Like Tree36Likes
Old 07-09-2014, 12:20 PM   #5086
Graham11's Avatar
Trader Rating: 21 (100%+)
Originally Posted by joeymdz View Post
you have an old manual. 2014 says 5.7-6.3
If you do not adjust the slipper properly YOU will destroy the diff and drive bevel gears.
does an old manual mean I got an old kit as well? When i ordered it I specifically asked that it be the new 2014 kit. How do I tell if I got the newest version?
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 07-09-2014, 12:25 PM   #5087
Graham11's Avatar
Originally Posted by asc6000 View Post
no thanks, I'll just buy the stock rims. They should proofread their stuff better. "XB4 12mm Front Clamping Hex Set. Converting the rear of the XB4 to 12mm hex drive is simple with the release of these adaptor sets"
front ? rear ?
they sell both the rear and front. its in the title but yes they should proofread
http://www.amain.com/product_info.ph...amping-Hex-Set
Kinda mad cus i literally have a amain order arriving today with 2 more sets stock rims and tires and i have all these AE tires from my b5m
Old 07-09-2014, 01:34 PM   #5088
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Fine if its not the composite gears then bring on a center diff screw the dumb slipper
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 07-09-2014, 02:06 PM   #5089
jkirkwood's Avatar
I must have the only XB4 that pushes out of the box. I was surprised how much steering I had to add especially after reading review after review of how much the car steers for them. After a few changes I about got it there. Excellent build and seems to handle very well.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 07-09-2014, 02:23 PM   #5090
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Dunno about that. The D413 guys run almost a locked center diff (100k oil for high bite) and keep stripping spurs (sure its a combination of metal ring gears and a diff). Still not convinced its needed in a 1/10 size car unless its with metal spurs as well.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-09-2014, 03:53 PM   #5091
BDRMBULLY's Avatar
Maybe makeit mod1spurn pinion
Hand D Flooring
Old 07-09-2014, 04:26 PM   #5092
aloksatoor's Avatar
Yeah that would be awesome and I would also like bigger diff cases for center (less chance of oil breaking down fast like the tki3). And also a shorty with center diff case movable back and forth (tunable for weight placement like the JQ white car)
Old 07-09-2014, 07:20 PM   #5093
BDRMBULLY's Avatar
Now were talking
Hand D Flooring
Old 07-09-2014, 08:11 PM   #5094
elex300's Avatar
Trader Rating: 102 (100%+)
Im always dialing steering out of mine.
Erik Everett
EZ Customs (Rc Painting) www.facebook.com/ezcustomspainting
Jconcepts - Trinity/Revtech - Xtreme Hobbies - RCADDICTION Products
elex300 is online now   Reply With Quote
Old 07-09-2014, 09:50 PM   #5095
joeymdz's Avatar
Send a message via MSN to joeymdz
White slipper pad= 2014. Black pad =2013
2 holes on the back left and right for the chassis weights
Also removable shim in the rear
Those are the easiest things to notice right away
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 07-09-2014, 10:45 PM   #5096
Graham11's Avatar
So I have an old manual w the new stuff I guess? So loosen my slipper basically?
Old 07-10-2014, 05:08 AM   #5097
Hi Guys,
Looking at getting the XB4. Going to be running mod on an outdoor rough track.
What electronics would you recommend?
Should I run the box settings or would I better of changing the setup from the start?
Are there any options or hop-ups I should get right away?
moch8 is offline   Reply With Quote
Old 07-10-2014, 05:37 AM   #5098
EricW's Avatar
I run mine at 6.3 and haven't stripped anything in nearly 6 months of running it. My track is mid traction so I'm sure that has a lot to do with it as well.
I have the 2014 as well and the manual that came with it also specified the wrong slipper settings. I believe if you download the latest manual from the Xray site it shows the correct slipper settings.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 07-10-2014, 06:20 AM   #5099
Trader Rating: 15 (100%+)
I have the newer pads and spring and I run mine at 6.00mm. I race at a clay track which is considered med-high traction. I have stripped a set of front bevel/pinion gears but looking back it was likely me being a donkey by gunning it to try and jump over some tile drainage tubing outlining the track.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 07-10-2014, 06:25 AM   #5100
Trader Rating: 28 (100%+)
Originally Posted by moch8 View Post
Hi Guys,
Tyler vik's reedy setup is a good starting point and the avid 1.5 and 1.6 pistons are a must.
Thanks to my sponsors
Proline racing Sidewinder Fuel 4C Hobby Supply Upgrade-Rc Psm-Rc Rcdepot.ca RcAmerica Hudy Xray
kyok2 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
