Like Tree52Likes
Old 12-11-2013, 07:56 PM   #3541
Trader Rating: 9 (91%+)
Quick question.
Does soaking the orings in diff oil help to prevent the gear diffs from leaking?
leongkc is offline   Reply With Quote
Old 12-11-2013, 08:21 PM   #3542
Awesome thanks. Got my 2014 coming and a few exotek upgrades. Love my current xb4 and love it
Xb4
Rcexcitement
Maximus Rc Raceway
Sponsored by the one and only SBRD Racing
lonslo is offline   Reply With Quote
Old 12-12-2013, 07:36 AM   #3543
Nitronut3's Avatar
Send a message via AIM to Nitronut3
Originally Posted by leongkc View Post
Quick question.
Not really, I put a little grease on the oring seat and push the oring down, the grease helps seal a but better, and grease the out drive that goes thru the housing, that slight relief is their to hold grease and act as a last minute seal
Nate Jaskot
XRAY, RC America, KO Propo, Hudy, FX Engines, Nitropro, Rc addiction products , TeamSR, SmacTrac
Nitronut3 is offline   Reply With Quote
Old 12-12-2013, 07:49 AM   #3544
BillyT.'s Avatar
Well, the theory here is that if you soak the o-rings, the swell up a little bit, making them seal better...
So unless the o-rings in these diffs are some how impervious to swelling(maybe they are), it should work.
Certainly isn't going to hurt to soak them.
Nemo Racing USA
Agama : Bullitt : Beta
billy@nemoracingusa.com
BillyT. is offline   Reply With Quote
Old 12-12-2013, 08:12 AM   #3545
Soaking or greasing them don't seem to work.
Mine still leaks after every run.....
Old 12-12-2013, 10:14 AM   #3546
Try some of the green slime from associated. That's the best for orings I have found
Xb4
Rcexcitement
Maximus Rc Raceway
Old 12-12-2013, 10:51 AM   #3547
Zach Peterson's Avatar
Trader Rating: 38 (100%+)
Default fill level
Make sure have just enough oil, mine do not leak at all.
Team Hacz Racing
Zach Peterson is offline   Reply With Quote
Old 12-12-2013, 10:53 AM   #3548
Qwkrn U's Avatar
Trader Rating: 128 (100%+)
Haven't had a leaking issue with mine, but I did assemble with green slime. You may have a bad oring. The orange Kyosho orings may solve your issue as well.
Wayne Robison
B5m , X-ray XB4 '15 ,xb8e, Scte 2.0
Tiny Boat Guy Paint Designs, Checkered Flag Hobbies, creativecustomtees.com
Qwkrn U is offline   Reply With Quote
Old 12-12-2013, 12:22 PM   #3549
Blown up's Avatar
Is there only one company making weight kits?
XB4 RSpro/LRP 7.5 JR9000s, SCTE 2.0 RX8/Pro46 DS1015, SC10.2 RS/D3.5 17.5 DS1015,
Blown up is offline   Reply With Quote
Old 12-12-2013, 12:53 PM   #3550
Trader Rating: 15 (100%+)
The point of green slime however is to coat the orings and prevent the silicone oil from getting into the rubber and causing them to swell....
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 12-12-2013, 03:03 PM   #3551
just got my xb4:-) 2014. any build tips or set up ideas?i run on 2 tracks. one is tight indoor small med traction dirt and the other is large for tenth scale outdoor with a roof.
http://youtu.be/mDdc8iCzvUQ
auto2 is offline   Reply With Quote
Old 12-12-2013, 03:52 PM   #3552
Trader Rating: 55 (100%+)
I just picked up my kit as well nd clicked on the vid realizing I race at same tracks lol. Did u get it from Cruzin. I'm putting the avid pistons on my car as well starting with 5k front 3 rear I'm also going to be playing with the +2 rear holders to see if they help.
Speedychris22 is offline   Reply With Quote
Old 12-12-2013, 04:24 PM   #3553
yes I did.small world lol.
Old 12-12-2013, 07:56 PM   #3554
I did change out to new o-rings.
Green slime is a no no. The idea behind green slime is like someone just said, to prevent o-rings from swelling. This product came about because the o-rings on the Associated shocks swell alot from the shock oil and caused stiction.
Old 12-13-2013, 04:19 AM   #3555
mjk1210's Avatar
some things I typically change when going from a bigger track to a smaller track are:
smaller track:
1. lighter diff oil (5/3) (for higher traction I may change that to thicker oils) - this change makes it feel like I can get into and out of the tight corners quicker with more power applied through and out of the corner
2. move to front ackerman holes on steering rack - for really tight tracks this can add steering to the point that the rear end will swing around for the really tight turns.
3. move rear outer hinge pin to inner hole through hub. car seems more reactive to steering inputs. the rear doesn't feel like it lags behind in a turn.
4. for very tight tracks I will move the front shocks to the inner hole on the arm. this instantly adds droop and keeps the front tires on the ground longer as the chassis rolls through a turn. it can feel very aggressive this way though.
for larger tracks:
1. move rear shock in one hole on top.
2. heavier diff oil - especially if there is more traction
3. outer hinge pin hole on rear hub
4. rearward holes in steering rack
most of the time for larger tracks I'm trying to get the car to not rotate too early in the turn. the bigger and more sweeping the turns, the more I use these changes to dial the car in for the way I like to drive it.
Also, remember to tune for the majority of the track. I see a lot of people tuning for that ONE jump or the fast sweeper on a track only to get it wrong for nearly every other section.
for that track in the video I would personally change my car like I mentioned for small tracks with the exception of the front shock position on the arm. it looks like that track may be a little too loose to deal with that much steering.
Hope this helps
I'd rather be fishing!
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
