Like Tree52Likes
Old 11-20-2013, 04:43 AM   #3376
Pintopint's Avatar
In the rear kit there is two plate.
Pintopint is offline   Reply With Quote
Old 11-20-2013, 06:03 AM   #3377
BentKa's Avatar
Originally Posted by Pintopint View Post
The item contains two carbon plate per bag?
Originally Posted by mjk1210 View Post
looks like 1 to me. And it says "plate" not "plates". but there seems to be alot of screws in that bag as well. hmmmm.
Originally Posted by 001casey View Post
In the part number description it says L+R = 1 left and 1 Right. I assume it means a pair. I know you should never assume anything.
They come as set of 2 (Left + Right) for either front or rear.
Same as for the T4 and XB9(E)
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 11-20-2013, 06:33 AM   #3378
BillyT.'s Avatar
2014s should be here Friday... can't wait...
Nemo Racing USA
Agama : Bullitt : Beta
[email protected]
BillyT. is offline   Reply With Quote
Old 11-20-2013, 07:43 AM   #3379
fmm
Hi everybody
I am new in this forum as I am also new for xray and 4wd . I recently bought the new xb4 2014 and I have a question that any of you may help me to solve.
I have been reading a lot about the importance of the slipper clutch setting. As I am going to be using my car in high byte tracks (carpet), I think that the slipper clutch setting is critical to do not damage the drivetrain.
I have experience in setting slipper in 2wd, but I have never done it in a 4wd, so if someone can explain me step by step how to do it, I would really appreciate it. By setting I mean how to adjust the slipper clutch depending on the track surface and characteristics. I have already read the manual and I know the recommended range (5,7 mm- 6,3 mm), but I assume that this range is illustrative/guide and I need to fine tune the slipper clutch on the track. This fine tune setting is what I am asking for.
I also take the chance to ask for the optional diff gears. I am going to buy some spares, which include the diff gear (as I am going to be driving on carpet, I think is good to have a replacement for them). So I was wondering if it would make sense to buy the optional gears (graphite or metal) instead of the composite ones, as spare. Which are the pros and cons of graphite and metal gears vs composite? Does someone have experience with them?
Thank you very much and really looking forward for your responses.
fmm is offline   Reply With Quote
Old 11-21-2013, 04:37 PM   #3380
xrayracer1's Avatar
Default running xb4 with 17.5 blinky gearing help
Hi, I have an xb4 that I've raced once at my club with a 10.5 turn motor. I don't race there anymore due to certain reasons, and a couple of my fiends want me to race 17.5 stock with them in Sydney.
Here is my problem: I'm running a speed passion reventon S with a speed passion 17.5 motor. I have a 30t pinion and a modified AE 75t spur, and I have the timing up as far as it will go and its still slow.
Any ideas how I can get more speed out of the sucker?
If you can please PM me.
Thanks.
xrayracer1 is offline   Reply With Quote
Old 11-21-2013, 04:52 PM   #3381
Trader Rating: 28 (100%+)
I would go back to stock gearing and adjust timing and boost from there.
Thanks to my sponsors
Proline racing Sidewinder Fuel 4C Hobby Supply Upgrade-Rc Psm-Rc Rcdepot.ca RcAmerica Hudy Xray
kyok2 is offline   Reply With Quote
Old 11-21-2013, 05:23 PM   #3382
jhautz's Avatar
Trader Rating: 85 (100%+)
Thanks.
If your motor temps are ok, then bigger pinon and/or smaller spur is the only answer to your question.
Or you could throw some monster truck tires on it.....
I think no matter what you do, coming from running a modified motor, the 17.5 is gonna seem real slow. 17.5 feels slow to me in a 2wd buggy. I can imagine running it in 4wd unless the track is tiny.
jhautz is offline   Reply With Quote
Old 11-21-2013, 05:27 PM   #3383
silvalis's Avatar
Trader Rating: 29 (100%+)
Thanks.
go down to a 69T spur. I ran 30/69 @ 40 deg motor timing on a reedy m2/viper vtx10.
17.5 stock here is no boost.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 11-21-2013, 06:18 PM   #3384
xrayracer1's Avatar
Cool, thanks for the help.
Old 11-21-2013, 08:52 PM   #3385
Trader Rating: 54 (100%+)
I'm looking to purchase the 2014 version, should I upgrade the diff gears to steel? Also has anyone got the 14 yet? Looking to see what they think
Speedychris22 is offline   Reply With Quote
Old 11-22-2013, 07:40 AM   #3386
EricW's Avatar
Is the 2014 available in the US yet? Anyone have one?
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 11-22-2013, 08:20 AM   #3387
BillyT.'s Avatar
Was told they would be in today... fingers crossed.
Nemo Racing USA
[email protected]
Old 11-22-2013, 08:29 AM   #3388
asc6000's Avatar
Trader Rating: 15 (100%+)
Your challenge will be learning how to tune the diffs. A completely different game than 2wd. The slipper setting is easy by comparison, start with the 6.3 and go from there. The only real caution being to not have it too tight to start.
Originally Posted by fmm View Post
Hi everybody
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 11-22-2013, 08:39 AM   #3389
asc6000's Avatar
Originally Posted by RC MARKET View Post
XRAY New Option Parts
why ? EXACTLY what is this improving ? Under what conditions is the stock arm inadequate ?
Ayrton Senna
Old 11-22-2013, 09:02 AM   #3390
MikeXray's Avatar
Trader Rating: 73 (100%+)
Stiffening plates, increase rigidity which should reduce traction, used on very high bite tracks only.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
miranmotorports
