Like Tree39Likes
Old 06-16-2014, 06:04 AM   #4936
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Boz View Post
Sorry, your +1 is invalid because you drive TLR.
The score is back to +2
Lol! I drive whatever drives best.
But seriously, I follow most threads and Xray fanboyz are the most defensive of all. Why is that?
My buddy, not mullet1 seems to have unending issues with the front center drivetrain cvd, he even had the pin eject through the aluminum retainer. It's painful to watch, almost ever time he puts it out there is an issue with the car. I could swear he must be driving a Durango ( a car which I rarely had issue with)?!
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 06-16-2014, 06:18 AM   #4937
Boz
Trader Rating: 23 (100%+)
Can you please find out what brand of grease he is using to lube these with pins for me?
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 06-16-2014, 06:21 AM   #4938
Can you please find out what brand of grease he is using to lube these pins for me.
Will do, what kind should he be using, let me guess, xray?! JK lol(quick troll). Are you guys using a lithuim grease or a black grease? I sincerely wish he had it all sorted out, he is a good driver and has no other issues with any other of his kits...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 06-16-2014, 06:30 AM   #4939
Funny, he was using losi black grease. Lol. Maybe that was his problem.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 06-16-2014, 06:51 AM   #4940
Trader Rating: 16 (100%+)
I had a pin come out but only after the screw for the input gear came loose inside the diff case.
Tekno: NT48, ET48, EB48, SCT410
Xray: 2 XB9E, XB9, XT9 E, XB8 E 2014, 808E, 2 T4, XB4, XB4 2015
Losi: SCTE 2.0, 8T 3.0E, 2 8T 2.0E, Mini8T, 2 Mini8,
Mullet1 is offline   Reply With Quote
Old 06-16-2014, 06:55 AM   #4941
Hmm, Keith was having hell with his car at 3palms, I actually felt bad for him lol. So the input gear is held in place by a screw going into it securing it to output of the cv joint? ? Maybe he didn't threadlock it...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 06-16-2014, 06:58 AM   #4942
yes and I Loctite mine.
http://www.teamxray.com/teamxray/sho...p?file_id=9662
part 902306
Old 06-16-2014, 10:40 AM   #4943
katana's Avatar
These following recommendation was previously mentioned many pages back by others. And this work for me. These following parts are a good investment for our xb4's. I've installed these drive shaft pins all around and yet to have any issue. As well as Exotek cups for front and rear center drive shaft and front axles. The rear however, I've use the Durango drive shaft boots. These boots doesn't fit over the Exotek cups so well but with the safety pins in (loctite) I have yet to have any issue. Good luck.
http://www.stormerhobbies.com/cgi-bi...s&pn=TDR310120
http://www.stormerhobbies.com/cgi-bi...s&pn=TDR310113
http://www.stormerhobbies.com/cgi-bi...&pn=EXO1350BLK
http://www.stormerhobbies.com/cgi-bi...s&pn=TDR310023
katana is offline   Reply With Quote
Old 06-16-2014, 12:57 PM   #4944
joeymdz's Avatar
Send a message via MSN to joeymdz
I think I'm leading the pack for most parts destroyed on an XB4
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 06-16-2014, 01:26 PM   #4945
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Oh yea!!! I snapped my front out drive but just half.
Nice carnage, $ cha ching
I feel your pain
BDRMBULLY is offline   Reply With Quote
Old 06-16-2014, 01:28 PM   #4946
EricW's Avatar
Did you hit something?
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 06-16-2014, 01:33 PM   #4947
aloksatoor's Avatar
Trader Rating: 42 (100%+)
first things to check, droop/limiter changes, front hinge pin insert changes? I broke mine as well last month lota coin for that fix
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 06-16-2014, 01:36 PM   #4948
I agree.
Gets old hearing people thinking they know everything and want to tell everyone else. Give advice when people ask, not when you think they need it.
i like this guy lol very true
evolution03 is offline   Reply With Quote
Old 06-16-2014, 01:49 PM   #4949
fullout's Avatar
Send a message via MSN to fullout
Default my experiences
I have had the screw that goes into the pinion in the front diff come loose. It wreaks all kinds of havoc.
First of all it allows the centre front cvd to back out of the diff case which will allow the plastic cvd cover to back off allowing the cvd pin to escape which happened to me. Snapped a front cvd pin because it slipped out a bit and caught the plastic rib on the chassis.
But i also found that if the pinion screw in front diff pinion backs out enough it actually hit's the diff, which will lock up the front end. You can see the grooves caused by the screw
on the diff, as well as a polished screw head.
I also ended breaking the short pin in the spur shaft that keeps the front cup in place. I think the the front end locking up caused this.
But on the upside no stripped diff gears running on indoor and outdoor clay with a 6.5.
All of this due to screws coming loose. User error in my opinion, the car really is a tank for any of you doubting it.
Daniel Weinstein
Xray T4 15, Xray XB8 14, Xray XB4 14, Kyosho TKI 3, Kyosho RB6, Sanwa M12
rcamerica.com
performancehobbies.ca
orcarc.com
fullout is offline   Reply With Quote
Old 06-16-2014, 02:12 PM   #4950
justpoet's Avatar
I was looking at a local driver's xb4 recently and saw that when the suspension was fully compressed, the driveshaft was rubbing and putting pressure on the outside edge of the outdrives and clunking on the slot in them. The drive shafts were worn quite a bit in that spot. I don't know if that is normal, but that might explain your outdrives shattering if it was also happening for you.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
JanisK
