Like Tree52Likes
Old 12-22-2013, 10:19 AM   #3616
Trader Rating: 55 (100%+)
I ran my wheeler last night with bayers euro setup with avid pistons nd plus 2 holders, with 5k front 3rear, the car felt loose with a tone of steering, I'm going to try 7k front 5 rear to see if that helps. Also on one jump I kept on nose diving but I think I had to much drag brake.
Speedychris22 is offline   Reply With Quote
Old 12-22-2013, 12:09 PM   #3617
am
Originally Posted by BentKa View Post
I like how you (and several others) refer to it as a "problem"
Keep the joints lubricated and keep the dirt out.
This isn't brain surgery.
Same thing you would do on any race vehicle no matter the scale
The Exotek cups are quality items and adds a bit of bling if you opt for the orange (have had them on the work bench for "a few months now")…..but they are far from a necessity and should never be used as a band aid for lack of 2-3 min. maintenance
Bent
It is not a band aid. It called being smart and fix something Xray should have implemented in the firstplace. They have them on their XB9 center CVD`s, same principle just done different :-)
If you have the Exotek cups, it will/can not happend. You put it on as a safty feature and eliminate something that can go wrong.
JConcepts
Kyosho MP9
KO PROPO
Top Elite distributor Norway
am is offline   Reply With Quote
Old 12-22-2013, 12:30 PM   #3618
BentKa's Avatar
Yep……nothing wrong with HeavyD99's approach
My remark was aimed at the constant reference to this being a "problem", when it's just a lack of maintenance from those experiencing this.
Potensial buyers and current owners new to this are getting the impression that they need to go out and buy parts to get rid of the "problem" when all they need to do is just regular maintenance
Bent
Again…..not a "problem" for those who actually do the little maintenance required
And as you can see from the quoted post my initial grief was the constant referral to this being a "must buy" item for those contemplating to buy the XB4 for the first time.
It's NOT !
If you want to buy it for the bling or the peace of mind knowing you will neglect the required maintenance then by all means……buy it
You bought the XB4 yet to get some first hand experience and knowledge ?
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 12-22-2013, 01:01 PM   #3619
joeymdz's Avatar
Send a message via MSN to joeymdz
I run 0 drag brake unless I'm on carpet. Going thicker on the diffs will not help you with traction. What surface are you running on and what tires? I've been using the Bayer set up for awhile now from loamy to high bite clay.. only changing my tires, throttle punch, and throttle curve.
When I went thicker on the diffs it made the car too snappy and it was a real handle to work with. I have 3 extra diffs to experiment but I keep on going back to 5f/3r
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 12-22-2013, 01:12 PM   #3620
am
I think that happend to two or three cars at Mustit today, so yes, i do not own one, but i have first hand experience. :-)
It is like driving a car with ESP, airbags or Pre-sense. You do not have to buy that car with that equipment, but boy, i am shure glad you did when the accident suddenly and unexpected happend ;-)
JConcepts
Kyosho MP9
KO PROPO
Old 12-22-2013, 01:42 PM   #3621
BentKa's Avatar
That wouldn't be first hand experience as I'm sure you're not the one doing the maintenance on those
And comparing avoiding an accident by the use of safety systems to skipping regular maintenance is kind of a stretch don't you think………but blaiming the manufacturer for a faulty tire when you haven't checked the air pressure in months would be more on the point ;-)
We've been racing 3 of these for a year now and no signs of any pins wanting to protrude any plastic covers…….but I'm guessing we're just lucky…….OR ?
And I actually prefer to drive the car myself instead of being in the hands of all sorts of electronic gadgets trying to "help" me
But that could just be me seeing I've been racing 1:1 vehicles on and off since the age of 10
All that aside……NO you don't NEED to buy these CVD cups to enjoy a problem free XB4 ownership…….which has been my point the entire time
If you want to save the cost of these just clean and add some grease to the CVD joints and all will be fine
Bent
Old 12-22-2013, 01:53 PM   #3622
joeymdz's Avatar
Hey bent thanks for all the advice!!
Old 12-22-2013, 02:28 PM   #3623
Hard packed bumpy low traction, double dees are the tire of choice. One guy is running the same car with 5 f 2 rear stock setup nd his looks more planted, but he is running a 10.5 motor. I'm using a 6.5.
Old 12-22-2013, 02:30 PM   #3624
advpball's Avatar
Trader Rating: 28 (100%+)
Ive been running mine with little to no maintenance for 8 weeks and only problem was set screw came loose…so time for a little cleaning and lubing.Tire ware seem to go up on higher diff oils...
xray xb2 de
Johnny 5 designs xsc2
Tekno eb410
all powered by smc battery's and Motiv motors
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 12-22-2013, 02:44 PM   #3625
rcgod's Avatar
Trader Rating: 27 (100%+)
What's the point of the 2mm suspension mounts? Raising the roll center 2mm is a huge change. I understand you dont want to run without the rear spacer without raising the inner arm mount because you will lose cvd plunge and make the car looser on power. Why not use the stock hangers and raise the rc with the inserts? Ran mine yesterday for first time on indoor clay track with stock setup and was loose on power. Tried 7k/3k fluids and car was hooked up on power but way too aggressive off power. Went back to 10k front and car was perfect. Had steering dual rate backed off to 75% and car was on rails. Like driving a touring car on dirt. Love this car!
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-22-2013, 03:28 PM   #3626
joeymdz's Avatar
What esc settings are you running and your EPA? That's allot of motor for a loose track if your settings are high
I'm running an 7.5 with the Orion at punch 3, throttle curve at -13%/75 (mt-4), steering rate at 80%
Old 12-22-2013, 03:41 PM   #3627
What surface type are u running on? Also are u running the +2 mounts?
Old 12-22-2013, 03:49 PM   #3628
mjk1210's Avatar
I don't discount your luck, but if the alum cups reduce a chance of a DNF, then they should be used. still the best car out there and if this is the biggest problem people are having now, well, that's not so bad.
I'd rather be fishing!
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
Old 12-22-2013, 04:02 PM   #3629
mjk1210's Avatar
Agreed. if the track is very large and you need the top end, you can try to gear up and turn the EPA way down. it will actually soften the bottom end too but still get some top speed that way because of the gearing. or change to less motor. 6.5 is a lot of motor to run at full rip on anything less than pretty good traction. play with other ESC settings too. punch, boost, or any of that stuff.
I also agree on the diff oils. After going down to 5 and 3 I haven't wanted to change back to thicker oils. If I am running slicks on clay or on super high bite again, I probably will. But anything less than that and it just isn't as good.
Old 12-22-2013, 04:18 PM   #3630
I'm running orion as well, punch level 3 no boost and turbo at 4, neutral range at 6%. I have a very smooth throttle finger. I'll try to turn the dual rate down.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
