Like Tree36Likes
Old 12-31-2013, 04:19 AM   #3691
Do we have a date when the +2 hangers will be available?
* HobbyWing of N.A. * Nitrohouse *M.I.P.*Proline * Carl D. *
Losi57 is offline   Reply With Quote
Old 12-31-2013, 04:54 AM   #3692
Trader Rating: 48 (100%+)
Amain has them. They added several 2014 parts.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 12-31-2013, 06:52 AM   #3693
their on my car :-) ron got them. with the rear diff lowered its even better! has a small push into the turn and too much throttle past the apex gives a med overstear out of the turn. just what i want.
auto2 is offline   Reply With Quote
Old 12-31-2013, 09:05 AM   #3694
Ben are u running the plastic in between or no plastic
My Credit Card
Old 12-31-2013, 09:22 AM   #3695
BillyT.'s Avatar
I pulled the shim out of mine last night. Still running the std hanger, just sanded the "fangs" smooth with the chassis.
Didn't get to run it too much, though. Track was hectic last night. Be nice when the holiday break is over.
Nemo Racing USA
Agama : Bullitt : Beta
billy@nemoracingusa.com
BillyT. is offline   Reply With Quote
Old 12-31-2013, 10:23 AM   #3696
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rcgod View Post
Anyone have a setup for low bite? Car has plenty of steering but the rear wants to come around on power. Running the kit setup, also tried 1 dot rear springs not much better.
Check that your shocks are all equalized. My car was straight as an arrow on power until my last run- found that the front shocks sucked in a little air over time and had uneven rebound.
You also might try shortening wheel base, go up 1k heavier rear diff oil, 1 step more rear toe, remove the rear sway bar or move rear shocks lower inner holes and front shocks lower outer hole.
Much kudos to the Xray team on the XB4- such an easy to drive fast, durable buggy and so easy to work on too
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-31-2013, 11:02 AM   #3697
JOJOHAMBONE's Avatar
Trader Rating: 31 (100%+)
Just wanted to say I am building my 2014 Xb4 and this is an amazing kit!!!!! I loved my 2013 now I cant wait to get the 2014 on the dirt!!!!!
Blake Morris
-521 Designs-Tony's Hobby+Video-R&L R/C Products-Richards and Lees Cabinets-
**2014 XB4**Tekin RSX, REDLINE 5.5t, Protek Servo, Revtech Formula X Batteries
JOJOHAMBONE is offline   Reply With Quote
Old 12-31-2013, 11:22 AM   #3698
no plastic shim. you remove it and the fibre spacer on top. same screws though.have to reset the camber links after.
the barn track is being redone as we speak. new track for friday night:-)
Old 12-31-2013, 12:35 PM   #3699
monsterbrad's Avatar
have to agree on that post about this car being great
I have been in this hobby over 20 years and have raced everything and run all the monster trucks on the market
This buggy outa the box is great wish i could buy another 1 and build it
monsterbrad is offline   Reply With Quote
Old 12-31-2013, 12:46 PM   #3700
So.. If I remove the plastic between the chassis and rear diff... and file down the stock rear hangers it will increase the rear traction? Does anything else need to be done?
Website: http://michaelsasher.com
masher81 is offline   Reply With Quote
Old 12-31-2013, 02:19 PM   #3701
joeymdz's Avatar
Send a message via MSN to joeymdz
I was going to file down my hangers until a previous post said you can buy the new ones from a main.. $50 bucks later and a Monday delivery I'll be set.
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 12-31-2013, 03:19 PM   #3702
I emoved the plastic peice and fitted a brass plate , as a weight ( i said about this a couple of pages back ) tried it on sunday on a frosty start , then wet astro track and it was alot better , but it had a bit of push .. was alot better behaved tho !!
xray xb4 and xray t4'14 ...
shaun207 is offline   Reply With Quote
Old 12-31-2013, 03:25 PM   #3703
Blown up's Avatar
Anyone know the width of the stock rear hex's? Trying to figure out why my 13 has alot more thread's showing on my rear axle stub then my buddies 14 w/wheels + nuts on...
XB4 RSpro/LRP 7.5 JR9000s, SCTE 2.0 RX8/Pro46 DS1015, SC10.2 RS/D3.5 17.5 DS1015,
Blown up is offline   Reply With Quote
Old 12-31-2013, 03:48 PM   #3704
Blown up's Avatar
just found this on xray's FB page for those that have ?'s on what the hangers and 2mm shim do,
Xray Racing Cars
December 20
#363313 Brass Rear Lower Suspension Holders +2mm
• Brass lower suspension holders
• Additional weight
• Lowered CG
• Improved traction
• Increased stability
• I.S.S.™
• Quick & easy geometry setting
• CNC-machined
Optional brass lower suspension holders for XB4 cars provide additional weight down low to improve traction and stability while lowering the car’s CG. The suspension holders feature Integrated Suspension Settings™ (I.S.S.) which allows for quick & easy suspension geometry setting. This XRAY concept was first introduced in the original XB8 and now has been carried over to the 1/10 scale XB4. The holders are +2mm and fit both XB4 & XB4 2WD. Set of 2 pieces.
XB4 suspension geometry can be completely adjusted using eccentric suspension bushings inserted into suspension blocks, as well as using additional suspension shims.
In the XB4 2WD, the suspension holder is used without the rear lower composite chassis plate and is mounted directly to the aluminum chassis.
On the XB4, the suspension holder can be mounted in two different ways:
1. Mounted on the rear lower composite chassis plate which increases roll center by +2mm. This improves the rotation of the car in corners.
2. Without the rear lower composite chassis plate, mounted directly on the aluminum chassis. This is recommended for low-traction tracks. — with Bruno Coelho and 12 others.
Old 12-31-2013, 05:56 PM   #3705
ps71's Avatar
The axle stub is shorter on the 14
Losi 22 2.0 xerun 120a v3.1 6.5t
Xray xb9e w/tekin rx8 gen2 1900kv t8
Spectrum dx3s
ps71 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
