Like Tree36Likes
Old 02-06-2014, 04:13 PM   #4006
Originally Posted by jamesbernatchez View Post
Both my XB4s had play front to back with the spur. I added a shim in the rear and have been fine.
noted and thanks.
now doing up the body shell... some minor touches to go...
viktozzz is offline   Reply With Quote
Old 02-06-2014, 06:01 PM   #4007
Trader Rating: 36 (100%+)
Just guessing, I'd say I've got maybe 6 race days and equally as many practice days on my '14. Now, I have noted the play as well, on the slipper assembly, but decided to leave it be. Tonight while practicing, I blew out the rear bearing and stripped the spur. Granted, I know I've got some miles on it as is, but I do believe I'll be shimming it up from now on.
NitroOB4You is offline   Reply With Quote
Old 02-06-2014, 06:07 PM   #4008
have shimmed in 0.3mm shim at the bearing that is located on the slipper adjuster side.
movement had minimised alot.. tho i can still add in 0.1mm. additional 0.2mm would sort of tighten it up abit too much..
thus would leave it at 0.3mm as of now and re-shimmed when necessary.
Old 02-06-2014, 11:18 PM   #4009
ronP617's Avatar
Can you run the xb4 with out the plastic shim under the rear tranny where the rear suspension holders sit? I want to lower my roll center without buying the +2 suspension holders..
ronP617 is offline   Reply With Quote
Old 02-07-2014, 08:07 AM   #4010
wittyname's Avatar
I did some searching , and seems like only 2 bodies available for this fat girl .... Is that true ? j concepts and the stock body ..
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 02-07-2014, 08:18 AM   #4011
Yes and I also think you can run the XB4 2WD body as well
Tijuana_Taxi is offline   Reply With Quote
Old 02-07-2014, 08:18 AM   #4012
asc6000's Avatar
Trader Rating: 15 (100%+)
"2wd"
at least it looks ok
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 02-07-2014, 08:41 AM   #4013
EricW's Avatar
Yes thats what it is designed for.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 02-07-2014, 09:26 AM   #4014
am
Dt racing from Italy also have made a body :-)
JConcepts
Kyosho MP9
KO PROPO
Top Elite distributor Norway
am is offline   Reply With Quote
Old 02-07-2014, 09:33 AM   #4015
SuperiorHobbies's Avatar
We've been running the car without the shim while using the stock suspension holders. You'll have to file down the RR holder a little bit so it doesn't extend below the chassis. This really seemed to lock in the rear without giving up too much steering. If you're eager for more steering after this, push out the shocks on the rear shock tower.
Supplying all your R/C Racing Needs with over 10,000 items in stock and ready to ship.
www.superiorhobbies.com
SuperiorHobbies is offline   Reply With Quote
Old 02-07-2014, 09:40 AM   #4016
ronP617's Avatar
Thanks I will try that!
Old 02-07-2014, 10:45 AM   #4017
wittyname's Avatar
Wonder why I never thought of the 2wd....
Josh W.
Old 02-07-2014, 11:15 AM   #4018
pekow91's Avatar
Trader Rating: 45 (100%+)
I like the look of the stock one. $10 over priced though.
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 02-07-2014, 12:00 PM   #4019
Trader Rating: 28 (100%+)
I like that body but I can't read the website. I would like to get that body somehow. :-)
Thanks to my sponsors
Proline racing Sidewinder Fuel 4C Hobby Supply Upgrade-Rc Psm-Rc Rcdepot.ca RcAmerica Hudy Xray
kyok2 is offline   Reply With Quote
Old 02-07-2014, 12:16 PM   #4020
That DT looks a lot like the 2WD body, albeit with a dorsal fin...
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
