Xray XB4 thread
#4082
http://images.amainhobbies.com/image...Table_v1_0.pdf
Recomended oil front and rear work great. 2+2 1.5front and 1.6 rear..
these pistons are a must, the stock pistons have blow back and dont seem to fit plush
#4084
13 was the first xb4.
#4085
Their lesser popular kits like 1/10 nitro, ebuggy and pan cars get less love and are on a more regular release cycle (like moog, kyosho etc).
#4086
#4089
#4091
Anyone else have there car feel like the rear over rotates? I had the v2 and loved it so I got the 14 put same set up and my rear end feels like it breaks loose and over rotates the front. Exiting corners and it will loose traction so much I have to let it stabilize before I can get back into it.
#4093
Do you guys know where I could find the aluminum cross pins inside the diff. I got a couple sets of metal gears and wasn't sure if I should run metal gears on plastic cross pins. I know it was mentioned earlier in this forum I just can't find the post .
#4094
amainhobbies has them.. I run the metal nt1 gears with the plastic cross pin and i havent had any problems
#4095
I had the same problem coming off of the '13 and onto a '14. I have both cars still and could duplicate that problem with "identical" setups between the two cars. I struggled with this for two months before I had a good fix. What eventually ended up calming the car down was going to 3.5 toe and adding 1 degree of pro squat. The push was too much at first for me so I changed the inserts to make the rear a little wider. I also pulled the shim from under the gearbox and used the standard hangers dremeled down.
I have already removed the rear plate.
Thanks!
Jimmy
