Like Tree39Likes
Old 12-16-2013, 11:56 PM   #3571
onekiwi's Avatar
lol the durango and AE HT ones work, probably the schumacher ones as well
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 12-17-2013, 12:01 AM   #3572
Threedprof's Avatar
I'm going to try the Exoteck aluminum collars since I shot a pin through the plastic. Very miffed with Xray on that part
Cars: Xray XB4, B5m, SC5m, RT6
Guts: SchuurSpeed| Savox | Orion | Reedy | SMC
Radio: Futaba 4pks-R
Threedprof is offline   Reply With Quote
Old 12-17-2013, 12:18 AM   #3573
onekiwi's Avatar
Durango parts are cheaper but granted not a blingy
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 12-17-2013, 12:20 AM   #3574
BentKa's Avatar
Only reason this happens is lack of maintenance from driver/owner letting the axle joint run dry which in time pushes the pin through the plastic collar
Just clean and add a small amount of black grease……takes 1 minute……and you'll never have this "problem" again
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 12-17-2013, 12:26 AM   #3575
BentKa's Avatar
Originally Posted by Speedychris22 View Post
Just finished the build, must say very nice build as well quality of kit. The only thing I'm disappointed in was they are still using last years setup sheet?? No mention of new +2 holders, the 2mm shim for the rear hubs is confusing on the sheet, as well as the 2mm shim for the arms is not even mentioned.
XB4 '14 setup sheets are now up
http://forum.teamxray.com/xsheets.php
Bent
Old 12-17-2013, 12:34 AM   #3576
Threedprof's Avatar
Good to know, Bent. How often do you lube the joints?
Old 12-17-2013, 12:57 AM   #3577
BentKa's Avatar
All depends on surface and conditions really
Indoors clay with little to no dust…..once a week.
Outdoors dirt…..end of day after clean up.
Outdoors dirt in the wet……2-3 times during the day……after practice…..after qualifying and after clean up.
It really only takes 2-3 minutes to do all 6 joints with a bit of cleaner, compressed air and black grease (or motorcycle dry lubricant) !
Added bonus is you get much less wear and slop in the joints and it lets the suspension cycle smoother
Maintenance is key to a well performing buggy
Bent
Old 12-17-2013, 01:05 AM   #3578
silvalis's Avatar
Trader Rating: 29 (100%+)
Bent
I did it once in 4 months after the pin popped. My drivetrain was freer before I put more grease in the joints. ha.
(I was doing bearings every 6-8 runs. ignored the cvds. lol.)
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 12-17-2013, 01:25 AM   #3579
Threedprof's Avatar
Thanks for the advice! What cleaner do you use? Can I use a standard carb cleaner spray? How do you aactually clean it? Spray directly into the joint then dry it out?
Old 12-17-2013, 01:42 AM   #3580
BentKa's Avatar
He he…..whatever works for you
Any cleaner that dissolves grease would work.
One that dries out would be preferred so you are certain you don't have any residue that will break down the new grease you apply
I use an automotive degreaser and a small brush and either let them sit and dry or blow them dry with compressed air.
Bent
Old 12-17-2013, 06:05 AM   #3581
Trader Rating: 15 (100%+)
Bent
I skipped this problem entirely by 1) using Tamiya Anti wear grease, it is a really think silver paste that maintains lubrication really well, 2) using Exotek aluminum collars and then 3) installing Durango cvd dust boots on all those joints keeping the dirt out. Works like a charm.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is online now   Reply With Quote
Old 12-17-2013, 06:22 AM   #3582
BentKa's Avatar
I like how you (and several others) refer to it as a "problem"
Keep the joints lubricated and keep the dirt out.
This isn't brain surgery.
Same thing you would do on any race vehicle no matter the scale
The Exotek cups are quality items and adds a bit of bling if you opt for the orange (have had them on the work bench for "a few months now")…..but they are far from a necessity and should never be used as a band aid for lack of 2-3 min. maintenance
Bent
Old 12-17-2013, 08:01 AM   #3583
Trader Rating: 48 (100%+)
When they mention the 2mm shim for rear hubs on the setup sheet. How do u know if it's on the left or right of the hub
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 12-17-2013, 08:27 AM   #3584
rraden's Avatar
Trader Rating: 231 (100%+)
+1 Did the same thing to mine. Works like a charm!
Xray XB8E 2016 | MBX7TR Eco | Xray XB4 2017 | Xray XB2 DE | Xray XB8 2017
Dirt Burners - Livonia, Mi
The Track - Carleton, MI
rraden is offline   Reply With Quote
Old 12-17-2013, 08:32 AM   #3585
rraden's Avatar
Bent
Agreed! But we are doing exactly as you suggest, "Keep the joints lubricated and keep the dirt out" Same outcome, just different approach.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
