Like Tree44Likes
Old 01-04-2014, 11:11 AM   #3751
monsterbrad's Avatar
sounds good I am running a 19 on a 7.5 and its working well
it gets a bit warm but the speed is nice
monsterbrad is offline   Reply With Quote
Old 01-04-2014, 06:05 PM   #3752
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Xray XB4 wheels & tire sale posted
Xray XB4 wheels and tires
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 01-05-2014, 02:08 PM   #3753
Trader Rating: 65 (100%+)
Which servo's are you guys using?
nrm1977 is offline   Reply With Quote
Old 01-05-2014, 02:20 PM   #3754
Errokk's Avatar
I use a Savox 1251mg. Works great.
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 01-05-2014, 10:38 PM   #3755
Trader Rating: 24 (100%+)
Double post
jamesbernatchez is offline   Reply With Quote
Old 01-05-2014, 10:38 PM   #3756
Ran my XB4 for the first time and really liked it. I decided to try an S-Workz molded wing and ordered a few more as I really like the look and quality of it. Much better than the lexan wings I normally run on my buggies.
I ended up bending my rear front hinge pin holder and breaking the inserts on one side. Front a-arm and hinge pin were ok. Bent the holder back and changed to the 1 inserts and was fine the rest of the day. Coming from a B44.2 with gear diffs it was familiar to drive.
I found the XB4 to jump a bit better and drive a bit smoother. It had less steering than I wanted, but for my first time out without any practice I was very close to my fastest lap with the B44.2. (15.1 with the B44.2 vs 15.4 with the XB4). With more tuning and driving I think it will end up being just as good.
This is the older model. I have the 2014 coming in hopefully this week.
I plan to keep this one as is, with the only change shortening all the wiring to just what I need it to be, plus a 1/4 of an inch or so. This will give it a much cleaner look.
Here's the track layout:
Old 01-06-2014, 09:01 AM   #3757
joeymdz's Avatar
Send a message via MSN to joeymdz
Easy fix... this car has tons of steering! what set up are you running
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 01-06-2014, 09:09 AM   #3758
I'm running pretty much the kit setup. Car feels good just looking for a little more on power steering running 7-3 in the diffs. Where should I look to first without giving up rear traction
Xb4
Rcexcitement
Maximus Rc Raceway
Sponsored by the one and only SBRD Racing
lonslo is offline   Reply With Quote
Old 01-06-2014, 09:19 AM   #3759
seth556's Avatar
Trader Rating: 42 (100%+)
Lower the front roll center, use the arm bushings to move the front arms down. You can also go up in rear oil a tad, that should help as well, it won't be so quick to put all of it's weight on the outside rear tire.
seth556 is offline   Reply With Quote
Old 01-06-2014, 01:12 PM   #3760
Smile
where did you get the wing?
i likey
Old 01-06-2014, 02:14 PM   #3761
aloksatoor's Avatar
i likey
schumacher maybe?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-06-2014, 02:26 PM   #3762
Trader Rating: 36 (100%+)
i likey
Looks just like this SWorkz wing to me.
http://www.amainhobbies.com/product_...ear-Wing-Black
ufoDziner is offline   Reply With Quote
Old 01-06-2014, 04:00 PM   #3763
This...I even mentioned what wing it was in my post.
Old 01-07-2014, 03:57 AM   #3764
English365's Avatar
Trader Rating: 128 (100%+)
If anyone has their car apart already, could you provide a measurement for me? I need the width of the gear diff assembly from the outer bearings, as well as the width of a diff case/bulkhead bottom. Thanks in advance!
Kyosho America~Thunder Power~Team Orion~KO PROPO~AKA
Mikes Hobby Shop...TeamTreeTop!
English365 is offline   Reply With Quote
Old 01-07-2014, 12:25 PM   #3765
BillyT.'s Avatar
FYI, if you are having problems with the pins coming out of the plastic pin holders, I have a solution...
TD parts are a direct fit. Set screws in bushing and flat spots on pin. cheap too.
TD310113 and TD310120
Maybe this was already covered... doesn't hurt to post again.
Nemo Racing USA
Agama : Bullitt : Beta
[email protected]
BillyT. is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
