Like Tree36Likes
Old 05-15-2014, 10:36 AM   #4786
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by HeavyD99 View Post
Yes!
And the prize goes to Joey - it was the front 35T bevel and ring gear that chipped, not the rear like i was so certain it had to have been.
thanks Xb4'ers!
Yep red loctite there for me hahaha. Generally never get to use it but I chewed through two gears. They were usable but noisy so had to go. The front always gets it worse though never chipped a rear.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-15-2014, 01:12 PM   #4787
joeymdz's Avatar
Send a message via MSN to joeymdz
Yes!
thanks Xb4'ers!
HOORAY!!! (what did I win??lol)
I've replaced my fair share of those darn things and it all came down to not adjusting my slipper properly. On my 2wd it just went out on me the other day but on carpet I run my slipper tight (price to pay for going fast)
glad to help
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 05-15-2014, 11:18 PM   #4788
XB4's in their current state are crap. I find it very sus that they make a car that breaks NOTHING except two parts, and they made very easy to replace the two parts, its been years and they haven't fixed the two parts. I doubt the aluminum parts will ever be released, XRAY will probably go under if they do.
XRay Sales sheet:
Cars
Car sales 10%
Parts
Bevel drive gear 45%
Crown Gear differential 45%
Other parts 0%
Its pretty stupid to produce such a strong car with such a clear problem. XB4 is for stock drivers that go slow, or drivers with awesome skills. Most of us don't have awesome skills and no one goes into 4WD buggy to drive conservatively.
Proky is offline   Reply With Quote
Old 05-16-2014, 03:01 AM   #4789
XRay Sales sheet:
Cars
Car sales 10%
Parts
Other parts 0%
5.5t motor, high grip astroturf/carpet and no failures here. Set your slipper properly and avoid landing on full throttle (doing this to any car will result in failure).
The stock ring gear in the 410 is less durable than the plastic one in the xray. I also snapped multiple rear driveshafts and centre shafts on the 410. For me the drivetrain is not only efficient, it is also very durable.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 05-16-2014, 04:10 AM   #4790
rcgod's Avatar
Trader Rating: 27 (100%+)
XRay Sales sheet:
Cars
Car sales 10%
Parts
Other parts 0%
+1. Been running mine for months with a 5.5 and 6.5 motor on some pretty high bite tracks and no issues. Slipper setting is fairly tight too. Car will wheely slightly on high bite. But I did shim the diffs recently to take out a little slop that wasn't there when I built the car.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 05-16-2014, 08:21 AM   #4791
EricW's Avatar
XRay Sales sheet:
Cars
Car sales 10%
Parts
Other parts 0%
I've yet to, and neither has anyone else at my track, ruined any gear on a 2014 XB4s.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 05-16-2014, 09:11 AM   #4792
joeymdz's Avatar
XRay Sales sheet:
Cars
Car sales 10%
Parts
Other parts 0%
I destroyed lots of bevels and crown gears but then I learned to adjust my slipper when I travel to other tracks and I havent killed any of them in months... except recently on my 2wd but that was my fault... AKA SLIPPER TOO TIGHT
Old 05-16-2014, 09:25 AM   #4793
XRay Sales sheet:
Cars
Car sales 10%
Parts
Other parts 0%
^^^ troll alert!!!!
But, seriously, with the slipper and brakes set correctly the gears last for MONTHS! I have a high bite indoor clay track and the gears hold up even with slicks on! In a year with two cars I've broken two ball cups, one rear hub, one front bulkhead, one set of gears, and one rear axle. That is with a 5.5, 8.5, and 13.5 motors. Every break was entirely my fault and had nothing to do with the car. This is by far the most durable wheeler I have ever seen.
ericschlaifer is offline   Reply With Quote
Old 05-16-2014, 09:35 AM   #4794
Trader Rating: 74 (100%+)
I've only had one crown gear issue in the 1 year I've owned this car. Was leading late in the main and tubed it. Marshal wasn't getting there fast enough so I tried to climb over the tube. The car was just spinning its wheels in place against the tube and I kept pinning it in desperation . After I got marshaled on the next few laps I could hear some grinding while braking. The car accelerated fine, but the braking was loud. Got home and tore in to it and found that I had rounded 3 or 4 of the teeth on the crown gear. The teeth weren't chipped, but rounded as if smashed between some pliers. So that crown gear issue was completely my fault . . . and partially that marshals
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 05-16-2014, 10:38 AM   #4795
aloksatoor's Avatar
Just to make it clear, my bevel gear issues were actually user error. The screw was not cleaned of older blue loctite with brake cleaner and I just did not tighten it enough so it worked loose. I will always prefer the plastic gears for a car this size until I start running 4 pole motors . Does not make sense to put heavy metal where its not needed.
Old 05-16-2014, 05:28 PM   #4796
Boz
Trader Rating: 23 (100%+)
On one of Tyler's setup sheets he has put down that he is using the AKA Evo wheels.
Does anyone know what hubs and wheels he is using?
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 05-16-2014, 05:36 PM   #4797
Trader Rating: 15 (100%+)
To be honest - the reasonfor my breakage was my own fault for driving like a donkey. I'm not sure when it happened but we have a med-high bite clay track, outdoor (but has full circus tent coverage!) and a jump called the widow maker. This thing makes me cartwheel when I muff it up. There's also a donkey kick at the end of a 90* sweeper past the straight, so plenty of opportunity to mess things up. I run my slipper at 5.8mm. The thing is a tank, and is plush, I love the thing.
I have purchased metal NT1 internal gears and hardened pins, and ya, I'll probably buy the "soon to be released" ring & pinion gear once they are out.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 05-17-2014, 08:18 AM   #4798
Jono Buggy Dude's Avatar
Originally Posted by suzukipro View Post
I'm running the 1258 tg in my XB4 and have no issues at all, kinda impressed with it actually. I'm running the Tekin RSX ESC and only running 6.0v to the servo as the optonal 7.4v seemed like overkill. Stick with what you have and spend the money on something else, you'll be glad you did.
Awesome thanks for that much appreciated
Agama A215
Alpha / O.S Speed finally 😏😃 / Savox / Sanwa / Beta
Jono Buggy Dude is offline   Reply With Quote
Old 05-17-2014, 08:33 AM   #4799
jmcelroy42's Avatar
I'm in the process of putting my new XB4 kit together and I got 3 of the small spacers for the front steering blocks and one of the big ones, instead of 2&2. I bought my kit from A-main, what is my best bet for getting the correct ones sent to me? Call A-main or is there somewhere else that handles those type of issues?
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 05-17-2014, 08:55 AM   #4800
Trader Rating: 119 (99%+)
I need some help. Last night during my main my car started making an awful racket. Needless to say after a lot of reading in here I thought I was loosing a gear. I kept on pushing on and finished 2nd in the main. Afterwards I took the body off and started snooping around. It is actually my spur gear, and not because of gear mesh. I have a TON of back and forth/side to side play in my slipper setup. What in the world is going on here? Any ideas?
skoalisbad4me is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
