Like Tree36Likes
Old 05-07-2014, 09:43 PM   #4741
joeymdz's Avatar
Send a message via MSN to joeymdz
Originally Posted by jpcopeland1 View Post
What's wrong with the stock shocks? Mine are perfect, and this is with the "inferior" stock pistons.
The stock pistons have a huge amount of blow by compared to avid pistons that are machined. Avid pistons has to be the best investment to get for this car.
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 05-08-2014, 09:10 AM   #4742
suzukipro's Avatar
Trader Rating: 21 (100%+)
Not saying there is anything wrong with them, just wondering if anyone prefers to run them with bladders, if bladders don't fit/work in them, what other shock options are available that do have bladders is the question.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 05-08-2014, 09:59 AM   #4743
V6Jim's Avatar
I popped on a set of Caster bog bore shocks which have bladders. I didn't like it much. I feel the Caster shocks are really designed for a heavier car than the XB4.
With a bit of fettling I'm sure they could be made to work, but having returned to the Xray shocks which work great (standard piston at present) I see no point in changing.
The Kyosho shocks are reckoned to be about as good as they come, so might be worth trying...
Jimmy
Dumfries, Scotland.
Returned to racing after 20 years off. (Racing Karts and Motocross!)
Scottish 1/10th Off-Road Champion 1985/86/87.
Now driving PR Racing UK PRS1 V2, V3FM, V3MM & PR SB401LW
V6Jim is offline   Reply With Quote
Old 05-08-2014, 01:09 PM   #4744
Trader Rating: 15 (100%+)
Ahh, a Frankenbuggy, LOL. Plenty of other shocks fit I'm sure, I think someone on here used the Kyosho shocks for a time but noticed them to be significantly heavier than the Xray OEM shocks. I've ran TLR 22 BB's on my 511, but limiting was much different, and so then was droop, sure it worked, but wasn't ideal - this was until Tamiya came out with their own shocks. The other thing is - the fastest guys for Xray run the OEM shocks and no bladders. Actually no one runs bladders in off road - not AE, TLR, Xray - why do you want bladders? You might be over thinking things. Avid or the Schelle pistons (who make 1.6 & 1.7 2 holes as well as the 1.5+1.1 & 1.6+1.1 pistons) are "true" fit pistons. Yes, better than the Xray OEM pistons and are a worth while investment - as are the Exotek aluminum bleeder caps. Put those together and now you have a great shock package.
Now, what o-rings to use for my rebuild.......
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 05-08-2014, 01:34 PM   #4745
aloksatoor's Avatar
Trader Rating: 42 (100%+)
The kyosho shocks fit with mods on the xray. Posted pics some time back. Frankly do not see the point if you got the avid pistons, as good as they are gonna get. Still no kyosho but pretty great.
Tried using different o rings (x ring clear kyosho), but most orings are too fat to fit with the stock spacers in the cartridge of the xb4 shock. I like the regular stock orings best still.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-08-2014, 04:07 PM   #4746
suzukipro's Avatar
Fair enough, I would assume on lighter weight vehicles that emulsion performs better than bladders for shock set up? While it is not a fair comparison, I have found emulsion works better in my SCT410 and bladders work better in my EB-48. Just thought maybe I should look into trying out bladders and figured someone else may have tried it...
Thanks,
Eric
Old 05-08-2014, 04:27 PM   #4747
aloksatoor's Avatar
Thanks,
The last cars that had options for bladder shocks never worked for me. Had the 2 schumachers sv and sv2, most ppl prefered emulsion over the stock bladder shocks (prob astro setups from factory on the cars). The other car was the over engineered under performing dex210 v1 which in most us setups, was run with emulsion. Think the tlr series also comes with bladders so any of these cars parts will work since all are 12mm shocks.
Old 05-08-2014, 07:06 PM   #4748
jmcelroy42's Avatar
Just ordered this kit today I'm pretty excited to build it. Also i got the avid pistons as advised from this thread. I will be ordering the exotek cvd cups and possibly a few other things before its up and running. Anything else i should get right away?
Does anyone know if any of the MIP Bypass pistons work in these shocks? I have them in my SCTE 2.0 and MIP Pro8 and love them. So i was wondering maybe they would work on this car too.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 05-08-2014, 07:14 PM   #4749
rcgod's Avatar
Trader Rating: 27 (100%+)
If you want to run the Vik setup you'll need 3 dot front and 1 dot rear springs and 1.4mm rear sway bar. I would also get the exotek wing mounts I've broken a couple of stock ones. Other than the usual spares you would want to carry for any car you should be good.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 05-09-2014, 12:08 PM   #4750
Jono Buggy Dude's Avatar
Proud owner of a xb4 super proud
Agama A215
Alpha / O.S Speed finally 😏😃 / Savox / Sanwa / Beta
Jono Buggy Dude is offline   Reply With Quote
Old 05-09-2014, 12:21 PM   #4751
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Its now my fav car to drive, have scte eco6 desc410 22 (sold) no more putt putt 2 wheelers lol
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 05-09-2014, 05:00 PM   #4752
Errokk's Avatar
My kinda driver right there! I as well have found the xb4 to be my favorite!
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 05-10-2014, 03:06 PM   #4753
Trader Rating: 54 (100%+)
Best 4wd buggy IMO, I let other 4wd owners drive mine and all they do is say WOW, the orion combo with this car is just smooth. It handles great, and flies like an ebuggy! Haven't broken any parts….nothing! Makes me want to try the 2wd (once they come out with the conversion) for those of us who don't run on carpet
AE RC8B3.1E |Xray XB2 CE|Sanwa M12|MKS Servos
Yodah is offline   Reply With Quote
Old 05-10-2014, 03:37 PM   #4754
suzukipro's Avatar
I'm looking for a little help with gearing or at least a starting point. I tried 20/81, 22/81 & 23/81 on a small - med dirt indoor and motor temps are approaching or getting into the 180° motor / 120° ESC range with a Tekin RSX/6.5 redline combo. Should I actually try a smaller pinion to help reduce motor temps like maybe a 19t? My theory/conventional wisdom is that if the motor is hot and the ESC is cool gear up (reducing motor RPM should help with heat), but if the ESC gets hot it is too much strain for the ESC and you should gear down. I'd like to believe I have it right, but I see a lot of setups with lower gearing and I'm not sure if I'm missing something.
Thanks,
Eric
Old 05-10-2014, 04:01 PM   #4755
Thanks,
I run 19 and 20……thats it with my 81T and my temps don't go over 150 on motor indoor or outdoor 120 on esc sounds about right. Although mine hovers around 113-117... I think 22 and 23 are too tall….and thats why the high motor temps.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
