Like Tree52Likes
Old 12-22-2013, 04:33 PM   #3631
joeymdz's Avatar
Send a message via MSN to joeymdz
And how big is your track and what gearing are you running?
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 12-22-2013, 04:46 PM   #3632
Trader Rating: 54 (100%+)
18/81
Here's the link for the vid of the track
http://youtu.be/Gn3C1yQ5_J8
Also thanks for the help
Speedychris22 is offline   Reply With Quote
Old 12-22-2013, 07:07 PM   #3633
monsterbrad's Avatar
ran mine yesterday man I need to practice
but the car ran perfect the entire time and other then gearing it down to 18 to keep heat down it was great
handles awesome and is very smooth
have to try it again and see what happens
thanks to all you guys on here that helped me in all the reading
monsterbrad is offline   Reply With Quote
Old 12-22-2013, 10:06 PM   #3634
joeymdz's Avatar
Originally Posted by Speedychris22 View Post
18/81
That's a big indoor. It almost looks like a Rebar, holeshot, impact, or even a green barcode tire.
I would play with the EPA settings and turn down the initial punch. Also run no to low drag brake. And with a 6.5 you really don't need any Turbo or boost (my opinion).
I have the same amount of rip as the 6.5's
I'm geared 23/84 with a 7.5 Orion vst. And I have my curve turned down
Old 12-22-2013, 10:53 PM   #3635
Ok thanks def going to take your advise before I switch diff oils. I'll let u know how it goes.
Old 12-22-2013, 11:18 PM   #3636
joeymdz's Avatar
I would also try different diff oils so you can see first hand how it drives. Maybe it will work for you with your driving style?
But I would do the EPA first.. then play around with diffs
Good luck
Old 12-22-2013, 11:18 PM   #3637
joeymdz's Avatar
Old 12-23-2013, 04:06 AM   #3638
rcgod's Avatar
Trader Rating: 27 (100%+)
What surface type are u running on? Also are u running the +2 mounts?
Tacky clay. Used gold barcodes or clay suburbs.
I'm running the car bone stock with rear spacer in.
I guess what I'm asking is the reason for the +2 mounts. I keep reading that guys using them are having issues with the rear end being loose.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-23-2013, 09:39 AM   #3639
That is the issue that I have. I think im also going to take off the the +2mounts and try the regular
Old 12-23-2013, 09:51 AM   #3640
Hard packed bumpy low traction, double dees are the tire of choice. One guy is running the same car with 5 f 2 rear stock setup nd his looks more planted, but he is running a 10.5 motor. I'm using a 6.5.
My car was perfect.I'm.not changing anything.but I think the 10.5 motor has a lot to do with it.I'm going today if you want to try it.the rear never got loose it had a tiny push entering the turn .very easy to drive.ions were hooked up .maybe cause I had a 10.5 cause no one else was using them.
auto2 is offline   Reply With Quote
Old 12-23-2013, 09:53 AM   #3641
mjk1210's Avatar
until recently I was running the car the same way. I was also on tacky clay. Now that the cold weather has come into Chicago the track is getting drier and drier. I took the composite piece off the rear of the chassis and dropped the gearbox down. wow. quite a difference in the amount of power I can put down through the middle and exit of a corner.
I'd rather be fishing!
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
Old 12-23-2013, 10:44 AM   #3642
joeymdz's Avatar
Are the New rear hangers available yet? I really don't want to purchase the old/stock ones, bust out the dremel, then a few days later the new lower hangers are available
Old 12-23-2013, 11:07 AM   #3643
Thanks Ben, I cant make it tonight but Steve wants to setup a race for Thursday. You should come.
Old 12-23-2013, 11:08 AM   #3644
Old 12-23-2013, 11:10 AM   #3645
I got them. I went to my hobby shop and had him order them for me. Right now I am running the +2 hangers with the spacer in between. Should I remove the spacer?
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
