Like Tree44Likes
Old 12-28-2013, 11:29 AM   #3676
ps71's Avatar
Originally Posted by big chris View Post
Any of you super smart guys know all the part numbers to convert a XRAY xb4 2wd to the XB4 2014?
361160 1
364170 1
902305 1
361100 1
364900 1
365420 1
365230 3
980210 3
365440 1
365470 3
940510 1
940815 1
365114 1
902306 1
365320 2
980210 4
365240 2
940510 2
940512 2
I think that should be it..
Losi 22 2.0 xerun 120a v3.1 6.5t
Xray xb9e w/tekin rx8 gen2 1900kv t8
Spectrum dx3s
ps71 is offline   Reply With Quote
Old 12-28-2013, 11:43 AM   #3677
GregerL's Avatar
Originally Posted by hobdog View Post
I'm looking for some advice guys. Let's start off by saying this car ( 2013 xb4) is real good and consistent compared to many of the other 4wds if owned. I am currently running the Martin Bayer setup on high bite clay track. The only changes I have to the suspension are avid pistons (1.6front and rear) and associated green rear spring.
The complaint I have about this car is it jumps horrible. It is a constant situation of either having to bring the nose down in the air or gassing it to bring it up to level things out. Now before people jump on me and tell me how to drive\jump, I am not a rookie and my original racing roots are from 1\8th scale nitro which requires much more jumping ability and control in the air. I almost wonder if the strong points of this car driving a lot like a sedan which I believe is partly because of the lack of droop are its weakness when it comes to jumping and landing. The best way I can describe it is some cars are very "cat like", meaning they tend to want to level out and land nice on all fours. Has anyone else had this complaint that has found a way to make it jump better.
We had the same issue when we got our kit and it was configured with two hole pistons it was improved a lot when we switched to the three hole set up. Obviously it should be possible to make it work with a two hole configuration, but this was the solution for us. I have since gone to the 2x1.1 + 2x1.6 configuration in the rear, and it still jumps well.
GregerL is offline   Reply With Quote
Old 12-28-2013, 12:11 PM   #3678
joeymdz's Avatar
Send a message via MSN to joeymdz
Hoby, are you racing on Thursday? If so lets swap cars and I want to see what's going on with yours
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 12-28-2013, 09:18 PM   #3679
Potoczak's Avatar
Trader Rating: 111 (100%+)
What starting setup would you guys recommend for medium bite smooth clay??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 12-29-2013, 05:10 AM   #3680
check to see if your axles are plunging too far into the diff cups on full compression. i have a 2014 and it jumps perfect. so good i dont even care how i hit a jump but one jump if i undershoot it and land just on the downhill crest the car goes crazy and flips over and barrel rolls. i think the axles were binding the diff cups and locking up at the same time the rear chassis slaps the ground. i changed the offset plastic bushings to the dot out position so my track is wider and now the axles wont bottom out. havnt tried it yet but im gonna go today and hit that jump the same way and report back.
ok just got back and now i can land that jump anyware i want to and it lands perfect. problem solved.
auto2 is offline   Reply With Quote
Old 12-29-2013, 10:44 PM   #3681
big chris's Avatar
Trader Rating: 50 (100%+)
Thanks.
B6 Carpet
B6 Clay
B6D dirt
SC5M
big chris is offline   Reply With Quote
Old 12-30-2013, 06:08 AM   #3682
rcgod's Avatar
Trader Rating: 27 (100%+)
Anyone have a setup for low bite? Car has plenty of steering but the rear wants to come around on power. Running the kit setup, also tried 1 dot rear springs not much better.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-30-2013, 07:22 AM   #3683
mjk1210's Avatar
is this the 2013 car or the new one? removing the composite piece on the old chassis and dropping the trans onto the aluminum made quite a difference. you may want to try that. you need to remove the carbon shim from the front of the bulkhead mount as well. the stock screws all still fit just fine.
I'd rather be fishing!
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
Old 12-30-2013, 07:36 AM   #3684
rcgod's Avatar
It's the new car. I also think part of the problem is I installed the carbon battery straps and that made the rear of the car stiffer. I thought if you took the spacer out in the back the +2 rear mounts were required to make it work.
Dialed RC Hobbies
Old 12-30-2013, 08:03 AM   #3685
jhanlon's Avatar
Does anyone know if the new wider offset front wheels are a running change or a different part number? I looked at the exploded view and it seemed to be the same part number. I want to get some new wheels but would like to keep the offset the same as the 2013 wheels.
Oregon State Fire Marshal.
jhanlon is offline   Reply With Quote
Old 12-30-2013, 09:39 AM   #3686
tufferwilde's Avatar
Running change. Same part #
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 12-30-2013, 02:30 PM   #3687
What did u do with the bushings setup?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 12-30-2013, 04:02 PM   #3688
mjk1210's Avatar
kept the stock hangers and martin bayer setup.
Old 12-30-2013, 04:53 PM   #3689
Awesome I will try that, bc I don't think those +2 holders work.
My Credit Card
Old 12-31-2013, 01:45 AM   #3690
am
The Xb4`14 is amazing, and very easy to drive!! Lets see how it holds up :-)
JConcepts
Kyosho MP9
KO PROPO
Top Elite distributor Norway
am is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
