Like Tree39Likes
Old 06-11-2014, 08:56 PM   #4906
I've been using the S-works wing for a while so far its held up great, a high clearance version would be great!!!
Cravin is offline   Reply With Quote
Old 06-11-2014, 09:39 PM   #4907
suzukipro's Avatar
Trader Rating: 22 (100%+)
Being new to the 1/10th 4x4 buggy class I'm actually surprised the more durable plastic wings aren't the standard considering the lexan wings get tweaked if you look at 'em wrong.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 06-12-2014, 06:16 PM   #4908
Boz
Trader Rating: 23 (100%+)
Originally Posted by V6Jim View Post
I run an XB4 and a Caster S10B. I raced them both today at a Regional Championship in the North of England.
The XB4 is a great car, but I have problems with it hopping its back end up in the air over smallish bumps or jumps. The car feels really nicely setup - very similar to the Caster, yet the Caster will fly nice and flat over small jumps and just hammers over bumps superbly.
The Caster is heavier (1.9 kilos ready to race), but I have weights in the back of the Xray to try and help. Anybody else suffer from this? Still qualified 9th out of an 80 car entry, so quite happy.
Jimmy
Mine is the same Jimmy. It's a little frustrating. Mine is most noticeable when heading up to this 180deg corner on our track where I'm hard on the brakes to slow down. It feels a but unstable and every now and then it catches me out and back end lets go.
Is yours under brakes or acceleration??
I have mainly played around with pistons, oils and spring combo's but have never found anything that has kept it in contact with the track in that section. What oil,spring and pistons are you using?
Saying that, I do have the best car that can constantly take the sweeper at the end of the straight at the highest speed. Go figure!!! It just rides the bumps in the sweeper so well.
I haven't tried weights in the rear end yet.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 06-12-2014, 09:02 PM   #4909
Originally Posted by BDRMBULLY View Post
Knifed mine off formy rsx and put rx behind the motor up front
Hmm..My rsx fit fine, but my dumb receiver is too long, looks like she's going under the knife
Rafterman45 is offline   Reply With Quote
Old 06-13-2014, 10:11 AM   #4910
suzukipro's Avatar
Got mine in the mail today and did some minor trimming, the tires don't rub at all and it looks great! Depending on how well it holds up this is likely to be my new Go-to Wing for the XB4.
Eric
Old 06-13-2014, 10:25 AM   #4911
asc6000's Avatar
Trader Rating: 15 (100%+)
Lexan is lighter and actually holds up very well. Plastic ones get bent too and cost 3 times as much.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 06-13-2014, 10:34 AM   #4912
joeymdz's Avatar
Send a message via MSN to joeymdz
Jimmy
100% piston issue. buy some avids and your issue will disappear. Schelle makes some also but haven't tried them yet.
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 06-13-2014, 03:33 PM   #4913
V6Jim's Avatar
I'm not convinced that some slightly snugger pistons are going to do the job, but I'll give it a go! What hole configuration do we recommend?
Jimmy
V6Jim is offline   Reply With Quote
Old 06-13-2014, 11:07 PM   #4914
hello guys,
I am constantly breaking CVDs in my sworkz s104, does any of you have the car, or know someone who does, or can anyhow help me and tell me, if the 81mm xray CVDs would fit? Sworkz are 78mm, so it should work, but I don't know about other dimensions.. I drove my car 4 times and broke 2 CVDs, this is desperate.
eMDee is offline   Reply With Quote
Old 06-13-2014, 11:35 PM   #4915
rcgod's Avatar
Trader Rating: 27 (100%+)
Jimmy
1.1/1.5 front and 1.1/1.6 rear 4 hole avids with 40/30 oils work great for me on medium to high bite tracks. I have tried several other piston/oil combos and nothing felt as good.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 06-14-2014, 04:39 AM   #4916
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Originally Posted by eMDee View Post
hello guys,
If you use a longer shaft you liable to snap your outdrives
BDRMBULLY is offline   Reply With Quote
Old 06-14-2014, 04:58 AM   #4917
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Agreed. Why are they breaking? Are the stock CVDs too long, and binding under compression? Are they breaking at crazy angles due to flex/compression/slop in the suspension?
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 06-14-2014, 05:59 AM   #4918
seth556's Avatar
Trader Rating: 42 (100%+)
+1 You may go +/- 2.5wt in the front or rear but that's a perfect starting setup. I've also wanted to try 2 hole pistons as it should feel very similar but make the car a little more lively.
seth556 is offline   Reply With Quote
Old 06-14-2014, 06:10 AM   #4919
asc6000's Avatar
hello guys,
I suggest posting in the thread specific to your vehicle. More people there would know the answer to your question.http://www.rctech.net/forum/electric...-buggy-81.html
Ayrton Senna
Old 06-14-2014, 10:42 AM   #4920
I posted it here because I was asking about the dimensions /fit of xb4 CVDs. I will post to sworkz threaad too, thanks.
Anyway, they are breaking after jumps, once I landed on the rear tires from like 1 meter height and second time on the front the same way.. They do not bend, but the ball that is at the end of the bone going inside the wheel breaks completely, I did not even find the rest of the bone after that..
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
