Like Tree45Likes
Old 11-25-2013, 03:40 AM   #3421
I've finished my xb4, although am undecided what to to with the pistons. Seems to be a few different variations. I noticed that both the base setups for clay and carpet both use the same pistons, along with Bayers EOS setup. Anyone have any opinions?
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 11-25-2013, 03:50 AM   #3422
protc3's Avatar
Originally Posted by Jamison R View Post
Did you cut the chassis and remove plastic or just cut for flex? Looking for just a little more rear grip. Can you post a pic? Also did you change suspension bushings?
I will take a pic while i tear it down to clean. It took like 5 minutes and the feel was very noticable. I mostly run low to medium bite. It works awesome.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-25-2013, 04:50 AM   #3423
Trader Rating: 55 (100%+)
Did you remove the piece that's cut or does it stay put just cut for flex? Thanks for the help
Jamison R is offline   Reply With Quote
Old 11-25-2013, 06:12 AM   #3424
protc3's Avatar
I took it out. The aluminum chassis plate is already pocketed out to clear the ring gear so it makes it a super quick mod. I did it for a guy at the track in 2 minutes. Well worth it buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-25-2013, 06:50 AM   #3425
rraden's Avatar
Trader Rating: 232 (100%+)
Did you do anything different with the rear camber link mounts on the tower or hinge pin inserts? I also run on similar conditions and want to try this mod.
Xray XB8E 2016 | Xray XB4 2017 | Xray XB2 DE 2017 | Xray XB8 2017
Dirt Burners - Livonia, Mi
The Track - Carleton, MI
rraden is offline   Reply With Quote
Old 11-25-2013, 06:57 AM   #3426
protc3's Avatar
No, Everything comes down together. The whole rear end cluster. You will need to remove the 2mm carbon fiber shim from the front of the transmission housing by the drive shaft.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-25-2013, 09:10 AM   #3427
joeymdz's Avatar
Send a message via MSN to joeymdz
Did you use a razor blade?
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 11-25-2013, 09:55 AM   #3428
Blown up's Avatar
Some funny stuff on here!
On a side note $70.00 for aluminum shock caps
I was just checking to see what was avail because I picked my xb up previously loved, very clean and little run time, But I ran it saturday night for the first time and 2 of the four caps were weeping. I gave them a little snug up today so we'll see.
By the way, It did drive incredible! I got to the track early enough for about 20 laps of practice before racing and my first qual I was able to stay on pace w/the top 4 guy's. Soooo much fun!
I did finish off the wing that came w/it tho....This thing jumps like a gazelle!
XB4 RSpro/LRP 7.5 JR9000s, SCTE 2.0 RX8/Pro46 DS1015, SC10.2 RS/D3.5 17.5 DS1015,
Blown up is offline   Reply With Quote
Old 11-25-2013, 10:04 AM   #3429
joeymdz's Avatar
they'll probably still leak...
2 methods you can do:
use a grease around the threads to help seal the leak or purchase shock cap orings
http://www.amainhobbies.com/product_...10mm-O-Ring-10
Old 11-25-2013, 10:06 AM   #3430
protc3's Avatar
A pair of body scissors and an exacto. It came out very clean.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-25-2013, 11:09 AM   #3431
joeymdz's Avatar
I removed it. I kept the part i cut off for high grip. I had to mill off the bottom of the rear pin holder where it locks around the chassis as it protrudes out of the bottom. I took it down 2mm. Arm bushings are the same. All i wanted to change was lowering the hinge pins.
could you take a pic of your rear-end? (haha funny I know)
I want to see your modification to the hanger
Old 11-25-2013, 12:07 PM   #3432
protc3's Avatar
I will shoot a G rated version when I get home.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-25-2013, 01:27 PM   #3433
Trader Rating: 15 (100%+)
Originally Posted by neallewis View Post
I've picked up the two +2 rear lower suspension holders today from MB Models.
363311 and 363321. They are shown below compared to the regular kit rear ones.
I've modified (Dremel) the kit RR holder to allow it to be mounted directly to the chassis, as i'd already removed the plastic rear section of the chassis for the ralls racing under-gearbox weight. I ran the car with the dropped gearbox and modified kit hangers on my slippy and it was excellent. Really helped lock in the rear of the car.
I've now got the new optional +2 hangers and they raise the mount points higher/closer to the outdrive by 2mm. really hoping this helps to lock in the rear end more on the slippy stuff with the dripped gearbox. Testing Sunday, will feedback.
Anyone else done this yet?
I knew I had seen the stock rear hanger mod already.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 11-25-2013, 03:45 PM   #3434
Trader Rating: 50 (100%+)
Just ordered the 2014 version, along with the 363311 nd 363321 optional hangers. For low to md bite track what diff oil wt should I start with? Also this will be my first xray, any build tips?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 11-25-2013, 04:07 PM   #3435
joeymdz's Avatar
where did you order the optional hangers?
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
