 4wd on 7-24-14 from amain, built the hole kit tried to put the servo in and the ears on the servo ripped off the servo. it seems like the servo mounts on the chassis is about 2mm to 1mm to wide for the servo. servo am using is xp ds1313. has anybody else experienced this problem. also i looked at the photos of the car online and it looks like i have the 2wd drive chassis is there a difference between the 4wd drive and the 2wd?
kjsea is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
