Like Tree38Likes
Old 05-04-2014, 05:12 PM   #4726
cvd needs grease and a aluminum collar AND boots.keep them greased and clean and they will last a long time.
auto2 is offline   Reply With Quote
Old 05-04-2014, 05:57 PM   #4727
Trader Rating: 119 (99%+)
That's why I specifically said in my post that I just rebuilt them with all new pins. They had fresh grease and new pins. And this has now happened twice.
skoalisbad4me is offline   Reply With Quote
Old 05-04-2014, 06:40 PM   #4728
suzukipro's Avatar
Trader Rating: 21 (100%+)
I just bought a replacement pack of pins too as I noticed that the tips were wearing quickly on mine, I also put the Durango boots over the aluminum retainers and hope that will help keep grease in / dirt out. I think I'll see who else makes 10mm x 2mm pins and try them out (Mugen?). As previously stated the slipper may be too tight though, I keep hearing that the range in the owners manual may even be too tight.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 05-04-2014, 06:47 PM   #4729
Boz
Trader Rating: 23 (100%+)
Not all grease is the same. I tried some Grim Racing Speed grease, I didn't like it at all and I manage to catch it just before the pin broke through the plastic cup. I have been using Eureka Lube for awhile now with no problems. On both plastic and alum cups.
In regards to the slipper setting. The manual setting is a good starting point (sometimes). We all use different motors and race on different surfaces. You have to use your common sense. You can either start tight and back it off after each run until you are happy or start on the loose side and tighten it up (you will glaze up the pads doing it this way if it's too loose for the whole race).
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 05-04-2014, 08:22 PM   #4730
joeymdz's Avatar
Send a message via MSN to joeymdz
On slipper adjustment start at 6.3mm and tighten from there. In both my cars I'm usually around 5.90mm
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 05-05-2014, 01:56 AM   #4731
Jono Buggy Dude's Avatar
Originally Posted by suzukipro View Post
From my limited experience I'd start with the following
-Front & Rear A-arms
-shock shafts
-Hinge pins
-2x10mm hex pins
-Turnbuckles
-rod ends
-Rear Wings / mounts
Nice to have:
-wheel and diff bearings are good to always have on hand as well
-Shock and differential O-rings
Thanks soo much for that really appreciate it 1 more question sorry about all, the questions guys does all the 2014 spec xb4 parts fit on the xb4 2013 spec? Anyone know?
Agama A215
Alpha / O.S Speed finally 😏😃 / Savox / Sanwa / Beta
Jono Buggy Dude is offline   Reply With Quote
Old 05-05-2014, 07:07 AM   #4732
joeymdz's Avatar
Everything fits except the rear triangle brass weights (2013 doesn't have the pre drilled chassis holes)
Old 05-05-2014, 04:27 PM   #4733
i have the billion dollar an ounce hudy graphite grease in mine since new and their all fine.running 8.0 motor on dusty track with TSR boots. you can use durango pins with the set screw style set up .
Old 05-05-2014, 08:58 PM   #4734
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
What parts are needed for the Durango boots to work on the car?
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 05-05-2014, 09:13 PM   #4735
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
3 pair of these,,,
http://www.amain.com/product_info.ph...xle-Boot-Set-2
Or do you mean to use the boots without the special order pin alloy pin retainers? Then i think some are using these...
http://www.amain.com/product_info.ph...VD-Rebuild-Kit
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 05-05-2014, 09:48 PM   #4736
Originally Posted by BDRMBULLY View Post
3 pair of these,,,
Do the boots simply just slide over and stay there? would think they would move. Sorry i'm an onroad guy and we don't have this problem normally
Antoni Caretti
Old 05-06-2014, 12:51 AM   #4737
onekiwi's Avatar
If you get the cups try the spec r ones they are cheap and they have other really nice xb4 goodies with what looks like really nice stuff on the way as well.
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 05-06-2014, 09:25 PM   #4738
I have the exotek cups on now but wanting to keep out some dirt. I did notice that Spec R has DCJ's for this! I was wondering if anyone does this in offroad as its now standard in onroad. Any reason why we wouldn't want to run them?
Antoni Caretti
Old 05-07-2014, 09:15 PM   #4739
suzukipro's Avatar
Does anyone run bladders in the stock XB4 shocks? What brand/s will fit or are commonly used if this is possible. Would there be an advantage to running a different manufacturers shocks like maybe Kyosho etc...
Thanks,
Eric
Old 05-07-2014, 09:39 PM   #4740
Trader Rating: 137 (100%+)
Thanks,
What's wrong with the stock shocks? Mine are perfect, and this is with the "inferior" stock pistons.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
LThompson37
