Like Tree52Likes
Old 01-01-2014, 01:32 PM   #3721
Trader Rating: 54 (100%+)
I decided to due a little TLC to my buggy today. I decided to clean her up. Not really that dirty i decided to play with the shock oils. I have to say the shocks were dirty on the inside. The rear especially. I have only driven the car for less then 1 hr in total (One race day and One Practice night). I cant believe they are that dirty. My Kyosho shocks look brand new compared.
Speedychris22 is offline   Reply With Quote
Old 01-02-2014, 04:43 PM   #3722
JOJOHAMBONE's Avatar
Trader Rating: 31 (100%+)
Hey Guys I was building my 2014 Spec and when I put the rear bottom shock screws on they would not go through the shock rod end??? Any ides? And has anyone else had this?
Thanks,
BM
Blake Morris
-521 Designs-Tony's Hobby+Video-R&L R/C Products-Richards and Lees Cabinets-
**2014 XB4**Tekin RSX, REDLINE 5.5t, Protek Servo, Revtech Formula X Batteries
JOJOHAMBONE is offline   Reply With Quote
Old 01-02-2014, 04:43 PM   #3723
Thanks,
BM
Sorry double post
Blake Morris
Old 01-02-2014, 05:45 PM   #3724
[QUOTE=JOJOHAMBONE;12867113]Hey Guys I was building my 2014 Spec and when I put the rear bottom shock screws on they would not go through the shock rod end??? Any ides? And has anyone else had this?
Thanks,
BM
so your saying the screw is too large in diameter to fit in the shock end?
can you post a pick? that is odd.
auto2 is offline   Reply With Quote
Old 01-02-2014, 06:50 PM   #3725
jmkalt's Avatar
Thanks,
BM
This happened to me on my '13 model. The screw isn't lining up with the hole in the arm.
It's not the shock end like you think, even though it feels that way. Demonstrate this to yourself by passing the screw through the shock end while it is not in the arm. It should go through freely.
What you need to do now, is put the shock back into position in the arm and push the screw in as far as you can. If you watch closely you will see that it does indeed pass through the metal tube in the eyelet. At that point, the end of the screw will be just above or below the hole in the arm at the opposite side. Take a flathead screwdriver and, while simultaneously turning the screw with your hex driver, push up or down (as the case may be) on the end of the screw itself to direct it into the hole.
That should do the trick.
jmkalt is offline   Reply With Quote
Old 01-02-2014, 06:54 PM   #3726
Actually it is the shock end the screw goes halfway through it and stops and is stuck it is really weird
Blake Morris
Old 01-02-2014, 07:03 PM   #3727
bill marchant's Avatar
Trader Rating: 229 (100%+)
Send a message via Yahoo to bill marchant
Just picked up the 2014 spec any good suggestions, or links to good base line setup
Hobby Pro USA, Agama
PRS1 buggy D3 13.5/Hobbywing
Novarossi/savox
BRUCKNER HOBBIES For All your RC needs 2 FEED YOUR ADDICTION!!!
BARNSTORMERS RC/Gun Hill Racing
bill marchant is offline   Reply With Quote
Old 01-02-2014, 08:29 PM   #3728
Originally Posted by bill marchant View Post
Just picked up the 2014 spec any good fetus suggestions or links to good base line setup
Hi Bill great to see another xb4 locally. I would start with Martin Bayers euro winning setup.
Old 01-02-2014, 08:39 PM   #3729
Trader Rating: 15 (100%+)
...then my guess is that the screw has 'caught' in the eyelet somehow, likely having cut into it while you were screwing it in and will not pass thru it anymore. Use pliers to hold the eyelet and unscrew it to get it out. You may need a new eyelet.
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is online now   Reply With Quote
Old 01-02-2014, 11:11 PM   #3730
I got it out and used a new screw and it was perfectly fine, the same thing happened on my 2013 spec>>>> At least its fixed! I will post some pictures when I get the electronics in!
Thanks!!
BM
Blake Morris
Old 01-03-2014, 12:03 AM   #3731
Trader Rating: 39 (100%+)
Raced my 2014 yesterday it was awesome with the stock clay setup. Super durable as well. The b44s were dropping like flys out there :-)
1000rrstunna is offline   Reply With Quote
Old 01-03-2014, 06:40 AM   #3732
Potoczak's Avatar
Trader Rating: 112 (100%+)
Where can I find Martin Bayers euro winning setup??? Thanks
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-03-2014, 07:39 AM   #3733
http://www.petitrc.com/setup/xray/se...lid2013071820/
Old 01-03-2014, 07:44 AM   #3734
Just as a heads up to anyone else who's seen them on that other site that sells things....those XB4 machined pistons from that company in Macau, they are only ok. I asked them to make me 2 hole 1.6 & 2 hole 1.7's. And they did. Two isssues however, 1) if you buy a set of 1.6's and 1.7's - they have no markings on them to tell you which is which, so don't mix them up. 2) They are the same size as the stock pistons - so ya, they are a little smallish inside the shock body with the same "blow by" as the stock pistons. I wrote them to tell them to measure up a set of Avids, so we'll see if they improve. They offer a ton of different sizes and hole combinations, even tappered pistons. Oh, and they took 4 weeks in the mail.
Daragh Slowey
Old 01-03-2014, 07:52 AM   #3735
Potoczak's Avatar
Thank you!!!
Pete Potoczak
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
