Like Tree44Likes
Old 01-31-2014, 03:39 AM   #3946
onekiwi's Avatar
Originally Posted by Boz View Post
Did you convince Juraj to make some pink colored cups for Malin's cars?
There are red ones available for about $12 as well as black
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 01-31-2014, 06:19 AM   #3947
BentKa's Avatar
They won't match her color scheme Simon…….and that's a big no no for a little lady….
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 01-31-2014, 06:41 PM   #3948
Trader Rating: 41 (100%+)
Send a message via Skype™ to StockRacer
when is the ball diff going to be out?
Ben
StockRacer is offline   Reply With Quote
Old 01-31-2014, 06:55 PM   #3949
joeymdz's Avatar
Send a message via MSN to joeymdz
End of March sources say (in America)
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 01-31-2014, 09:17 PM   #3950
Is there a 12mm hex conversion for the 4wd
justinchambers is offline   Reply With Quote
Old 01-31-2014, 09:58 PM   #3951
jmkalt's Avatar
Anyone else having trouble with the motor mount shifting? A couple weeks ago, my motor shifted causing me to strip my spur gear, and tonight, the motor shifted the other directing, causing the mesh to be too tight.
I love this car, but dislike the came design of the motor mount, tightened only by the one screw. IMO, it's the one design flaw of this buggy, as it seems to me that there is not way to positively clamp it down.
jmkalt is offline   Reply With Quote
Old 02-01-2014, 05:32 AM   #3952
celt's Avatar
The only way I can see the motor shifting in the mount is for the screw to come loose. Being a cam system, the motor would have to be so loose in the mount that it rotated - that's pretty loose.
Is that what happened to you?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 02-01-2014, 06:03 AM   #3953
Errokk's Avatar
I had this very thing happen a couple weeks ago, was caused by a very hard impact with an 1/8th e-buggy during practice. Since, I've cinched the clamp down very tight. Under normal conditions it should not be a problem, nor have I had any other issues with it.
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 02-01-2014, 06:43 AM   #3954
Potoczak's Avatar
Trader Rating: 111 (100%+)
I would put some thread lock on the clamp screw.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 02-01-2014, 08:38 AM   #3955
Customworksking's Avatar
Trader Rating: 73 (100%+)
raced last night car is good now i see y you guys use different springs my track was rough very bumpy kit setup but, i used 2 hole rear pistons and drilled 2mm holes xray 35wt oil
took out.5 of anti sqt i was off by a lap heat 1 by the main i was on pace ..I tried the kit setup 3 hole pistons and the car clearly didn't have enough damping
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-01-2014, 08:56 AM   #3956
Trader Rating: 36 (100%+)
Jason, replace the button head with a cap head screw.
NitroOB4You is offline   Reply With Quote
Old 02-01-2014, 09:15 AM   #3957
jmkalt's Avatar
Thanks, will give that a try
EDIT: Brilliant! I replaced it with a 2.5mm Cap Head and I can really torque it down now. Thanks again!
Old 02-01-2014, 11:01 AM   #3958
advpball's Avatar
Trader Rating: 28 (100%+)
so what is 6 mo old xb4 v2 worth with 160 worth of extras?
xray xb2 de
Johnny 5 designs xsc2
Tekno eb410
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 02-01-2014, 05:55 PM   #3959
vr6cj's Avatar
Trader Rating: 124 (100%+)
Originally Posted by seth556 View Post
I think I've found the 12mm solution, and it's super cheap. Traxxas
Also the wide front hexs in the front and Kyosho front wheels.
what traxxes ones are those? slash?
vr6cj is offline   Reply With Quote
Old 02-02-2014, 03:49 AM   #3960
celt's Avatar
A good point that someone at our local track brought up:
It is possible to install the plate that attaches to the motor face backwards - with the flange facing the motor. I'm told you can install the motor just fine as you normally would, but it wouldn't "lock in" to the motor mount itself.
Not suggesting this is your issue, but something for anyone having an issue might double check.
Stan Garvin
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
