Xray XB4 thread
#5011
I just bought the aluminium shock caps to get rid of the leaking.
They do hold up much better, but they still leak through the bleed screw when under pressure. How do you make it completely sealed?
#5012
What brand? I currently have the Exotek caps arriving any day and thought they came with o-rings to seal up the bleeder screws.
#5015
#5016
Talking fans - here's mine. Yeah Racing fan, 30mm, Shoe Goo'd to the chassis and soldered directly to the ESC to get the 7v worth of cooling power - otherwise if hooked up to the receiver it does not spin as fast/cool as well.
Sorry - I saved it right side up but once uploaded into photobucket is reverted back to this - how does one fix this?
#5017
Talking fans - here's mine. 3 Racing fan, 30mm, soldered directly to the ESC to get the 7v worth of cooling power - otherwise if hooked up to the receiver it does not spin as fast/cool as well.
I also shoe goo the fan wires right up to the board where they connect. I find it helps support the connection a little better. In my experiences most fans die because of the hard wire connection to the fan circuit board breaking.
#5018
So quick questions for you guys
Im running a 2014 model and im having no issue with internal diff gears at all ...However i am having a huge issue with the pinion gear stripping out just as of lately ...I have ran many runs on the car before just lately having this issue ....So i think in my mind that the ring and pinion are getting there gear mesh through the diff housing as there are no shims on the ring and pinion ...is this correct ?
Also after having initially locktited the pinion gear screw and having no real issue for many runs my screw backs out and stripped pinion .....so i replace the ring and pinion and re locktite the screw ...thining ok well the locktite loosened up no big deal .....then another stripped pinion same issue screw is backing out so please help understand if maybe i am doing something wrong ?
So today i had to replace the pinion as a result of this issue and decided well lets just use some losi ca glue thinking i didnt have time for locktite to cure .....same issue ??????????? would you guys think possibley red locktite given more than 24 hours to dry would be a solution ? i really love this car one of the best i have ever driven ...please help to understand if im doing things correctly because in my mind i am doing all i can
also currently running slipper a little looser than recomended setting just to see ...but honestly i think it is just the pinion screw loosening up
thanks guys in advance for the help
p.s. i would give anything for some eclips on that pinion right about now
#5019
#5021
Make sure you coat the setscrew threads (I'd stick with blue Loctite) and then tighten it in the pinion using a good allen/hex wrench. Loctite came and did a demo at my place of employment and the tech stated that it hardens when there is an absence of air, I'd make sure to let it sit long enough to harden up. The other thing to look at would be the mesh for the pinion & spur gears, hopefully not too loose / not too tight. Sometimes people use a piece of paper between the two gears to set the mesh depth correctly.
any body else ?
#5022
When I built my car the diffs didn't need any shimming but after a while they got a little bit of play and I blew out a rear ring gear. After shimming them I haven't had any problems and I run on super high bite with a 5.5 and the slipper pretty tight.
#5024
Hello anyone allready test xb4 with shorty? Or it's possible convert to shorty?
I have a friend that put yokomo metal dif gear/pinion, it's simple conversion.
Tnks
Tnks
#5025
