Like Tree36Likes
Old 07-01-2014, 08:22 AM   #5041
Trader Rating: 61 (100%+)
Originally Posted by Graham11 View Post
when you say ring and pinion gears, do you mean the ball diff bevel gear? can you post a link and what is the stock spur size and what spur size for mod?
xray part number
365781
for the ctr spur gear
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 07-01-2014, 09:50 AM   #5043
B44
B44's Avatar
Is there away to run evo-aka wheels on this car?
B44 is offline   Reply With Quote
Old 07-01-2014, 09:59 AM   #5044
Exotek or JConcepts hexes
Tijuana_Taxi is offline   Reply With Quote
Old 07-01-2014, 10:58 AM   #5045
Yes get the exotek or jconcepts adapters for losi associated and kyosho rims
Or get the aka adapter bands
LATER COOKIE
TEAM PROLINE-RACING
Old 07-01-2014, 11:23 AM   #5046
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by zixxer View Post
collars referenced above
set of front and rear arms
set of hinge pins
spur gear
2x ring and pinion gears
the collars are a must in my opinion after running many packs you will have problems with the cvds puking out drive pins if you dont have the upgraded collars
make sure to set the slipper correctly by the measurement given in the manual
other than that i have only broken 1 front and 1 rear arm and puked out almost every drive pin before getting the aluminum collars ....very durable car for sure
Also might want to have a front diff case as a spare. Only thing I've broken other than arms and rear ring gear. A hard hit to the front shock tower can crack the diff case.
rcgod is offline   Reply With Quote
Old 07-02-2014, 02:56 PM   #5047
Trader Rating: 23 (100%+)
I sold my d413 4wd buggy last week and bought an XB4 2wd and 4wd because I really liked the out of the box setup and parts availability. The d413 spur gear is impossible to find and I got tired of waiting..so glad it worked out. I was shocked how much better the xb4 suited my driving style. I thought I would have more time and energy for both but I just don't. I am selling the 2WD on the FS thread if anyone is interested. Its a 2014 and only ran one pack through it on a indoor rubber/carpet track.
Does anyone make a harder rear hub hing pin or do you guys just buy the stock part? I broke the rear of mine on the 4wd with a very mild landing on the one rear wheel.
scteonoffroad is offline   Reply With Quote
Old 07-03-2014, 01:58 PM   #5048
Trader Rating: 16 (100%+)
Originally Posted by Rampokker View Post
Here is the fan setup I've got in my son's car.
I really like the spec-r fan mount. Makes it really easy to take the fan out or replace it if needed.
Can someone link this spec-r fan mount? Can't locate even on their site. Thanks
Tekno: NT48, ET48, EB48, SCT410
Xray: 2 XB9E, XB9, XT9 E, XB8 E 2014, 808E, 2 T4, XB4, XB4 2015
Losi: SCTE 2.0, 8T 3.0E, 2 8T 2.0E, Mini8T, 2 Mini8,
Mullet1 is offline   Reply With Quote
Old 07-03-2014, 02:05 PM   #5049
Rampokker's Avatar
Here you go:
http://www.spec-r.com/default/index....roducts_id=464
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
Old 07-03-2014, 02:47 PM   #5050
^^^^ thanks
I looked all over their site and couldn't find it.
Old 07-03-2014, 08:12 PM   #5051
theclutch's Avatar
This is one NEAT setup. Thanks for sharing!
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 07-04-2014, 02:50 AM   #5052
Rampokker's Avatar
Cheers! Took me ages to get it right. I think it can do with some blacked out wiring. Ah well, maybe in the next car.
Old 07-04-2014, 04:12 AM   #5053
Errokk's Avatar
I'm all for the red white and blue wires! Clean install man!
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 07-04-2014, 06:24 AM   #5054
MrLosi88's Avatar
set of hinge pins
spur gear
I have had the 13 spec and now own the 14 spec I haven't upgraded my collars at all I changed the pins with ones with a flat spot and used a grub screw with lock tite.
Never had a single problem!
Adelaide Rc Team Driver - Troy McGuire
XRAY XB4 '14 Spec / Nosram
XRAY XB4 2WD / Nosram
WWW.ADELAIDERC.COM.AU
Now a ARCR member
MrLosi88 is offline   Reply With Quote
Old 07-04-2014, 06:33 AM   #5055
ferrarieeeee's Avatar
Originally Posted by brnantunes View Post
Hello anyone allready test xb4 with shorty? Or it's possible convert to shorty?
I have a friend that put yokomo metal dif gear/pinion, it's simple conversion.
Tnks
metal gears? details please x 2, very interested. Any additional parts required in addition to these two?
http://www.amain.com/product_info.ph...ial-Drive-Gear
http://www.amain.com/product_info.ph...-Ring-Gear-40T
Electric: eb48.3 / eb48sl / 811e / d413 / b5 / b5m / kr / pro2b / msc / scte
Nitro: nb48.3 / xb8
ferrarieeeee is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
