Like Tree52Likes
Old 12-20-2013, 08:54 AM   #3601
lots of new goodies coming from Xray for the XB4
http://tqpros.com/kit/xray_xb4/hopup...on_Holders_2mm
and
http://tqpros.com/kit/xray_xb4/hopup...sis_Weight_20g
nicmo is offline   Reply With Quote
Old 12-20-2013, 01:46 PM   #3602
Trader Rating: 54 (100%+)
Originally Posted by nicmo View Post
That is some nice bling right there!!
Speedychris22 is offline   Reply With Quote
Old 12-21-2013, 10:34 AM   #3603
EricW's Avatar
Anyone know which servo horn that comes with the 2014 kit fits the spectrum 6040 servo? The servo is 23 spline, the kit has horns F, H, K.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 12-21-2013, 10:45 AM   #3604
Trader Rating: 36 (100%+)
Pretty sure it'd be H.
Futaba 25
Hitec 23
K.O 24
NitroOB4You is offline   Reply With Quote
Old 12-21-2013, 10:53 AM   #3605
rcgod's Avatar
Trader Rating: 27 (100%+)
Airtronics/KO are 23t
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-21-2013, 11:01 AM   #3606
DERP!
Oops. Sorry, RCGod is correct.
Hitec is 24
Air, KO, and I believe JR also are 23.
Old 12-21-2013, 11:18 AM   #3607
EricW's Avatar
**** "Luxury" ****
Old 12-21-2013, 12:37 PM   #3608
I need help. I always run my xb4 on dirt tracks but im going to try a new track by me that is carpet, big question what tires do you use. I have slicks would they work.
billsharp34 is offline   Reply With Quote
Old 12-21-2013, 02:20 PM   #3609
Schumacher "Mini Pin" 2.2 yellow front and rear, cut the outside pins of the front tyres if you get too much steering, that you probably will.
Old 12-21-2013, 03:40 PM   #3610
mjk1210's Avatar
those dboots tires can be pretty good too. the medium compound will last longer but have less grip. the softer compound will be really hooked up but wear faster. I think Nanobytes or terabytes are the names.
I'd rather be fishing!
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
Old 12-21-2013, 09:33 PM   #3611
How much drag brake are you guys running on your cars?
Old 12-22-2013, 08:11 AM   #3612
mjk1210's Avatar
Drag brake is very much a personal preference kind of thing. With that being said, I am at 5% on my Speed Passion esc.
Old 12-22-2013, 08:36 AM   #3613
I was running 12 and felt it was to much. Thanks
Old 12-22-2013, 09:29 AM   #3614
Blown up's Avatar
There was a couple '14's at our track last night and they looked real good. My '13' was hooked in the second heat and mains after I removed the 2mm plastic under gearbox w/stock hangers dremeled, also went lighter in rear shock fluid so the car rebounds evenly F+R when dropped on the bench. The rear always seemed slow w/stock setup. I went w/1.3x3's all around, 3 dots w/AE 40wt.F and 2 dots w/AE 25wt.R, I also turned servo speed down to 75% on my DX3R, What a difference!
After seeing the '14's in person I can see how much narrower the old style rear wheels are. Anyone know if the narrow offset wheels will still be available or are they a running change?
XB4 RSpro/LRP 7.5 JR9000s, SCTE 2.0 RX8/Pro46 DS1015, SC10.2 RS/D3.5 17.5 DS1015,
Blown up is offline   Reply With Quote
Old 12-22-2013, 09:31 AM   #3615
For me it depends on track conditions and perhaps even more so on the actual vehicle. I'm currently running a ball diff Wheeler and I do seem to like to run a little bit of DB, I think I'm at 9% right now.
I run Tekin ESCs, and they have a feature called Push Control which is essentially the opposite of DB, wherein at neutral, it applies a small amount of power. On my 1/8s I tend to run PC instead. I feel if I had an XB4 or another gear diffed Wheeler, I probably would run PC and no DB.
I suspect this is due to the difference in spool down characteristics between a ball vs gear diff.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
