Like Tree52Likes
Old 02-02-2014, 08:15 AM   #3961
Errokk's Avatar
Has anyone ever tried boiling the front a arms to make them more pliable by chance? I hear this can reduce the likelihood of breakage on minor impacts.
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 02-02-2014, 09:18 AM   #3962
Originally Posted by justinchambers View Post
Is there a 12mm hex conversion for the 4wd
I think the avid guy commented on the thread a few pages back saying they were working on some
evolution03 is offline   Reply With Quote
Old 02-02-2014, 11:10 AM   #3963
seth556's Avatar
Trader Rating: 42 (100%+)
Originally Posted by vr6cj View Post
what traxxes ones are those? slash?
Those are the standard Rustler, Bandit, Slash, etc hexs. Tra1654, $2 and they come with extra cross pins. You'll just need to put a clutch shim behind the pin to take a little slop out. They're also nice because they snap onto the pin so they won't fall off every time you take your wheels off.
seth556 is offline   Reply With Quote
Old 02-02-2014, 11:41 AM   #3964
frito's Avatar
Trader Rating: 59 (100%+)
So wih the 12m slash hexes. Your able to run b4 or what style wheels front and back
rc8b3e
b44.3
bfmce
t5m
radioactive raceway
frito is offline   Reply With Quote
Old 02-02-2014, 12:07 PM   #3965
Errokk's Avatar
Yessir!
I have some if you need some.
Garage:
Old 02-02-2014, 12:22 PM   #3966
seth556's Avatar
On the rear, Kyosho fronts will be 1mm narrow on the front.
Old 02-02-2014, 08:53 PM   #3967
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by aloksatoor View Post
Hey, I am running the following
2014 slipper pads/springs slipper is set pretty loose
5 5 diff
front soft compound rebar rear super soft rebar
1mm rear sway front stock,
durango wheels (the rears are narrow you might be able to replicate with -.75 rear hubs)
2014 xb4 2wd rear hinge pin holders without rear chassis spacer, rear droop 2 turns out on shock bottoms, front full droop 3 dot front 1 dot rear avid pistons of course. Oils 550 F and 350 R.
Hinge pin holders 1 mm offset with hinge pins on the lowest setting RF RR.
Drives like my ebuggy, rear stuck on power with a bit of push, tonnes of steering off power.
Alok, tried something very close to your setup today at delta and the car was way better. The track was bone dry and very slippery. Started out with the Vik setup from Reedy and car was pretty much undriveable. Tried your setup with a couple changes and car was dialed. Very driveable and a lot of forward bite. Was actually able to move the rear hubs back and still had plenty of bite. Ended up with 5k/2k diff fluids, 1.4/1.0 sway bars, and rear camber link out on hub. Also didn't have the 3 dot front springs so I ran losi black 4.1 rate.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-03-2014, 03:36 PM   #3968
Customworksking's Avatar
Trader Rating: 73 (100%+)
has anyone tried making the 2014 car as wide as possible vis hing pins if so how did u like or dislike it?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-03-2014, 06:10 PM   #3969
Trader Rating: 75 (100%+)
Just picked up a new 2014 XB4 to replace my 2013 v2. I wanted to give everyone a heads up on a wear and tear part to keep an eye on. As I was cleaning up my 2013 XB4 for sale, I happened to notice the front center drive shaft had a ton of forward and back play. When I took off the plastic retaining collar where the shaft connect to the universal joint, I noticed the holes in the universal joint were horribly egged out by the pin. I raced this car every weekend since late October on a high bite clay track. I took the front center universal joint apart once in December because I noticed the pin began to walk and tried to protrude through the plastic retainer collar. The pin was slightly worn and I probably should have replaced it but I didn't have any on hand so I put it back together. I don't recall any issues with the universal joint at the time. Two months later that pin has about 50% of the diameter left and the holes in the universal shaft are eaten almost all the way through. DAYAM! The rear center universal shaft is as tight as a drum, retained most of the grease and never once has the pin tried to walk on that end. So keep an eye on your front center universal joint, keep it lubed and replace the pin each time you lube it!
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 02-03-2014, 06:17 PM   #3970
Qwkrn U's Avatar
Trader Rating: 128 (100%+)
1 mm narrow compared to 2013 specs or the 2014 wheels? The 2014 wheels
are 1mm narrower than the 2013.
Wayne Robison
B5m , X-ray XB4 '15 ,xb8e, Scte 2.0
Tiny Boat Guy Paint Designs, Checkered Flag Hobbies, creativecustomtees.com
Qwkrn U is offline   Reply With Quote
Old 02-03-2014, 06:31 PM   #3971
aloksatoor's Avatar
Very cool, theres some other roll center stuff we can compare on both cars saturday (the hinge pin inserts/tower mounting locations as well). Also the new slipper pad/spring rocks! Never tried that low a diff oil on the rear might give it a whack this time!
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-03-2014, 07:56 PM   #3972
Trader Rating: 26 (88%+)
What do you keep these lubed with.....and do you pack it or just a thin film??
jgonz is offline   Reply With Quote
Old 02-03-2014, 08:41 PM   #3973
just curious if anyone has used a 5.0 in there 4wd xb4 just looking for a starting point for gearing
Hot bodies- fantom-Aka
a.seffrood is offline   Reply With Quote
Old 02-03-2014, 09:00 PM   #3974
Errokk's Avatar
6.5t tekin with a 19 pinion and 81t spur is st00pid! Cant imagine a 5t motor. Lol
Garage:
Old 02-03-2014, 09:08 PM   #3975
katana's Avatar
I'll be joining the XB4 family here soon. Purchased the 2014, should be here by end of the week. I've been reading up on here and on Petitrc. If you guys have any tricks, things to watch for during my build please let me know.
Thanks!
katana is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
trick25
