Like Tree39Likes
Old 01-11-2014, 08:20 PM   #3781
Trader Rating: 48 (100%+)
Quick questions I'm looking to get 3.5 toe in . Which position should I put the bushings into
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-11-2014, 10:03 PM   #3782
Trader Rating: 24 (100%+)
Issue? My chassis doesn't have the molded in screw holes to run the battery wires. This seems odd.
jamesbernatchez is offline   Reply With Quote
Old 01-11-2014, 11:54 PM   #3783
Errokk's Avatar
I dremeled mine out due to them just being in the way. Saw no real use for them.
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 01-12-2014, 05:50 AM   #3784
advpball's Avatar
Trader Rating: 27 (100%+)
Ran mine 13 last night with rear tranny mod of cutting off the plastic on chassis,
very much improvement, can grab throttle coming off of tight corners.Developed slight push but can live with that.just gotta concentrate on better driving. lol
xray xb2 de and xsc2,eb410
eb 48.3 for sale artr 500
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 01-12-2014, 06:38 AM   #3785
monsterbrad's Avatar
lets see pics of that modd you did with the back please
monsterbrad is offline   Reply With Quote
Old 01-12-2014, 06:46 AM   #3786
advpball's Avatar
just cut plastic chassis off under rear diff..just leaving aluminum chassis..
drops rear diff down,sorry no pics available.
Old 01-12-2014, 06:55 AM   #3787
hummm maybe a running change? 2014 chassis right? i cut mine off by the esc.
auto2 is offline   Reply With Quote
Old 01-12-2014, 06:59 AM   #3788
your talking about the 2013 chassis? the 2014 chassis has a plastic spacer there that you just remove and buy the new hinge pin holders (or grind down the stock ones to sit flat)
Old 01-12-2014, 07:15 AM   #3789
Fabulous's Avatar
Trader Rating: 42 (100%+)
That's the XB4 2wd chassis.
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 01-12-2014, 07:43 AM   #3790
advpball's Avatar
yes 2013 chassis
Old 01-12-2014, 11:10 AM   #3791
Pintopint's Avatar
yes 2WD Chassis multi servo position setting
Pintopint is offline   Reply With Quote
Old 01-12-2014, 03:04 PM   #3792
You think it matters its a 2wd chassis? I don't care about the posts as long as the geometry is correct.
Old 01-12-2014, 05:19 PM   #3793
Potoczak's Avatar
Trader Rating: 111 (100%+)
What pinion are you running? Going to be running the same motor.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-12-2014, 05:27 PM   #3794
seth556's Avatar
I usually run 20/84 or 19/81 with my Reedy 6.5t
seth556 is offline   Reply With Quote
Old 01-12-2014, 05:28 PM   #3795
Errokk's Avatar
I run a Tekin 6.5t and I run a 19t pinion. Plenty fast for my indoor track with no timing in it. Track has approximately a 70' straightaway.
Garage:
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
