Like Tree36Likes
Old 11-11-2013, 09:52 AM   #3331
Trader Rating: 15 (100%+)
All of the above is good advice, just remember to change one thing at a time, go out & run your buggy, then try the next change to see if it's starting to work for you. Don't make 10 changes all at once or you'll get lost in what works and what doesn't and be no further ahead.
I would 1st try the inner hole on the arm, standing the shock up a bit, softening it essentially. Then try one dot springs back in the outside arm hole. If you don't have one dot springs - try either AE or TLR 2.0lbs springs. Then try moving the rear inner camber link down a spot.
I run this set up:
http://www.petitrc.com/setup/xray/se...lid2013071820/
Don't worry about the full top deck & custom 2 hole pistons, just run 3 hole 1.3's all around - AE 40wt front, AE 32.5wt rear 2 dot fronts, 1 dot rears. Diffs 7K front, 3k rear.
We have a large clay track (22-25 sec laps) and it works well, there.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 11-12-2013, 05:29 PM   #3332
monsterbrad's Avatar
Default new xb4 owner
Hey guys new to this buggy always wanted something Xray and finally after 20 years I got a next to new used.
Has anybody tried the avid pistons ???
I have a set that came with the stuff I bought and the car looks to be set up stock.
I am going to run the car on clay and have a ton of tire combos mostly AKA in all styles and compounds red and blue inserts.
Any help would be great
thanks
monsterbrad is offline   Reply With Quote
Old 11-12-2013, 05:37 PM   #3333
joeymdz's Avatar
Send a message via MSN to joeymdz
You can run it box stock to get a feel for it.. you wont be disappointed but definitely use the avid pistons (night and day difference).
I personally love the Martin Bayer setup that's listed above your post from heavyd99. It has tons of grip and steering but you will need a few xray items to complete it.
Other that enjoy it.. it's a great 4wd
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 11-12-2013, 05:48 PM   #3334
Ok so how is this car for durability?
I see alot of 1/10 4wd's break in the past
this one seems to get great reviews from what I have read on here.
thanks for the help keeps me from reading the entire forum which I am currently doing!
Old 11-12-2013, 07:18 PM   #3335
hobdog's Avatar
Trader Rating: 19 (100%+)
It is the most durable 4wd I have ever had, and I have had most of them
Lunsford racing
Kyosho RB6
DEX408V2
Hoby
hobdog is offline   Reply With Quote
Old 11-13-2013, 08:18 AM   #3336
joeymdz's Avatar
LIES!!! you seen what I can do with my Xray and a steel beam!
This car is very durable and dependable
Old 11-13-2013, 11:12 AM   #3337
Which parts do I most likely need as spares?
The setup sheet for carpet says that the +2mm rear suspension holders should be used - is that with or without the plastic plate that goes under the gearbox?
Also aren't the +2mm holders for low traction?
Regards,
David
niemand is offline   Reply With Quote
Old 11-13-2013, 02:03 PM   #3338
silvalis's Avatar
Trader Rating: 29 (100%+)
I'd pick up some ballcups for the camber links.
Front arms would be standard I guess.
Some CVA covers too, but I only needed these 5 months later...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 11-13-2013, 02:04 PM   #3339
seth556's Avatar
Trader Rating: 42 (100%+)
On the Xray website they suggest the +2 holders would be good for low traction but I would think it'd be the opposite. From what I can tell they just raise up the rear roll center. A higher roll center just decreases traction. You're also moving the arm closer to the diff outdrive so you're decreasing the natural tendency of the car to squat under acceleration. If anyone has had a 22 and raised the tranny for more rear bite, you'll know what I'm talking about.
For spares, maybe some wing mounts, ball cups, and some arms. Doubtful you'll go through many arms though. The others will break with a really hard hit.
seth556 is offline   Reply With Quote
Old 11-13-2013, 05:21 PM   #3340
I wondered about the ball ends that seems to be a common part in all RCs that see the track.
Hard hits are bound to happen
What motor and speedo combos are you guys running?
I have an old GTB and thinking about an 8.5 novak motor ballistic
Old 11-13-2013, 07:36 PM   #3341
Team Orion R10 and VST 5.5, I prefer to run less boost and timing, but a hotter motor
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 11-13-2013, 08:01 PM   #3342
nexxus's Avatar
Trader Rating: 301 (100%+)
In one race meet I broke a suspension arm, front bulkhead, bent a hingepin, had a cv joint fail and two front hinge pin bushes pretty much disintegrated
That's in 17.5 Blinky!
Spare parts I keep are:
1 of each rear arm
1 front arm (both sides the same)
1 Rear upright
1 front upright
1 front bulkhead
2 spurs
1 set slipper pads
As well as some loose ball ends, screws, bearings etc
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 11-14-2013, 05:29 PM   #3343
where are you guys getting your parts ??
Amain
Old 11-14-2013, 07:29 PM   #3344
neallewis's Avatar
Amain
MB Models: http://www.rccarshop.co.uk/index.php...=351&limit=all
YZ-2 | B-MAX4III | 2x B-MAX2 MR | Cougar KF | RC10 | RC10WC | Supastox GT
neallewis is offline   Reply With Quote
Old 11-14-2013, 07:37 PM   #3345
Amain
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
Tijuana_Taxi is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
