Like Tree45Likes
Old 02-07-2014, 12:35 PM   #4021
Saw that spec-r made ecs shafts for this buggy today.
Does anyone have experience with them/ do they have an actual effect?
I just know them from my touring car, where they are quiet essential, but never saw any in a 4WD buggy.
Regards,
David
niemand is offline   Reply With Quote
Old 02-07-2014, 01:41 PM   #4022
SuperiorHobbies's Avatar
We've had them in the store and they seem to be really nice. I have them on my car but have only run them once so far, they seem to smooth out the car in the sweepers.
Supplying all your R/C Racing Needs with over 10,000 items in stock and ready to ship.
www.superiorhobbies.com
SuperiorHobbies is offline   Reply With Quote
Old 02-07-2014, 02:19 PM   #4023
Yeah, they do look really good in the pictures as well
Could you keep me updated how they do duarbility-wise compared to the stock ones once you get some more packs on them.
Any advantages on hairpins and the tight corners?
Regards,
David
Old 02-07-2014, 02:57 PM   #4024
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Ordered a pair from you. Do they need skinny inner bearings like the xray touring car options?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-07-2014, 03:45 PM   #4025
Just use the stock bearings, nothing else needed.
The touring car driveshafts from Spec-R seem to hold up very well so these should be similar.
Old 02-07-2014, 07:06 PM   #4026
Trader Rating: 28 (100%+)
When cutting the rear chassis on the 13 car do you take the carbon fiber spacer out on the front of the diff case.
Thanks to my sponsors
Proline racing Sidewinder Fuel 4C Hobby Supply Upgrade-Rc Psm-Rc Rcdepot.ca RcAmerica Hudy Xray
kyok2 is offline   Reply With Quote
Old 02-07-2014, 07:07 PM   #4027
Yes.
1airborne
serpent cobra 811TE, Cobra 811T,Serpent S411TE,rebel12 pan car, VPfuel, Buku clutches, Novi motors
1airborne is offline   Reply With Quote
Old 02-07-2014, 07:26 PM   #4028
Ok thanks
Old 02-07-2014, 07:45 PM   #4029
This is a shot in the dark but anyone have a custom painted body they want to sell.
Old 02-08-2014, 09:42 AM   #4030
ronP617's Avatar
What are you cutting the chassis for??
ronP617 is offline   Reply With Quote
Old 02-08-2014, 09:47 AM   #4031
The plastic piece under the rear diff. You also have to sand the hinge pin holders a little bit so they sit flat on the chassis.
Old 02-08-2014, 11:58 AM   #4032
fullout's Avatar
Send a message via MSN to fullout
We've been running the car without the shim while using the stock suspension holders. You'll have to file down the RR holder a little bit so it doesn't extend below the chassis. This really seemed to lock in the rear without giving up too much steering. If you're eager for more steering after this, push out the shocks on the rear shock tower.
Do you adjust for droop when making either of these changes( lowering the inner hinge pin or standing up the shock on tower)? I know forsure standing up the shock on tower will increase droop and i assume lowering the arms will lessen droop. Haven't done the hinge block mod yet but i hope they cancel each other out, and get you back to my original droop settings(1mm limiter in each shock).
I have been running on indoor clay with medium bite, tightand a bit bumpy and the car on power wants to wash out. Have tried raising the inner rear camber link as well as running it in the longest position with 5f/3r diff oils and kit setup for clay everything else. Any ideas?
More or less limiters in shocks?
wheelbase?
or do i just bust out my dremel and mod the rear hinge pin holders and chassis?
springs?
car seems to stiff overall.
Daniel Weinstein
Xray T4 15, Xray XB8 14, Xray XB4 14, Kyosho TKI 3, Kyosho RB6, Sanwa M12
rcamerica.com
performancehobbies.ca
orcarc.com
fullout is offline   Reply With Quote
Old 02-08-2014, 09:52 PM   #4033
Customworksking's Avatar
Trader Rating: 73 (100%+)
looking for a xb4 2wd to try
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-09-2014, 06:53 AM   #4034
with the sprec-r double shaft i can see a use for it if your going around a turn with the steering at full lock and full throttle as the front tires will chatter.
are they holding up durability wise long term?
auto2 is offline   Reply With Quote
Old 02-09-2014, 06:58 AM   #4035
wheelbase?
springs?
check if your rear dog bones are binding in the cups at full compression. loosen up the motor and compress the suspension all the way and see if the tires turn with no binding. i had that problem and went to 5 degrees rear toe and it made a huge difference.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
