Like Tree39Likes
Old 06-06-2014, 09:42 AM   #4876
suzukipro's Avatar
Trader Rating: 21 (100%+)
Originally Posted by jmcelroy42 View Post
Finally got my XB4 done. Tekin RSX & 6.5t motor, ProTek 130SS servo, SMC 5600 batteries. I also got the DMX body for it (its the stock 2wd body I think) and I can tell I am going to need the short body mount post in the front but am not sure about the rear? has anybody used this body before and know if I need both or just one?
Looking Good Joe! I'll have mine at Innovative tonight if ya feel like running
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 06-06-2014, 11:48 AM   #4877
ridgeback's Avatar
Default XB4 parts
Ive been officially sold on buying a XB4, without reading 326 posts here on this XB4 thread what parts should I buy as spares/backups along with the kit or necessary upgrades? Im pretty sure its not many parts. I race at a high bite indoor clay track (1/8 scale size); do I need to buy the carbon arm inserts?
ridgeback is offline   Reply With Quote
Old 06-06-2014, 11:53 AM   #4878
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Most parts that your gna end up needing are on back order in most places and have been so for over a month
i guess there is always flea bay
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 06-06-2014, 12:05 PM   #4879
Trader Rating: 75 (100%+)
I race on a medium sized high bite indoor clay track in the winter. The car performs great without the carbon arm inserts. The XB4 is super durable! There are only two things to watch out for in my opinion. 1) the front center drive cvd will get dry and the pin will slowly walk out. Yes, it even pushes through the plastic cvd collar. Buy the Exotek aluminum drive cvd collars, then there is now way for the pin to walk out. I only use them on the center, the rest of cvds don't seem to suffer from the same problem. Keep these greased every so often to keep the drive train smooth and prevent wear. 2) The plastic gear diffs are very durable, however . . . if you're stuck on a pipe or against a wall, don't try to power out of it! I rounded the crown and input gears on two separate occasions doing this. If you're putting power to through the gears with that much resistance, it will round the crown and input gears. It didn't chip or shred them, it just rounded a few splines down. The car still accelerated like a champ, but under hard breaking I could hear the gears skip.
With that being said, I would buy a few crown and input gears. I've not yet broken anything else on the car, so I hesitate to tell you to buy much than that. But I keep a spare set of front arms, front shock shafts, spur gear and cvd pins, that's about it. The car is absolutely amazing in terms of performance and durability!
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 06-06-2014, 12:29 PM   #4880
BDRMBULLY's Avatar
Front out drives , front bulkhead shock shafts n bottom ends are great to have and ive stripped internal gears in diff
Hand D Flooring
Old 06-06-2014, 12:44 PM   #4881
Anyone else have to dremel off the battery lead retaining tab to get their rx to fit??
Rafterman45 is offline   Reply With Quote
Old 06-06-2014, 02:07 PM   #4882
BDRMBULLY's Avatar
Knifed mine off formy rsx and put rx behind the motor up front
Hand D Flooring
Old 06-06-2014, 03:27 PM   #4883
Apparently it so common that xray did a running update to leave it out.
"If you have complete control over the damned thing, you're not going fast enough."
kaan is offline   Reply With Quote
Old 06-06-2014, 03:39 PM   #4884
asc6000's Avatar
Trader Rating: 15 (100%+)
Thats where mine is too, in front of the motor, and it's small. Allows easy fit of the esc as well as a full size swervo on the left side. With my setup it all makes for better balance.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 06-06-2014, 05:32 PM   #4885
What size pinion should I run with a 5.5t motor? I'm running an RS Pro. I'm guessing a 16 or 17, but I'm not sure.
XRAY 17 XB4
Yokomo YZ-2 CA
Old 06-06-2014, 05:42 PM   #4886
1) C'mon man, use the search button for "spares".
2) No, unless you're running carpet, you don't need the carbon arm inserts
3) Build, race, enjoy
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 06-06-2014, 10:22 PM   #4887
rcgod's Avatar
Trader Rating: 27 (100%+)
I run 16 indoors smaller track and 17 outdoors medium size track.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 06-08-2014, 12:42 PM   #4888
Jono Buggy Dude's Avatar
Yip actually dremeled mine off during the week to get my new hobbywing v2.1 esc and Rx in was also going to ask if guys have had to do that
Agama A215
Alpha / O.S Speed finally 😏😃 / Savox / Sanwa / Beta
Jono Buggy Dude is offline   Reply With Quote
Old 06-08-2014, 12:48 PM   #4889
Alright finally got my xb4 up and boosting like a wild child running the v2.1 120a hobbywing esc and yeah racing hack motor 8.5t been racing 1/8th buggy nitro for the past 3yrs so decided to give the 1/10th class a try seeing as I just love Buggys so much yesterday was my first outing with The Xb4 and electrics and all went perfect I just love it super fast tend to blip abit cause use to nitro but will get the hang of it alot smoother must say
Agama A215
Old 06-08-2014, 01:41 PM   #4890
Trader Rating: 137 (100%+)
All you really need for right away spare parts are drive pins and the removal tool. Everything else if maintained will last forever. Maybe get a spare set of Diff gaskets, can possibly get torn when rebuilding diffs. Get arms and stuff later down the road (2-3 months). Car is bullet proof. Exotek safety collars are a good investment as well. We tested carbon arm inserts in Socal on all track types, and abandoned them at all tracks. They just were not needed, and make the car to twitchy due to it being so rigid. Start with Tyler Viks Reedy Race setup, and tune from there. You will be pretty close to perfect with that setup. Keep your slipper tightened correctly. Thats pretty much all the advice I can give you.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
