Like Tree39Likes
Old 01-13-2014, 11:33 PM   #3811
Trader Rating: 49 (100%+)
Originally Posted by jamesbernatchez View Post
It's James
Steve's swinging on up Tuesday night for the RB6. Ill have a better idea as to how the buggy is after racing tonight. Looking real forward to it.
Sorry James smh one to many Heinekens
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-14-2014, 04:25 AM   #3812
Trader Rating: 28 (100%+)
I have a 2013 and the rear is very loose. I was reading the forum and was thinking about cutting the rear plastic chassis but I was wanting to make sure before I did this. Anyone have any pics or info on this please.
Proline racing Sidewinder Fuel 4C Hobby Supply Upgrade-Rc Psm-Rc Rcdepot.ca RcAmerica Hudy Xray
kyok2 is offline   Reply With Quote
Old 01-14-2014, 06:08 AM   #3813
BentKa's Avatar
Video from Malin's C-main Leg 3 in 4WD modified buggy @ the 2014 DHI-CUP in Denmark this weekend.
She qualified as #4 on the grid for this C-main (Finals A through F).
Juraj Hudy, Mr. Xray himself is on start #1 in this C-main.
She ended up taking 2nd place in this 3rd leg with Juraj Hudy once again in 3rd spot.
If you are watching this from an iPhone or iPad press the blue banner on top.
+ YouTube Video
She drives the white/pink/light blue Xray XB4.
Her setup:
Xray XB4 '14 4WD
Orca Vritra VXX speed controller
Orca TX 6.5T brushless motor
Orca Infinite Ultra 90C | 6000mAh | 7.4V saddle pack battery
Hitec HS-7940TH servo
Futaba 4PKS-R with 614FF receiver
Scumacher Mini Pin Yellow front & rear
New! 4dotz front springs/900cst oil/1.8 Sway Bar
3 dotz rear springs/700cst oil/1.8 Sway bar
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 01-14-2014, 06:35 AM   #3814
mjk1210's Avatar
remove the rear bulkhead/trans case. remove the carbon shim in the front of it. Cut off the plastic piece on the tail of the chassis. lightly file the alum chassis in the corner where the front hanger will sit. only need a little bit for clearance. maybe 1mm or so. file the "curve" out of the rear "RR" hanger where it sat on the plastic and will now sit on the alum chassis. You will see what I mean when you set it down on the alum. the trans case will sit up a bit if you don't.
Use all the original screws and bolt it back together. Leave the carbon shim out. It's really pretty simple. once you get it apart you will see.
Speed Passion USA - speedpassion.net
Leisure Hours Hobbies & Raceway - leisurehoursraceway.com
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
Old 01-14-2014, 07:40 AM   #3815
Are you also doing something about the lower "hump" on the rear hanger, after you take the rear plastic chassis piece out I would imagine it hangs below the chassis instead of being flush as before.
Tijuana_Taxi is offline   Reply With Quote
Old 01-14-2014, 08:15 AM   #3816
BillyT.'s Avatar
I dremmeled mine off.
Nemo Racing USA
Agama : Bullitt : Beta
[email protected]
BillyT. is offline   Reply With Quote
Old 01-14-2014, 09:13 AM   #3817
fullout's Avatar
Send a message via MSN to fullout
Quick question during build. They call for oil on the outdrive groove and inner diff oring. I can understand oil on the oring but the groove in the outdrive has always been lubed with black grease or maybe green slime. Any advice?
Daniel Weinstein
Xray T4 15, Xray XB8 14, Xray XB4 14, Kyosho TKI 3, Kyosho RB6, Sanwa M12
rcamerica.com
performancehobbies.ca
orcarc.com
fullout is offline   Reply With Quote
Old 01-14-2014, 09:27 AM   #3818
Trader Rating: 24 (100%+)
I used green slime on all the o-rings and outdrives.
jamesbernatchez is offline   Reply With Quote
Old 01-14-2014, 11:17 AM   #3819
monsterbrad's Avatar
does that rear diff modd make that big a difference on dirt? or clay?
monsterbrad is offline   Reply With Quote
Old 01-14-2014, 01:34 PM   #3820
advpball's Avatar
Trader Rating: 27 (100%+)
yea on loose to med traction you can really lay down power off of turns!!
xray xb2 de and xsc2,eb410
eb 48.3 for sale artr 500
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 01-14-2014, 02:34 PM   #3821
aloksatoor's Avatar
Trader Rating: 42 (100%+)
All the guys hacking the older chassis, how does it compare to putting the rear hinge pins at the lowest setting with the hinge pin inserts?
Or are you doing both, lowering the aluminum pieces and also using the lowest hinge pin inserts? Mines pretty hooked on right now on medium clay indoors with just the inserts. Thinking of buying the '14 holders but they are out of stock everywhere.
This might be just armchair engineering, but lowering the diff cups as well, at regular ride height (20mm for me rear), won't the dogbones be more at an angle. Do you guys compensate with higher ride height as well? Cos as it squats on power it will plunge more.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-14-2014, 04:33 PM   #3822
Potoczak's Avatar
Trader Rating: 111 (100%+)
+ YouTube Video
Her setup:
Xray XB4 '14 4WD
Bent
Who makes the wing washers on the buggy??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-14-2014, 05:24 PM   #3823
I'm 99% sure those are the serpent 1/8 wing washers but he will have to confirm that.
Old 01-14-2014, 07:49 PM   #3824
Trader Rating: 36 (100%+)
Got a couple practice packs through mine today. Didn't have enough folks to race ( same track as JamesB ) but what little I did run tonight, so far it felt very, very good. Looking fwd to Fri night
NitroOB4You is offline   Reply With Quote
Old 01-15-2014, 01:33 AM   #3825
BentKa's Avatar
Bent
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
