Like Tree36Likes
Old 12-13-2012, 03:06 PM   #331
gijoe64's Avatar
Trader Rating: 30 (100%+)
How does this buggy perform on a dirt or clay track?
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 12-13-2012, 03:15 PM   #332
CarlCrocco's Avatar
Trader Rating: 88 (100%+)
Originally Posted by BentKa View Post
I'm sure the hit he took from that SC weakened it as well prior to the failure.
But looking at the part it did look kind of brittle.
Wouldn't mind towers done in 3.5mm or even 4mm for some added strength for the camber link mounts
So did you finish yours tonight ?
I had to leave early to get my daughter to bed and with her breaking a c-hub + axle and then an a-arm + axle there wasn't much time left to finish mine
Bent
Looking at your signature your using the Tekin 6.5t, what gearing are you running?
Andrew Crocco "The Hammer"
Viper R/C
XB9E XSCT
CarlCrocco is offline   Reply With Quote
Old 12-13-2012, 03:36 PM   #333
BentKa's Avatar
Had to leave early so I didn't have time to get the ESC hooked up to go for a test drive
Kind of got held up wrenching on my daughters SC10 4x4 after she wrecked twice.
I have singled out a 19 and 20 to test for our track though......might start with the 19.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 12-13-2012, 04:26 PM   #334
Boz
Trader Rating: 23 (100%+)
Based on the gearing which I use in the DEX410, I will be starting with a 19t pinion too. I use 6.5t Pure2 Nosram.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 12-13-2012, 09:58 PM   #335
slow_jun's Avatar
Trader Rating: 14 (94%+)
are the gear diffs metal(Crown and Pinion)? or composites?
seems like the internals are composites.
thanks,
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 12-13-2012, 10:27 PM   #336
BentKa's Avatar
thanks,
Outdrives are metal.....rest is composite
Bent
Old 12-14-2012, 01:35 AM   #337
Suspended
oh, wouldnt you like to know.
ErnestHelmsley is offline   Reply With Quote
Old 12-14-2012, 06:13 AM   #338
RC MARKET's Avatar
Some Spare parts was onsale now !
rcmarket.com.hk
RC MARKET is offline   Reply With Quote
Old 12-14-2012, 07:06 AM   #339
onekiwi's Avatar
From the xray forum:
There is no reason to be concerned before you drive or even build the car. The car has plenty of hours of track tests in different conditions. Martin Bayer even used the final specs car in real races including the Czech Championship which he won, so the reliability was tested and is proven.
Slipper clutch - if you have the slipper clutch set loose you do not need to worry, the wheels will slip and the pinion will not break. If you however tighten the slipper too much (and this is what happen to those who experienced problems) you will create a solid axle instead of slipper clutch, the wheels will not slip and something (pinion) will break. That is common on all buggies of other brands using slipper clutch in the market.
Shimming the diff - Very Important - do not ship the diff. As mentioned in other threads, the diff was designed by purpose with a small play. If you shim the diff you will eliminate the play. The diff will during operation get warm and expand and if there is no play the diff will not work properly. Therefore there should be NO shims used.
Satelitte gears - they are made by purpose from composite, they are lighter and have better dynamic performance. They are moulded from very special composite mixture and have very good reliability. The same gears from same special material are used in the T4 and NT1 gear diff and the traction on foam tires on asphalt is several times higher than on a buggy track. Since there are no problems with the NT1 gear diffs at all there is absolutely no need for any worry about the composite gears for XB4. However if you want to feel more safe you can use the NT1 metalic optional gears #335030, they are direct fit.
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 12-14-2012, 07:22 AM   #340
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I would say breaking pinions or rotor shafts would mean a solid drive train.
UN4RACING is offline   Reply With Quote
Old 12-14-2012, 07:38 AM   #341
Well, almost all other buggies on the market, except Durango. Sorry, just had to say it. /end hijack
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 12-14-2012, 07:40 AM   #342
Super Moderator
racer1812's Avatar
when he says "pinion" he's referring to the diff pinion..I assume anyway.
Or am I reading YOUR post wrong?....but yes if you're breaking either of those I would consider the drive train bullet proof.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 12-14-2012, 08:22 AM   #343
Trader Rating: 19 (100%+)
I guess I'll need to watch my slipper. On my Durango, it is locked down completely
Cars I've Owned: Tekno EB48 & SCT410, AE 8.2e, AE SC10 4x4, MBX6e Tekno V4, Xray 808e, Xray 8Te, Losi 810e, Losi SCTE 4x4, Losi 22, Hot Bodies Ve8, Losi 8te, and plenty of Traxxas
Sponsors: Visa, Mastercard, Amex, and my wife's bank account.
Edumakated is offline   Reply With Quote
Old 12-14-2012, 09:14 AM   #344
sickpuppy1's Avatar
Trader Rating: 25 (100%+)
Its referring to parts INSIDE the diff......
If you cant fix it with a hammer, you have an electrical problem...
TeknoSCT410,Losi 22 2.0 & Eight-B 2.0,Losi LST2 , losi LXT circa 1990, it's a runner!
sickpuppy1 is offline   Reply With Quote
Old 12-14-2012, 09:52 AM   #345
Trader Rating: 26 (100%+)
Originally Posted by OleC View Post
READ THIS, IMPORTANT INFO!
I started building mine last night, and found something:
The manual says nothing about using shims to get proper mesh from the crown and pinion gears in the diff casing. There are no shims supplied either.
BUT, I had to add 0,2mm of shims in the rear diff, and 0,3mm of shims in the front diff to get perfect mesh.
That is quite a lot IMO, but not all kits will be the same so check yours while building. And check your car if you already have built it!
I had to use shims to get a tighter mesh. With the loose mesh I had in my diffs with no shims, I would not be surprised if the gears would strip quite easily.
ALL crown gears and pinions need to be shimmed in order to have perfect mesh, which is crucial for durability. I am a bit surprised that Xray chose not to include this...
Tamiya makes some very nice shim kits in 0,1 and 0,2 and 0,3mm thicknes (TAMIYA part number 53588 for the 10mm set). I bought a bunch of shim sets in various sizes some years a go, since there is always something that need to be shimmed properly
better take your diffs back apart . . . xray says shimming = bad news bears
bobf24 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
