Like Tree52Likes
Old 07-18-2014, 07:43 PM   #5176
asc6000's Avatar
Trader Rating: 15 (100%+)
The last pic looks the best but it looks too tall. I see what your going for though.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 07-18-2014, 08:16 PM   #5177
The pattern is higher due to you need to allow trim height for the material..actually the new design is a little lower...also the side sections dont have a chamfer as the original one so it just looks higher...once trimmed after it is moulded it will sit quite nicely on...I think I need to go to the next stage give me a week or so...
Thank you for the feedback
Aussie RC is offline   Reply With Quote
Old 07-18-2014, 10:20 PM   #5178
Graham11's Avatar
Trader Rating: 21 (100%+)
I like the incubus version but urs is cool to so far, I'd buy one if ur in the states, pm me if u do make them
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 07-20-2014, 08:38 PM   #5179
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Nt1 gears frnt n rear with alloy cross pins car is flying, cant wait for xray pinion n ring gear = no fear!!!!!!
Giver!!!!!
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 07-20-2014, 08:40 PM   #5180
rcgod's Avatar
Trader Rating: 27 (100%+)
Giver!!!!!
What's the part number for those?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 07-21-2014, 06:04 AM   #5181
BDRMBULLY's Avatar
I threw out the header cards
nt 1 gears
You will also need the metal cross pins
Hand D Flooring
Old 07-21-2014, 07:32 AM   #5182
Trader Rating: 16 (100%+)
http://www.amain.com/product_info.ph...llite-Gears-24
wrong ones.
you need the ones for the NT-1
Tekno: NT48, ET48, EB48, SCT410
Xray: 2 XB9E, XB9, XT9 E, XB8 E 2014, 808E, 2 T4, XB4, XB4 2015
Losi: SCTE 2.0, 8T 3.0E, 2 8T 2.0E, Mini8T, 2 Mini8,
Mullet1 is offline   Reply With Quote
Old 07-21-2014, 11:07 AM   #5183
1/10th NT1 gears - 335030
1/8th buggy gears - 355030
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 07-21-2014, 12:11 PM   #5184
rcgod's Avatar
Thanks guys.
Dialed RC Hobbies
Old 07-21-2014, 01:55 PM   #5185
Originally Posted by brnantunes View Post
I have a friend that put yokomo metal dif gear/pinion, it's simple conversion.
Tnks
Please if anyone knows exactly what's needed post up. If you got a buddy that has done this can you ask him? Thanks
Old 07-21-2014, 02:32 PM   #5186
rcgod's Avatar
It's not an easy conversion. I bought the parts and started working on it last Friday and set is aside until I have more time.
The outdrive and bearing on the crown gear side are going to have to be shimmed out quite a bit, about .090" which then means the bearing is riding on a little more than half of the crown gear. Also the crown gear is not centered on the diff case like stock. There is a gap so all the force of not only rotational but also radial force is through the 4 diff screws. Looks like a hokey setup not sure I would trust it. I'm waiting for the xray gears.
Then
Dialed RC Hobbies
Old 07-21-2014, 02:57 PM   #5187
Then
I wonder why a few others have said it was a somewhat easy conversion. Disappointing considering I bought quite a few of the parts to do it.
Old 07-21-2014, 03:16 PM   #5188
joeymdz's Avatar
Send a message via MSN to joeymdz
If you think about it that would be cross-mixing Segedin Goulash with Sushi Rolls... That just doesn't work.
and if you want to know what Segedin Goulash:
http://en.wikipedia.org/wiki/Slovak_cuisine
watch in 2 weeks the steel parts will be available
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 07-21-2014, 03:19 PM   #5189
rcgod's Avatar
If you don't mind shimming the heck out of the diff then it might be considered easy. It's definitely not a drop in and go mod. Even if I went ahead and made it work I still wouldn't trust the ring gear to stay concentric to the diff case.
Dialed RC Hobbies
Old 07-22-2014, 07:02 AM   #5190
ferrarieeeee's Avatar
Then
Anyone tried putting the complete bmax4 diff including the diff case?
ferrarieeeee is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
